Oil Plug gasket
Discussion in '4 Cylinder' started by The Shape, Oct 18, 2010.
  1. Oct 18, 2010 at 5:47 PM
    The Shape
    The Shape [OP] Well-Known Member
    Forrest City, AR
    '09 Access Cab A/T 4banger
    I saw someone in another thread metion changing this out each time you change the oil. Is that really neccesary? I had an '87 mustang with 145K on the same oil plug washer.
  2. Oct 18, 2010 at 5:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Thye say it should be changed. BUT...Im on change number 5 useing the same plug, with no leaks.
  3. Oct 18, 2010 at 6:10 PM
    The Shape
    Forrest City, AR
    I guess you have to get them through the dealer?
  4. Oct 18, 2010 at 6:12 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    i have changed mine out once just was leaking a really small amount took the old one off ran up to autozone with a different vehicle and got a new one
  5. Oct 18, 2010 at 6:17 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    :notsure:
    I replace mine on every oil change. Last time at the dealer I bought 5 filters and 5 washers.
  6. Oct 18, 2010 at 6:29 PM
    BCH
    BCH Shiester
    Lafayette Ga
    SR5 4x4 4cyl
    Viper, ARE Camper
    I have changed my oil every 3000 miles on my truck. I have 99700 miles on it and I have never changed the gasket at all. Never changed it on any vehicle I have ever owned. Its not necessary in my opinion unless you notice it leaking.
  7. Oct 18, 2010 at 6:32 PM
    The Shape
    Forrest City, AR
    On a sperate note, is there a certain site you guys recommend for ordering toyota oil filters from online?
  8. Oct 18, 2010 at 8:38 PM
    motoretro
    motoretro Well-Known Member
    Michigan
    09 Reg, Cab, 2.7 Four Cyl. manual trans
    I replace it every O.C.
    I figure the Drain Plug torque specification takes into consideration the compressibility of a new sealing ring. Aluminum work hardens so It's my guess you're probably over torquing things a bit by using the same sealing ring over & over. JMO
    Motoretro
  9. Oct 18, 2010 at 8:47 PM
    Johnnie
    Johnnie Well-Known Member
    I.E. SoCal
    Feds
    You can always put a little silicone around the plug just in case.
  10. Oct 18, 2010 at 8:53 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    The gasket never came off one change & figured out finally it was stuck to the bottom of the pan, actually there were two on there :eek: oopsie.
    Now just one.
  11. Oct 18, 2010 at 9:20 PM
    The Shape
    Forrest City, AR
    I am not sure I have ever looked up the torque specs on a drain plug:notsure:. I can't imagine breaking out the 'ol torque wrench for a oil change.
  12. Oct 19, 2010 at 7:21 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    IIRC, The drain plug is torqued to 30 ft-lbs.
  13. Oct 19, 2010 at 7:34 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You should ALWAYS torque your drain plug!!! My right arm is perfectly calibrated for such things as this...:D
  14. Oct 19, 2010 at 2:37 PM
    The Shape
    Forrest City, AR
    I am going to trust that mine is as well LOL:D
  15. Oct 19, 2010 at 2:58 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    x2 lol.
    Oh and im on the same gasket since I've had the truck (5 oil changes)
  16. Oct 19, 2010 at 4:11 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Usually change the washer every 4 or 5th oil change
  17. Oct 19, 2010 at 4:19 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    im on my i think 10th oil change with the same one and its just now starting to leak a bit ill put a new one on for the next O.C.
  18. Oct 19, 2010 at 4:25 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I torque everything I can't tell you how many bolts I broke over torquing.
  19. Oct 19, 2010 at 5:26 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    you would probably need a 1/2" drive breaker bar to accidentally snap the drain plug. That thing is pretty big.
    I just use a small ratchet and snug it up, never had a problem.
  20. Oct 20, 2010 at 7:55 AM
    JLee
    Jerry
    Grass valley CA
    Oh yeah I know I have however striped out a drain plug over torquing.
