Oil over filled..
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jws6295, Apr 3, 2021.
  1. Apr 4, 2021 at 3:18 AM
    JEFFRPM
    JEFFRPM Well-Known Member
    Jeff
    2018 inferno Double cab long bed 4x4
    17 x 8.5 KMC wheels, yokohama 285-70-17 geolander, 3" lift, 800 watts of alpine, leer shell, front & rear cloud cameras,
    Don't sweat it my illustrious dealer put 8 quarts in mine I drove it 10,000 miles till the next change. I never check oil level......It's a Toyota they NEVER use oil.
    BTW I drive it like I stole it (80 to 90 mph everywhere & lots of wide open shifts @ 6500rpm) so the talk about oil foaming is bullshit mine has 140,000 no prob.
  2. Apr 4, 2021 at 4:28 AM
    Clearwater Bill
    Billy
    Largo Florida
    Finally a fresh view.
    Please post your other anecdotal maintenance and operational guides.
    We need to be freed from all these silly engineering based methodologies!
    OG_Tacoma, G8R_Taco, Markcal and 5 others like this.
  3. Apr 4, 2021 at 4:35 AM
    JEFFRPM
    Jeff
    Granted I should take better care of my taco but theirs a reason third world terrorists use these things for overthrowing governments
    YOU CAN'T KILL THEM & Lord knows I inadvertently try after 300,000 miles of beating the shit out of them quit worrying.....besides who are you saving them for?
    The next owner?
  4. Apr 4, 2021 at 4:38 AM
    Clearwater Bill
    Billy
    Largo Florida
    Right on brother.
    Please post your VIN so those sissy's can avoid your truck when it hits the used market because Carvana has paid you more than it cost you to begin with.
  5. Apr 4, 2021 at 4:47 AM
    JEFFRPM
    Jeff
    My last 2 trucks were used as frames to build class 7 score race trucks so they "disappear" from the face of the earth.
    Besides if someone with half a brain seen one of my old trucks they'd know it was used up from 30' away
    jws6295[OP] likes this.
  6. Apr 4, 2021 at 4:58 AM
    jws6295
    jws6295 [OP] Well-Known Member
    Central PA
    2016 SR5 double cab long bed
    This a nice fresh view! I’ve personally never talked to someone that oil foamed and spun a bearing BUT I know it can happen. I bought my truck certified pre owned so I do have the 100,000 mile power train warranty. So if something we’re to happen it would hopefully be on Toyota. Also doesn’t the 3.5 engine have a windage tray? Parts diagram says it’s a baffle? But it certainly looks like a windage tray to me.
  7. Apr 4, 2021 at 5:18 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Geez i must of got a bad toyota back in 86. I drove my 4 cylinder pretty hard, and the engine failed around 60k miles breaking a crankshaft key tearing up the crank. Toyota replaced it with a new crank, saying it must of been a rare metallurgical failure, and i was back on my way. I think if they only knew.
    shakerhood likes this.
  8. Apr 4, 2021 at 5:30 AM
    JEFFRPM
    Jeff
    We raced class 7 4x4 from 1983 to 1988 running the 20R & 22RE 4 poppers we couldrnt kill them no matter how hard we beat on them. Tach who needed a tach? we'd shift when the valves floated. Our only problem was the damn 5 speed transmissions would only last 1 race......maybe.. Some times the only gear left was 4th & that was hell on clutches
  9. Apr 4, 2021 at 5:45 AM
    Clearwater Bill
    Billy
    Largo Florida
    Not if they could prove the problem was caused by your service work.
    And they would certainly try.
  10. Apr 4, 2021 at 7:15 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    No problemo, keep it simple:
    Simply drain all the oil out, put in a new oil filter and close her up.
    Then simply take and put in 6 qts of oil and call it a day.
    And I wouldn’t worry about the .2 qts. You’ll never get all that drained out unless you remove the oil cooler and lines. But if you do add the .2qts, then you’ll be overfilled and back to square one.
    Moral of the story, keep it simple, it’s not that complicated.
    Clearwater Bill likes this.
  11. Apr 4, 2021 at 7:24 AM
    The hammer
    This guy…This is 2021!
    Have you not heard or noticed? Congress scolded the auto makers in public hearings sometime after the 2008 financial crash for making their products last too long.
    Point being, new vehicles and products are not made to last, but made to be either replaced or insured against breakdowns to keep the factories rolling, people buying and employed so they keep paying more tax dollars they (congress) can spend.
  12. Apr 4, 2021 at 7:26 AM
    Hafaday
    Hafaday Well-Known Member
    Bill
    Richmond, VA.
    19, DCSB, Off Road. 23 KLX300, 14JKU
    You could always get one of them Fumoto, oil drain plug thingy’s. Drain off what ever you need.
  13. Apr 4, 2021 at 7:38 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    The downside to an overfilled Ccase is from the crankshaft.
    As it rotates, if the oil level is high enough, the journals on the crankshaft will enter the pool of oil. This creates a tremendous SPLASH. The splash will overload the cylinder walls with oil and lead to foaming. You may also see blue smoke from the exhaust as the oil on the cylinder wall overwhelms the oil scraper rings on the piston, leading to oil blowby into the combustion chamber.
    @JEFFRPM Thanks just the same. I'll read your maintenance advice, doubtful if I'll ever heed it.
  14. Apr 4, 2021 at 7:42 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    I wouldn't run it personally. Risk/reward is too low
  15. Apr 4, 2021 at 7:46 AM
    #35
    FuzzysTacos
    FuzzysTacos Well-Known Member
    Corey
    Wichita, KS
    Sold: 2017 TRD OR/2012 TRD Sport
    Some folks have taken high grit sandpaper to their dipsticks to help read it. But yes, let it sit for a longer period. Every time you pull it out you "contaminate" the tube for a shitty reading next time making it appear sky high.
  16. Apr 4, 2021 at 7:54 AM
    #36
    Trail Limo
    Trail Limo Well-Known Member
    This. I put 6qts in mine, and it's just below the top mark every time. So much easier than trying to deal with partial quarts.
    The hammer[QUOTED] likes this.
  17. Apr 4, 2021 at 8:45 AM
    #37
    muskratX22
    muskratX22 Well-Known Member
    Dave
    Illinois
    Mine came from the factory slightly over the full mark and both dealer oil changes are slightly over the full mark. Gone are the days when a mechanic gets the oil level close to full then carefully adds JUST enough to get to the full mark. BTW I have a 2.7L and I change @ 5,000 miles.
    OG_Tacoma likes this.
  18. Apr 4, 2021 at 8:49 AM
    #38
    jws6295
    Central PA
    That would explain why the two different readings. I’ve noticed you can pull that dipstick out with one side high and one side just right.. flip it 180 and it’ll read high on the opposite side that it did prior. That’s the odd part. I’ll probably drain some out tomorrow just for peace of mind.
  19. Apr 4, 2021 at 8:58 AM
    #39
    Knute
    That only means the dipstick enters the oil pool at an angle. Or there is a bit of residual oil in the dip tube. Ignore the trail, look to the solid oil level on the stick.
  20. Apr 4, 2021 at 9:19 AM
    #40
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    I would not leave 7 quarts in your engine. When I do my change I just run 6 quarts Penzoil Ultra Platinum, and 7 oz of Archoil 9100.
    Works very well for me.
