Oil Plug Bolt Stripped Advice 1GRFE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tactus, Apr 7, 2022.
  1. Apr 7, 2022 at 7:03 AM
    Tactus
    Tactus [OP] New Member
    Hi guys, I changed the oil on the truck the other day as I have done countless times in the four years I have owned it, but it now has a leak. I think the threads are stripped. Its a 2014 V6 4x4 so to change the pan the diff needs to be removed and the dealership wants an ungodly amount. I'm considering just retapping the threads but wanted to hear if anyone had any other advice.
    Happy Trails
    -Red
    Gunshot-6A likes this.
  2. Apr 7, 2022 at 7:06 AM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    Oil change place stripped the drain plug on my buddies 98 Cherokee. It has had a rubber plug in it for yrs. The Jeep leaks oil, but not through the plug.
  3. Apr 7, 2022 at 7:10 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    retap it or maybe just throw some replaceable teflon tape on it.
    Frito and whatstcp like this.
  4. Apr 7, 2022 at 7:11 AM
    Beerline123
    Beerline123 Well-Known Member
    07 Tacoma access 4x4
    I believe lower oil pan just comes right out without removing anything unlike the upper pan which involves diff and cv
    SR-71A likes this.
  5. Apr 7, 2022 at 7:12 AM
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    Make sure it’s not just double washered
  6. Apr 7, 2022 at 7:12 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    OP did you replace the crush washer? Are you sure its stripped?
    If not get a new crush washer, pull the oil fill cap on the top of the motor and hook a shop vac up to it, turn it on and this will allow you to pull the drain plug to replace the crush washer without loosing oil.
    Also i belive the lower metal pan (black) is removable without having to touch the front diff
  7. Apr 7, 2022 at 7:13 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Does it tighten up? Have you ever replaced the washer? Install a Fumoto or the like with some thread sealant and never worry about the threads again?
    Frito and 10thMTNgrunt like this.
  8. Apr 7, 2022 at 7:16 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    Use thread sealant/teflon tape to install a fumoto valve. Problem solved.
    Frito and daytrader2 like this.
  9. Apr 7, 2022 at 7:20 AM
    pmstoy10
    pmstoy10 Well-Known Member
    hudson valley, ny
    2010 Tacoma DCLB TRD Sport
    Weathertech Floor Liners, UWS Toolbox, Seatbelt Chime Mod, Coverking Covers, Window Guards, Wheeler's 1.5" Single Leaf AAL, Rear Spring TSB, Front Bilstein 5100's @ 2.5", Rear Extended Travel Bilstein 5100's, removed front mud flaps, Lifetime LED Headlights, Firestone RideRite Air Bags with Daystar Cradles, Light Racing UCA's, ECGS Front Diff Bushing
    Check for extra crush washer, re-tap, and replace with fumoto valve. Never need touch the threads again. Mines been on for 180k.
  10. Apr 7, 2022 at 7:45 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Plug is M12x1.25 thread and lists 27 ft-lbs torque. All the local auto stores have Dorman plugs in stock.
    Toyota OEM oil drain plug #90341-12012 (old# 12026) about $4 with 14mm head. Washer/Gasket #900430-12031 under $1
    Fool may have used power or air wrench and crossthreaded not starting it by hand and who knows shop settings on air.
    I would try replacing the plug and gasket as first step. You can look at the pan threads at that time. If you reuse the oil watch for metal threads in it.
    eherlihy likes this.
  11. Apr 7, 2022 at 10:14 AM
    Gregthespy
    Gregthespy Well-Known Member
    Greg
    Orlando
    2015 Blue Ribbon Metallic TRD Sport 4X4
    This was my solution on my wife’s Camry, I tried retapping it and was slightly crooked, so a fumoto valve went in with double washers. No regrets and 200k on it (did this around 80k)
  12. Apr 7, 2022 at 11:05 AM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    Pretty sure you don't need to remove the front diff to change the pan out. There is the upper pan that does need the diff removed to change that out, but the lower steel pan is where the drain bolt is located which you just need to remove the skid plate to access. You can also get a new pan for around $20 and a new gasket for a few more dollars. I don't like the idea of a fomoto valve because I have the fear that some idiot will be evil and open the valve while I'm out somewhere.
    1owner05, whatstcp and Key-Rei like this.
  13. Apr 7, 2022 at 6:11 PM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    You do not need to remove the diff to replace the LOWER oil pan, which is where the oil drain plug is located. If a shop told you that run away fast and far from that shop
    daytrader2, Jeff Lange and nats like this.
  14. Apr 7, 2022 at 6:28 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    Reading your post verbatim I think it's prudent to first ask for clarification on why you think the threads are stripped? Is the drain bolt spinning freely and unable to be torqued enough to compress the crush washer and form a seal? Otherwise, if the bolt is able to be torqued then your leak has nothing to do with the threads and instead is related to an issue with the crush washer and/or its mating surface areas where the actual seal is formed.
  15. Apr 7, 2022 at 6:40 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    daytrader2 likes this.
  16. Apr 7, 2022 at 11:21 PM
    TacoTuesday1
    SD CA
    I doubt the diff needs to come out to remove lower oil pan
  17. Apr 7, 2022 at 11:55 PM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    There's a new Fumoto valve available with an adjustable valve body. I just installed one on my 3rd Gen. What is different that would be of benefit in this case is it threads in but seal via o-ring against the surface of the oil pan immediately surrounding the drain plug. If you can cinch it up, you're golden.
    The photos on Amazon are not well representing of the new feature in that they don't show the side that houses the o-ring that mates with the pan.
    F103SX: New Generation Fumoto Valve with 12mm-1.25 Thread Size https://www.amazon.com/dp/B01HP5UZIO?_encoding=UTF8
  18. Apr 8, 2022 at 12:50 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Unless it’s stripped stripped, some rtv on the threads will most likely make it stop leaking. Fumoto is an interesting idea in this situation.
  19. Apr 8, 2022 at 7:12 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    GilbertOz and Torspd like this.
  20. Apr 8, 2022 at 7:13 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    WOODY2 likes this.
