oil pan
Discussion in '4 Cylinder' started by toyotadan98, Feb 26, 2011.
  1. Feb 26, 2011 at 11:22 AM
    toyotadan98
    toyotadan98 [OP] Well-Known Member
    wa
    2011 TRD OFFROAD 4X4 ACC
    I have a 98 2.7 4x4.will the oil pan come out without taking front diff out? its leaking and want to know if i can do this easily or not. Thx,Dan
  2. Feb 26, 2011 at 11:34 AM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    I'd suggest getting the Haynes or Chiltons manual. Everything I've hear though is that you have to remove it.
  3. Feb 26, 2011 at 12:24 PM
    toyotadan98
    wa
    i HAVE A 98 4X4 EXT CAB 2.7. My oil pan leaks. how hard is it to replace?
  4. Feb 26, 2011 at 1:25 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Where does it leak?
    If its anything like the 3.4L.... check the oil pan bolts to make sure they're tight. Aside from that....you might have to remove the pan, clean off the old sealant, apply new sealant and put the pan back on.
    Or do you have hole in it?
    Definately get a haynes, chiltons, www.ncttora.com, or www.google.com
  5. Feb 26, 2011 at 3:23 PM
    Janster
    Jandy
    Lancaster, PA
    Double post?
  6. Mar 8, 2011 at 5:04 PM
    Scott 96tacoma
    Scott 96tacoma Member
    Toms River N.J
    96 Tacoma
    Yes the frnt diff must come out, i changed my oil pan last winter. It is not really a bad job. Took me about 4 hours in my house garage on the floor.I got the pan and toyotas pan sealant from my local toyota dealer.
  7. Mar 9, 2011 at 6:32 AM
    toyotadan98
    wa
    thanks for the info.i thought it did have to come out.
  8. Mar 9, 2011 at 7:34 AM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Its most likely easy. Be glad its not 94 F150 ;) To replace oil pan gasket on that thing, you HAVE to pull the transmission :rolleyes::rolleyes:
  9. Mar 9, 2011 at 3:24 PM
    frog13
    frog13 Well-Known Member
    Damn Ford did it to their- selves...and the rest of them(US).
