Oil pan drain bolt repair
Discussion in 'Garage / Workshop' started by bigmw, Aug 19, 2024.
  1. Aug 19, 2024 at 8:06 PM
    bigmw
    bigmw [OP] Not-So-Well-Known Member
    Northeastern Ontario
    2016 Blue DCSB Sport 4x4, manual transmission
    Bunch of different mods
    Hi TW,
    My son broke off an oil pan drain bolt in his dirt bike. I had to drill the broken bolt out, but managed to nick the sides of the inside thread.
    My first repair involved an oversized bolt, with a smaller piggy back bolt in it. I used JB Weld extreme heat to secure the bolt in the broken threads. My son proceeded to break that off right on the first oil change.
    Second repair involved an Ecoplug
    https://www.amazon.ca/ECO-PLUG-Alum...e28fcc875ca236af9f19609a5543f975&gad_source=1
    I still had to use JB Weld around it to make sure there are no gaps.
    QUESTION:
    Is JB Weld extreme heat going to withstand contact with engine oil?
    Does anyone have experience with using that product on an oil pan?
  2. Aug 19, 2024 at 8:14 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    It will hold up OK to the oil if bonding surfaces are super clean to start. It's been years since I messed with JB WEld on engines, and the product I used years ago held up to oil OK, but it's more rigid and will crack
    That said, get the kid a torque wrench and shorter box ends and weaker arms :)
    All this junk may as well try but ultimately will fail at some point.......vs a new case.........
    bigmw[OP] likes this.
  3. Aug 19, 2024 at 8:19 PM
    bigmw
    Hahaha, I laughed at the torque wrench and weaker arms.
    I thought I had it cleaned well the first time, but I didn't watch him wrench it off. Maybe he went rightey-loosey again, since he's looking at it upside down.
  4. Aug 19, 2024 at 8:23 PM
    MGMDesertTaco
    I wonder if a tap and heli coil would have worked the first time? No idea on the JB weld holding up. I suppose permatex black gasket maker could be used if JB weld doesn't hold up.
  5. Aug 19, 2024 at 8:27 PM
    bigmw
    The way the inside threads broke off, I'm not sure heli coil has much to grab onto.
    The other problem with Heli coil is I can't find it locally, it's really expensive. But so was that ecoplug, I just thought the tapered design might have a better chance to grab and seal. Jb weld is just to fill any leftover gaps, and maybe add extra strength.
    MGMDesertTaco[QUOTED] likes this.
  6. Aug 19, 2024 at 8:36 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    What bike? How old?
    Maybe find a basket case with killed top end, but good case
    Jakerou and bigmw[OP] like this.
  7. Aug 19, 2024 at 8:39 PM
    bigmw
    I think it is 2010 klx 250 f
    New case is the next step, but hoping to get this going before it comes to that
    Pablo8 likes this.
  8. Aug 19, 2024 at 9:14 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Go back to the oversize bolt but don't use JB weld, degrease WELL and use red locktite on the threads and let it set.
  9. Aug 20, 2024 at 10:31 AM
    bigmw
    Repair number 2 (ecoplug with jb) is done, and looks like it might hold. Will be testing it later on today.
    If it breaks, I might try your idea before going with a new case
