Oil pan gasket or no?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hennessy3300, Jul 21, 2025 at 12:13 PM.
  1. Jul 21, 2025 at 12:13 PM
    hennessy3300
    hennessy3300 [OP] Well-Known Member
    I need to replace the rusted and leaking oil pan on my 2005 V6. Do I need to use a gasket or just a silicone like hondabond? Most of the youtube videos show just a sealant but rockauto has gaskets. Thanks
  2. Jul 21, 2025 at 12:46 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    How good are you at making RTV gaskets? I feel like premade ones exist for people who might not get a continuous bead of coverage.
    Factory uses RTV typically since its cheaper and there is a robot that can apply it perfectly.
    In the past I've used both a gasket and RTV (on a diff cover, different vehicle) and it held up fine.
  3. Jul 21, 2025 at 12:52 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
  4. Jul 21, 2025 at 12:53 PM
    hennessy3300
    I've used RTV plenty of times. I may use both for piece of mind. Also it looks like there are 10 bolts an 2 studs with nuts holding the pan on. The nuts on the studs are almost completely rusted off. Does anyone know what that part number or size those nuts and studs are? I cant find any online.
  5. Jul 21, 2025 at 1:04 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Just do what the manufacturer did at the factory
    Silicone sealant in between 2 dry, clean and flat surfaces is about as good a seal as you'll get
    Rockauto sells whatever people will buy, doesn't necessarily mean thats the correct part for the repair
