Oil Pan Leak Help & Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jjew18, Dec 28, 2012.
  1. Dec 29, 2012 at 1:38 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    80 in/lbs or 7 ft/lbs for reference.
    Careful on the RTV too. You don't want it "pillowing" out into the sump.
    Run a very thin bead down the center and around the bolt holes and bolt it up.
    Inspect carefully, and if you see any RTV being squeezed out, it is likely being squeezed out on the inside as well. Remove the pan and start over.
  2. Dec 30, 2012 at 12:35 PM
    jjew18
    jjew18 [OP] the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Thanks for everyones help, about to get under way, but one more question.
    After I get the pan off and clean it really well, how long should I wait to reapply the pan? Does the pan need to sit overnight to assure no simple green is still present, or a thorough wipe down with a dry clean shop towel, then set it and forget it?
    I know any oil will disrupt the bond/adhesiveness of the seal, but I wasn't sure about the cleaner.
  3. Dec 30, 2012 at 3:35 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Just make sure the degreaser is completely rinsed off.
  4. Dec 30, 2012 at 4:44 PM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    So when you say rinse, is it okay to introduce water to the pan as long as it is dry?
  5. Dec 30, 2012 at 4:47 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Yes that's fine..
    I use brake clean/parts wash in the spray can..it evaporates very quickly
  6. Dec 31, 2012 at 7:38 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Okay, so it appears my repair was successful, however it also appears Rich was right. Oil is leaking from underneath the black cap on this picture. It is on the engine but it is right where the engine is connected to the tranny. This is where I will hang up my mechanics gloves and let someone who really knows what they are doing take over. Before doing that, any thoughts so I don't get taken to the cleaners? Is this something I should keep in eye on?
    Things to know:
    1. Although it appeared progressive at first, it is a slow leak.
    2. Truck seems to be driving fine.
    3. When removing the black cap, it is pretty clean as far as I can see, however after sitting you will a while you can see a drip.
    [​IMG][/url] [/IMG]
    I'll try and get better pics.
  7. Dec 31, 2012 at 8:28 AM
    MonkeyProof
    SoCal- SGV
    That will most likely be the rear main seal. And if it is the rear main seal it is a big job involving removing the transmission from the motor.
  8. Dec 31, 2012 at 8:29 AM
    MonkeyProof
    SoCal- SGV
    I would recommend taking it to a dealer and have a tech inspect it and find out what the other leak may actually be..
  9. Dec 31, 2012 at 9:47 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Okay, that's what I figured.
  10. Dec 31, 2012 at 10:15 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Would you recommend trying a stop leak treatment first, since it is a seemingly minor leak?
  11. Dec 31, 2012 at 11:53 AM
    BamaToy1997
    Bill
    Navarre, FL
    Question, did you clean all of this very well after doing the repair, and it started showing signs of leaking again? Just being sure because a leak can blow backwards and make something else look like it was leaking. If it is oil, and coming from that area, then yeas, you are most likely looking at a rear main seal. As mentioned, take it to a qualified shop and have them check it out. Good luck.
  12. Dec 31, 2012 at 12:39 PM
    MonkeyProof
    SoCal- SGV
    Never
    X2..
    This is why I recommend in taking your taco to a qualified tech
  13. Dec 31, 2012 at 1:27 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Nevernevernevernever....
    Radiator or crankcase.... never.
    Oil in the crankcase
    Coolant in the radiator
    Fuel in the fuel tank
    Anything else will do more harm than good.
  14. Dec 31, 2012 at 1:47 PM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Unless you're Krazie!
    Okay good, I was reluctant to try it. To the dealership.
  15. Dec 31, 2012 at 1:49 PM
    #35
    MonkeyProof
    SoCal- SGV
