Oil over filled..
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jws6295, Apr 3, 2021.
  1. Apr 4, 2021 at 9:22 AM
    #41
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    But those are diesels.
  2. Apr 4, 2021 at 9:28 AM
    #42
    SRBenjamin
    Benny
    That's very very unlucky! I beat mine hard for 19 years and 590k miles, then drove it to the wreakers.
  3. Apr 4, 2021 at 10:53 AM
    #43
    BOSS-DS2
    BOSS-DS2 Well-Known Member
    Sam
    Texas
    2016 Tacoma 3.5L A/T DCSB
    Motofab 3” Spacer lift Spidertrax 1.25” wheel spacers Yokohama G003 M/T 285/75/17 (34”) MBRP 3” Turndown PowerStop slotted & drilled rotors Tekonsha P3 brake controller
    I almost always change the oil in my taco and my wife’s Corolla at the same time. Mine holds 6.2 and hers 4.4
    I buy 11 quarts and put 4.5 in hers and 6.5 in mine, problem solved.
    SandyTaco4x4 and shakerhood like this.
  4. Apr 4, 2021 at 11:06 AM
    #44
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    and she appreciates it
    Markcal, Junkhead, Otto-x and 3 others like this.
  5. Apr 7, 2021 at 3:16 PM
    #45
    GrievousAngel
    GrievousAngel Well-Known Member
    2019 Tacoma SR 4x4 V6 DCSB Super White
    Glad I found this. I was about to go out to buy a "spare" quart. It's silly for Toyota to come up with these uneven capacities.
  6. Apr 7, 2021 at 3:26 PM
    #46
    JEFFRPM
    JEFFRPM Well-Known Member
    Jeff
    2018 inferno Double cab long bed 4x4
    17 x 8.5 KMC wheels, yokohama 285-70-17 geolander, 3" lift, 800 watts of alpine, leer shell, front & rear cloud cameras,
    In America it's uneven amounts because we use quarts on the rest planet it's litres
    OG_Tacoma, Junkhead and malatx like this.
  7. Apr 7, 2021 at 3:31 PM
    #47
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    has been decades since any manufacturer has used ‘ splash ‘ lubrication
    whereby the crank assembly touches the oil n the sump
    fraction overfill wont hurt a thing
    better than being low........nxt change U will do better
  8. Apr 7, 2021 at 3:46 PM
    #48
    ret42
    ret42 Well-Known Member
    VA
    Cement 2021 TRD OR 6MT
    6.2/1.057=5.8674 liters
    Ah, yep. That clears it up.
  9. Apr 7, 2021 at 3:51 PM
    #49
    OrangeRa1n
    OrangeRa1n Well-Known Member
    Houston Area
    TRD-Offroad 2021
    I did not read this whole thread but:
    1. Start/Warm engine
    2. Turn off engine
    3. Remove dipstick
    4. Wait 15ish minutes
    The oil gets stuck on the walls of the dipstick tube. Letting the oil settle down into the oil pan usually helps with readings. Overfilling CAN be bad as it may cause the oil to foam.
    OG_Tacoma likes this.
  10. Apr 7, 2021 at 5:33 PM
    #50
    SRBenjamin
    Benny
    the rest of the planet is wrong.
  11. Apr 7, 2021 at 6:08 PM
    #51
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Yep, to mimic what others have said, 6qts and go. I dont even check oil level immediately after because its so damn hard to read! haha i just warm the engine drive it a week then check level
  12. Apr 7, 2021 at 6:35 PM
    #52
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    I wouldn't want mine over filled by a quart and I don't have any trouble reading the dip stick .
    OG_Tacoma and jimmerheck like this.
  13. May 31, 2021 at 5:06 PM
    #53
    wolf2600
    wolf2600 Well-Known Member
    San Jose, CA
    2021 TRD-OR 6MT-SOLD
    Coyoza Tuned
    Adding on to this, I changed the oil and filter for the first time about a month ago and after adding ~6.5qts (incl. ~0.25qt into the filter itself before installing it), I wasn't seeing anything indicating on the dipstick.
    Drove a little, let it sit, still nothing indicated. Didn't want to risk overfilling, and there were no low oil/low oil pressure warning lights, so I just drove it that way for a few weeks.
    But it had been weighing on my mind, so last weekend, I decided to check again (nothing), then added another 1/2qt. AH! Now, I can see oil barely registering at the tip of the dipstick. In total, I must have added ~7.25qts before any oil was visible on the dipstick.
    Yes, flat surface.
    Yes, let the engine run.
    Yes, let it sit overnight and checked in the morning.
    :confused: Don't know what to say, unless the measuring marks embossed on the side of the oil container are wrong. (2x 5qt containers of Mobil1)
  14. May 31, 2021 at 6:25 PM
    #54
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Something is very wrong here. The dipstick is not hitting down enough or bunching up or something else. When I changed mine a few weeks ago, 6 qts brings me to right below the top mark. As others, didn't bother pouring the additional 0.2 qts. Go back and see where things went wrong because 7.25 qts is way way too much.
    OG_Tacoma and Junkhead like this.
  15. Jun 1, 2021 at 8:39 AM
    #55
    Tacowin1013
    Agreed, i would drain and start over...
  16. Jun 1, 2021 at 9:29 AM
    #56
    CrazyAirborne
    CrazyAirborne Who jumps out of perfectly good airplanes?
    Central Wisconsin
    2017 TRD Sport
    Im betting you didnt push the dipstick down fully seating into the tube. I did this on my first oil change on the taco as well. It feels like its seated but it actually can go down into the the tube a little more and then you will see your oil line.
  17. Jun 1, 2021 at 3:45 PM
    #57
    GrievousAngel
    I got 6 individual bottles of Toyota synthetic, but I'm thinking of switching to Mobil 1 next time--I'm a little sketched out by buying oil on Amazon, since there's so much counterfeited goods, and that's the only way to get it at a reasonable price--but it's still expensive relative to Mobil 1. I figure I'll buy a 5 quart and 1 quart bottle, to eliminate the errors involved.
    But that begs the question--are these bottles filled precisely? Wonder what kind of quality control they have on how much is in there? I know: pour it in and check the dip stick.
  18. Jun 1, 2021 at 6:44 PM
    #58
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    They measure fill by flow meter and then QC check by weight. It should be very precise. Buy M1 at Wal-Mart. It will be cheaper than anywhere online.
    Edit: M1 0/20 extended performance 5qt $24.37 on Amazon. I just bought two of these today at Walmart for $24.88, so it's actually not cheaper but I'll take it right now for the +$0.50 each.
  19. Jun 1, 2021 at 8:18 PM
    #59
    dr4g1116
    dr4g1116 Well-Known Member
    2019 Silver Sky Metallic TRD OR SB M/T
    I overfilled my truck a bit at its first oil change but luckily have a vacuum pump to drain a little out from the top.
  20. Jun 1, 2021 at 8:43 PM
    #60
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    This is how I do it except after pulling/cleaning the dip stick, i stick the tip back in and let it flop until 5 mins to settle
