Oil pan clearance
Discussion in 'General Tacoma Talk' started by Lord_Kelvin, Jan 13, 2024.
  1. Jan 13, 2024 at 8:07 AM
    Lord_Kelvin
    Lord_Kelvin [OP] New Member
    Kelvin
    2016 Gray Access cab Manual I4
    Hi all, I’m doing an engine swap and I’m running into a little concern. It’s my first time doing a swap and I didn’t realize just how much my rubber isolators would compress. Would you guys be concerned about 3/16 or 1/4 inch of clearance between the oil pan and steering rack fitting?
    I don’t plan on ever jumping the truck or doing any hard core trails with this rig, just overlanding stuff and a little towing.
    I can take the engine back out and raise the mounting surface but if you guys think it should be fine I’d rather not do all that work again if I don’t have too.
    The engine mounts are 7 years old if that makes a difference.
  2. Jan 15, 2024 at 12:19 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^If you brake-torque the vehicle, the engine will often shift more than 3/16", so that looks too close.
