Oil over filled..
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jws6295, Apr 3, 2021.
  1. Apr 3, 2021 at 6:54 PM
    jws6295
    jws6295 [OP] Well-Known Member
    Central PA
    2016 SR5 double cab long bed
    Not sure what everyone’s theory is on this.. I know the manual says 6.2 quarts with filter. So I’ve noticed on my “Toyota Owners” page that in the past dealers have put 7 quarts of oil in the truck in the past.
    I recently changed my oil and filter.. did a few other things around the truck while my oil was draining. My dumbass put 7quarts in. Now I do know that’s overfilled. But I noticed one side of the dipstick reads dead nuts and the other side reads sky high. Anyone else on here been in the same situation? These new dipsticks suck to read. I’m assuming the high side reading is just because of the oil in the dipstick tube?
  2. Apr 3, 2021 at 7:13 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    let it sit overnight and in the AM don't start it just pull the dip stick out, should get a good read.
  3. Apr 3, 2021 at 7:23 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Did they actually use 7qts. Or was it billed as 7 qts.
    I typically get billed for 6 quarts on my 2nd Gen. It actually holds 5.5 qts.
    They don’t sell half quarts. (But it’s pumped from a hose? Beats me)
  4. Apr 3, 2021 at 7:26 PM
    bigoldbeef
    bigoldbeef Well-Known Member
    18 DCSB OR MT, 22 DCSB OR AUTO
    I’d just run it, it’s not like you put 10 quarts in it.
  5. Apr 3, 2021 at 7:28 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I think it’s about 6.1 qts but I never drain the oil all the way and just put in 6 qts. I recently had a tire shop do my oil change because I didn’t want to get on the ground that day and they put in 5.5 qts.
    jws6295[OP] likes this.
  6. Apr 3, 2021 at 7:30 PM
    Professor D
    Professor D Ex retired lion tamer
    Gregorny
    Mass
    2019 Toyota Tacoma race car
    Yes
    Honestly don’t worry about it I drained my trans pan and double filled the oil on my 2010 and drove 15 miles wondering why my trans was slipping so hard.. (Don’t bash me too hard I was raised by a single mom and was 19). FWIW I had that truck for another 170k and sold with 250k on it. don’t worry check oil level in the AM as suggested and if you feel like you’d be more comfortable drain all the oil into a clean drain pan and add in most of it eyeball 5.5 quarts. Check dip stick and add accordingly. I think you’d be alright with a quart over but it’s your truck.
  7. Apr 3, 2021 at 7:30 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    You’re SURE you didn’t drain the transmission?
  8. Apr 3, 2021 at 7:31 PM
    tedusmc1345
    tedusmc1345 Well-Known Member
    ted
    2018 Tacoma Sport 4x4
    If you really worry about it, check in the morning then drain half qt.
    jws6295[OP] and CusterFan like this.
  9. Apr 3, 2021 at 8:04 PM
    jws6295
    Central PA
    Thanks everyone! I’ll check it again in the morning but it sounds like from you guys opinion I’ll be good just to run the damn thing. I’ve just heard bad story’s about oil “foaming” but I highly doubt roughly a quart over will do that. Anyone else hate the dipsticks on the Tacoma’s? Or is it just me? My wife’s civic is so much easier to read.
    shotgunbilly420 likes this.
  10. Apr 3, 2021 at 8:05 PM
    Professor D
    Gregorny
    Mass
    Yes
    I have never liked the dipstick in
    The Tacoma’s but not nearly as bad as my F350s twizzler of a dipstick
  11. Apr 3, 2021 at 8:19 PM
    Professor D
    Gregorny
    Mass
    Yes
    If you decide to go this route keep in mind it will get quite messy. Only reason I suggested to drain it all and add back. Again from experience from my own mistakes which I make more often then I’d like to admit. And I’m sure there’s a way to use quoted posts method without making a mess. I just clearly can’t think of it.
    OG_Tacoma likes this.
  12. Apr 3, 2021 at 8:24 PM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    proper way to check the oil level especially with 0w-20 newly filled or even lighter weight oil:
    run the engine for more than 15 mins (user manual says 5 mins, but V6 takes way longer than 5 mins to reach max working temp)
    shut of the engine
    immediately pull the dipstick out
    wait 10 mins, close the hood if you don't want dirt fall into the dipstick tube
    insert fully and pull out and get a reading
    what you are reading is most likely a very think transparent film of oil and you'll see a line but don't expect anything caramel color at all with new light weight oil
    you only get 1 shot at reading this because as soon as you insert it back and pull out again the residual oil in the tube will mess up the reading
    OG_Tacoma, over60 and Tripod1404 like this.
  13. Apr 3, 2021 at 8:35 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Honestly, I'm not losing sleep over 0.8 quarts.
    shotgunbilly420 and wilcam47 like this.
  14. Apr 3, 2021 at 8:42 PM
    tedusmc1345
    ted
    Use the filter drain hole and don’t screw all way out.
    kahanabob and shakerhood like this.
  15. Apr 3, 2021 at 8:44 PM
    Professor D
    Gregorny
    Mass
    Yes
    I thought about that but would it not create a drain pattern too wide for your average oil drain pan?
  16. Apr 3, 2021 at 8:49 PM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    The reason you've seen 7qts on your bill is likely because a dealer is going to charge for full quarts. Most shops dont charge partial quarts when it comes to engine oil. So. 6.2 gets charged to the customer as 7.
    Dawelda, Kev250R and shakerhood like this.
  17. Apr 3, 2021 at 10:05 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    It doesnt really pour out until you insert that little drain tool in, I like to stick it in the top of an empty water bottle to drain the filter.
    over60 and The hammer like this.
  18. Apr 3, 2021 at 10:07 PM
    Professor D
    Gregorny
    Mass
    Yes
    Okay I thought you meant draining via the oil drain pan. Not the filter.
    shakerhood[QUOTED] likes this.
  19. Apr 3, 2021 at 10:11 PM
    Tripod1404
    Tripod1404 Annihilator tripod
    Yeah my dealer also charges 7qts but adjusts the price per qt to match price for 6.2 qts. I figured this out because there was a discount on oil they used, and I asked why I got a discount. They explained to me that their system doesn’t allow fractions for number or parts used, so they round it to the next number and apply a discount to match the price to the actual amount used.
    Kev250R likes this.
  20. Apr 3, 2021 at 11:29 PM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    It "probably" won't be an issue, but I wouldn't risk $10k engine damage over "probably"..... especially when it's an easy fix. You might not have an issue until you are on an incline.... whip a little oil and suck it into a bearing.
    Just fix it right. Drain about .8 quarts. Figure out how to get a good read on your dipstick.
    OG_Tacoma and Bleep100 like this.
