oil on top of the engine 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blackpearl17, Sep 11, 2020.
  1. Sep 11, 2020 at 10:12 AM
    blackpearl17
    blackpearl17 [OP] New Member
    hi .!!! yesterday i was changing spark plugs on my 2015 taco v6 4.0 .... and when i removed the engine covert noticed oil splashed under and a little bit on the top of the engine..... i have no idea whats going on... just wandering if anyone has at least an idea of what could be happening here...
  2. Sep 11, 2020 at 11:28 AM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I can only guess the oil shot itself over there from someplace. Is there any oil on the underside of your hood? Do you notice oil any place else in the truck? I would clean it up good and run the truck with the hood open. Maybe have someone give some throttle and you look to see where the oil could be coming from.
  3. Sep 11, 2020 at 11:32 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Do you have a K&N air filter?
    If not I suspect you have a bad PCV valve causing excessive oil vapor being introduced into the intake to be burnt off, there's really not much the oil could have come from and gotten *on top* of the airbox like that.
    I believe the airbox may be oil saturated and the fine dry silt is acting like developer and wicking the oil out of the pores in the plastic.
    jaredjnolan, ninja89 and Hobbs like this.
  4. Sep 11, 2020 at 11:34 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    X2
  5. Sep 11, 2020 at 11:41 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    X3 but you did a helluva job with the explanation! :cheers:
    igno1tus and Key-Rei[QUOTED] like this.
  6. Sep 11, 2020 at 12:08 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Try cleaning your engine bay would help.
  7. Sep 11, 2020 at 4:01 PM
    ninja89
    ninja89 HUH?
    install an OIL CATCH CAN. that will seperate the oil from the pcv.
  8. Sep 11, 2020 at 4:37 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Who changes your oil?
    If it’s not you, who know what someone could have spilled?
  9. Sep 16, 2020 at 8:19 PM
    blackpearl17
    UPDATE..!! first of all thanks everyone for the response.... my mechanic skills goes as far as youtube goes lol....... so yea i did run the truck 400km after i found the oil with out the engine cover on it... and it is completely dry.... not a single drop...... and is funny the some of you ask me who does my oil changes cuse i do my own but last one i did engine, diffs, transfer etc etc and my brother was helping me i ask him and he said that he dropped some oil but never saw where it went and im assuming it did go on top the engine cover and got trapped with the white blanket to later on dripped on the engine itself ..... i did consider the bad pvc and i have been monitoring closely and now is been close to 800km and havent found anything (i drive 3/4 of alberta through the month) so i will call it good for now.... and drop a message if i find something later on..... thanks everyone again..!!
    Bishop84 likes this.
  10. Sep 16, 2020 at 8:23 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Honestly looks like the air box is split there.
    BassAckwards likes this.
  11. Sep 16, 2020 at 8:24 PM
    Bishop84
    Bishop84 Well-Known Member
    Curious if you have lots of blowby. A quick check for blowby is to open the oil fill cap while its running. A really bad engine you will hear the purring of the motor and see gas come out.
  12. Sep 16, 2020 at 10:05 PM
    TacoTuesday1
    FL
    Oil goes down, not up. Due to gravity.
    And rearward, due to the car moving forward.
    Oil leaks are typically diagnosed by cleaning the fuck out of the area such as with a solvent like brake cleaner, letting it dry or blowing it dry with compressed air
    maybe a rinse with degreaser, brushing, and water; whatever works
    followed by spraying with a white film coating of leak detection spray, such as Gold Bond Foot Spray Power for about $3 from walmart. The talcum, talc, or whatever it's called, creates a white film.
    Then after driving, if the film stays white and dry, there is no leak.
    If there is a leak, it becomes more clearly visible over the white dried spray film.
    I've not tried other methods such as adding UV dye to oil. I hear that stuff stinks. I don't know if it requires an oil change after.
