Oil Pan Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pster, Feb 1, 2009.
  1. Feb 1, 2009 at 2:35 PM
    Pster
    Pster [OP] Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    I am going to install a Fumoto oil drain valve. The only thing I have not been able to get comfortable with is whether ALL the oil be drained when using this. The 12mm male threaded part is only 7/8" long, so it shouldn't protrude too far into the pan. Does anyone know what the inside of the Tacoma oil pan looks like so I can find out if all the oil will drain? I have heard that some have internal ramps or depressed areas around the drain to aid in letting all the oiul drain out, but since they were designed to have the drain hold totally open, I'm just not sure. Or has anyone used a Fumoto and then taken it off to check to see if any material oil remained?
  2. Feb 2, 2009 at 7:39 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  3. Feb 2, 2009 at 9:26 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    You never get ALL the used oil out, anyway. It isn't a problem.
  4. Feb 2, 2009 at 9:41 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Thanks Janster, I had actually read those posts on ToyoNation.....found the tailgate theft fis there as well: Turn Key Clamp (Mfg: Ideal) with rubber liner.
