Oil plug leak after I changed oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AME219, Dec 5, 2019.
  1. Dec 5, 2019 at 9:31 AM
    AME219
    AME219 [OP] Member
    Aaron
    2010 Tacoma 2.7 L 5 Spd 4x4 Access Cab
    I changed the oil in my Tacoma for the first time myself (haven't had it long). Also my first time changing oil. I tried to buy Toyota oil plug washers from the dealer but they were closed so I picked up some off brand ones from advance Auto. When reinstalling the plug, the old washer was pretty stuck to the pan and I had to use a flathead screwdriver to scrape it off. After performing the oil change, all seemed well until the next day when I noticed a few drips of oil on the driveway, I got under the truck and the plug was leaking. I tried to tighten a bit more (just barely snugged it before) and wiped it and drove a while and seemed to fix it, but now it is still barely seeping oil, maybe a drop or two per day. I feel like it may be the washer I used as it is a plain flat aluminum washer, unlike the felt material one that was on there before (no oil leaked before) I was also very careful not to overtighten, and don't wanna tighten it any more so I don't strip it. Is there any way to change the washer without draining all of the new oil out (it's expensive synthetic) or is there anything else I should try?
  2. Dec 5, 2019 at 9:34 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    The problem is most likely the gasket. You could just live with the leak until the next change or buy a new clean drain pan to drain the new oil into so you can reuse it.
    scottalot and Clearwater Bill like this.
  3. Dec 5, 2019 at 9:56 AM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    Or you can get a new OEM gasket, get a friend over...quickly unscrew the plug and block the hole with your thumb. Have your helper swap the gasket and pass back to you. Screw it in quickly and your done. Might cost you half a quart max...will get your hands dirty though. :eek:
    RTX Taco, Marc70, robssol and 3 others like this.
  4. Dec 5, 2019 at 9:59 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    The dorman gaskets from advance are bigger inner diameter than the toyota gaskets. You have to line them up perfect for it to work. You can probably loosen the bolt slightly and make sure the outer diameter it flush w/ the bolt and tighten.
    SR-71A likes this.
  5. Dec 5, 2019 at 10:50 AM
    AME219
    AME219 [OP] Member
    Aaron
    The gasket I used was a dorman. Thanks for the tip, it looked centered but I just looked at it again and it felt slightly not flush with the plug on one side. I just tried loosening the plug and trying to recenter the washer as best I could and re tightening, so I'll see if that works.
  6. Dec 5, 2019 at 10:53 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Just for clarity:
    The oil plug uses a copper crush washer.
    It is not felt.
    If one replaces the crush washer with a flat aluminum washer, you’re not achieving the proper seal or torque.
    One must be careful when torquing the plug with the crush washer- typically you can feel it actually crush and that’s enough, maybe a bit more snug and that’s all that’s needed.
    You can strip the threads over torquing.
  7. Dec 5, 2019 at 11:06 AM
    Muddinfun
    Muddinfun Well-Known Member
    The ones that the local Toyota dealer throws in the filter box for me are a black gasket material type stuff.
    Jimmyh, SR-71A and JC15Taco like this.
  8. Dec 5, 2019 at 11:14 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    OP could of gouged the pan when he scraped off the old one.
    FYI, if you stick a shop vac on the oil filler at the top of the motor, you can remove the drain plug without loosing any oil if you want to replace the drain plug gasket.
  9. Dec 5, 2019 at 11:22 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    robssol likes this.
  10. Dec 5, 2019 at 11:22 AM
    JC15Taco
    Jeff
    SK, Canada
    '15 TRD DCLB
    Heard of that...just never had the pills to try it.
  11. Dec 5, 2019 at 11:24 AM
    Muddinfun
    Personally, I think that’s right up there with unlocking a car with a tennis ball.
  12. Dec 5, 2019 at 11:25 AM
    nd4spdbh
    SoCal
    that is BS.
    This though, pull a vacuum on the crank case, and you wont loose oil, physics.
    12TRDTacoma likes this.
  13. Dec 5, 2019 at 11:32 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    Just order a Fumoto drain valve and never have to worry about the washers again.
    mac84, Blockhead and verynearlypure like this.
  14. Dec 5, 2019 at 11:44 AM
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    After 19 oil changes, my trucklet still has the original copper crush washers.... and still doesn't leak a drop.
    I have a small supply of new ones but haven't needed them yet.
  15. Dec 5, 2019 at 11:46 AM
    Muddinfun
    But... Here's my problem with that. There's a big crankcase ventilation hose connecting the crankcase to the air box, which, in theory should make it impossible to pull a vacuum.
  16. Dec 5, 2019 at 11:50 AM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Bridgestone Dueler A/T Revo 3 265/50, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    +1
    All my vehicles have been using Fumoto valves for years.
    verynearlypure likes this.
  17. Dec 5, 2019 at 12:52 PM
    EnonEye
    EnonEye Well-Known Member
    David
    O-H-I-O
    Silver '06 DCSB TRDPreRunner Off-Road/ Tow package
    works... been there, done that, works great just use at your own peril as in don't switch the shop vac to "blow" :crapstorm:
  18. Dec 5, 2019 at 12:53 PM
    nd4spdbh
    SoCal
    The volume of air pulled by the shop vac is greater than what the drainplug hole and crank case vent can supply so vacuum is still achieved.
    PzTank and Rob MacRuger like this.
  19. Dec 5, 2019 at 1:13 PM
    Muddinfun
    OK, since it's been done by someone on TW, I'll believe it. Sorry for the scepticism.
  20. Dec 5, 2019 at 1:13 PM
    JC15Taco
    Jeff
    SK, Canada
    '15 TRD DCLB
    Have no doubt about the physics at all....just that even remotely combustible gases in a shop vac can bite a fella.
    Just never bothered to test it.
