Oil Overfilled?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SDTaco4x4, Feb 24, 2019.
  1. Feb 24, 2019 at 2:30 PM
    SDTaco4x4
    SDTaco4x4 [OP] Well-Known Member
    San Diego
    2016 Black TRD Sport 4x4
    So I let the dealership do my oil changes, and today I decided decided to check my oil level, after I got done washing the truck. I found it to be a bit less than an inch above the top dot in the stick. Now I'm not a mechanic, but I assume that is pretty overfilled.
    My question is, is that enough that I need to worry? I had the oil change done months ago, so I doubt it's too pressing (yes I know I should have check it the day it was done), but is there anything long term I need to worry about here?
    Also how much overfilled do you reckon it would have to be to read that far over the top dot?
    wilcam47 likes this.
  2. Feb 24, 2019 at 2:40 PM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    In all seriousness, drain some out, a little at a time, and measure how much to bring it to level.
    That is how much it was over filled.
    Change your own oil next time.
    Tac0Tic0, jmneill, bax and 4 others like this.
  3. Feb 24, 2019 at 2:41 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    I believe bottom dot to the top dot is 1qt.
    Also, recheck your oil level and do it on a flat surface. Pull the dip stick out, check both sides and let the oil in the tube drain for about 5 min, then recheck. If still too high, drain.
    mosquitoTaco and wilcam47 like this.
  4. Feb 24, 2019 at 2:42 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    shouldnt have to double check a dealership, if you do you need to find a different place...
  5. Feb 24, 2019 at 2:43 PM
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    This is correct on all gas vehicles
    Edit:
    Disclaimer: this is true on most vehicles unless you have the huge powerplant motor thats in 3rd gen, or a lawn mower or smaller 4 cycle engine.
  6. Feb 24, 2019 at 2:44 PM
    specter208
    California
    Excellent.
    mosquitoTaco[QUOTED] likes this.
  7. Feb 24, 2019 at 2:45 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Killing us smalls
    tcjacado likes this.
  8. Feb 24, 2019 at 2:47 PM
    SDTaco4x4
    San Diego
    :confused:
    CusterFan and boynoyce like this.
  9. Feb 24, 2019 at 2:49 PM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    You, and everybody else...
  10. Feb 24, 2019 at 2:53 PM
    mosquitoTaco
    Anthony
    SouthTennessee
    Yes
    Go outside and try it if you dont believe me
  11. Feb 24, 2019 at 2:55 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    My recommendation is to take it back to the dealer and have them correct the oil level and make sure you get documentation in case you have engine issues down the road. You are probably okay, but I would in the future change the oil myself or find a better shop.
    Also, if you take it back to the same dealer, check the level yourself before you leave.
    Modesto Tacoma likes this.
  12. Feb 24, 2019 at 2:55 PM
    mosquitoTaco
    Anthony
    SouthTennessee
    Is it showing you a picture diagram? No it's just stating low is considered 1.6 quarts above full.
  13. Feb 24, 2019 at 2:55 PM
    El Chivo Norteño
    El Chivo Norteño Well-Known Member
    Central Oregon
    2020 White DCLB 4X4 Off-Road
    You beat me too it. Thought I read somewhere it was 1.5qt between dots on the stick.
    Vbpiper likes this.
  14. Feb 24, 2019 at 2:56 PM
    qua77ro
    qua77ro Well-Known Member
    Socal
    '19 Taco TRD OR, '14 Cayman S, '10 S4
    Lube techs... the lowest ranking tech in the automotive service/repair industry?
    over60, wilcam47 and boynoyce like this.
  15. Feb 24, 2019 at 2:56 PM
    mosquitoTaco
    Anthony
    SouthTennessee
    No bro. It says 1.6
    Tac0Tic0 and Heepspo like this.
  16. Feb 24, 2019 at 2:57 PM
    mosquitoTaco
    Anthony
    SouthTennessee
    You must be an alignment tech. J/k
  17. Feb 24, 2019 at 2:59 PM
    El Chivo Norteño
    Central Oregon
    Sorry dude! Was of by .1
    :crapstorm:
  18. Feb 24, 2019 at 3:00 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    And missing an entire f.
    jmneill, SR-71A, mosquitoTaco and 2 others like this.
  19. Feb 24, 2019 at 3:01 PM
    El Chivo Norteño
    Central Oregon
    :rofl::rofl::rofl:
    stun gun[QUOTED] and boynoyce like this.
  20. Feb 24, 2019 at 3:02 PM
    SDTaco4x4
    San Diego
    Ok, i think I got it. Yall can stop arguing now. :rofl:
