Oil plug leak after I changed oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AME219, Dec 5, 2019.
  1. Dec 5, 2019 at 7:47 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  2. Dec 5, 2019 at 8:01 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    The wife's 2010 Highlander still has the original factory copper washer and no leaks. This is not a gasket or a crush washer. My 2012 Tacoma has a Fumoto valve since my third oil change so...
  3. Dec 5, 2019 at 8:02 PM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
  4. Dec 5, 2019 at 11:55 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I have been using those cheap light blue plastic washers on all my vehicles since the 1980's, and never had a leak at the drain plug. They'll last 40k+ but I replace with a new one every three to four oil changes (about 35K). I bought a bag of 40 about 15 years ago for less than $10, if I recall correctly, and have about quarter bag left. About 50K ago, started using an EZ valve on the Taco; it has an O-ring and it hasn't leaked yet. I had a Fumoto on wife's Lexus for a time and used the plastic washer over the Fumoto washer because it was thicker and oriented the valve right where I wanted it. I no longer advocate a Fumoto or EZ valve on a sedan because it sticks out too much, but we can discuss that on another thread.
  5. Dec 6, 2019 at 12:14 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I have had EXCELLENT results using Nissans copper crush washers on all oil changes I do on Toyota vehicles. To this day it is the only Nissan product I will ever touch and endorse for usage on another vehicle.
  6. Dec 6, 2019 at 12:39 AM
    Gritto
    Gritto Mrs Gritto's First Husband
    Nowhere Else, Pottsylvania
    2006 AC AT V6 PreRunner
    Stock. SR5 Package #2.
    I'm 64 and have always done oil changes on my vehicles myself.
    That's a lot of oil changes.
    Never replaced an oil plug washer...and never worried about it...
    ...until now. :rolleyes:
    knottyrope, robssol and Gerard6778 like this.
  7. Dec 6, 2019 at 12:56 AM
    Gerard6778
    Gerard6778 Well-Known Member
    Gerard
    2015 TRD Sport
    I've done many oil changes over the last 30 years, on the many different vehicles I have owned, and likewise never replaced an oil plug washer. I've never had one leak.
    Gritto[QUOTED] likes this.
  8. Dec 6, 2019 at 2:05 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    Drain it, remove washer, check for damage, install new washer, torque, wipe. Put the same oil back in.
    AME219[OP] likes this.
  9. Dec 6, 2019 at 2:15 AM
    jtaco11
    jtaco11 Well-Known Member
    Yup thats the way to go put mine on after 1st 5k oil change no leaks whatsoever at 177k now. If you change oil often or have the shop newbie techs do it good chance will strip plug eventually after numerous oil changes.
  10. Dec 6, 2019 at 3:08 AM
    wags
    wags Well-Known Member
    Walleye Capital of the World, Ohio
    2012 2.7L 5-Speed Manual SR5 4x4
    This! I use the copper Toyota OEM drain plug washers also (after each oil change throwing away previous one). Torque drain plug to 28 ft lbs. My guess OP is inferior washer from Advance Auto Parts, to possibly cross threaded drain plug to not properly torqued. If I had to roll the dice it's the drain plug washer. It's up to you when and how you want to change it.
    NAAC3TACO[QUOTED] likes this.
  11. Dec 6, 2019 at 5:30 AM
    seedy_tea
    seedy_tea Well-Known Member
    chris
    Cape Cod
    2009 TRD-OR DC
    how does one unlock a car with a tennis ball?
  12. Dec 6, 2019 at 7:26 AM
    Muddinfun
    Muddinfun Well-Known Member
    There is a youtube video where they poke a hole in a tennis ball, position the hole over the door lock, smack the tennis ball with the palm of their hand, and the car unlocks. The claim is that the air pressure into the lock, unlocks it. There is no way, no how. It’s fake.
    Jimmyh and seedy_tea[QUOTED] like this.
  13. Dec 6, 2019 at 7:44 AM
    seedy_tea
    chris
    Cape Cod
    2009 TRD-OR DC
    ah ok thanks. wasnt sure if there was an "actual method" or if you were just making it up.
  14. Dec 6, 2019 at 7:51 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    I have used a few wraps of folded teflon tape at the head of the bolt for as long as I can remember with no leaks ever. :crapstorm:
    Just be sure the tape doesn't accumulate and get into the pan.
  15. Dec 6, 2019 at 8:10 AM
    #35
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    Lol for future reference just keep using the original crush washer until you notice it starts dripping. I’ve never replaced a single crush washer on any vehicle I’ve owned. I’ve been doing oil changes for 15 years. Is that the technically proper thing to do, no. But it’s never failed me so I’m not changing it lol
    Gerard6778 and Gritto like this.
  16. Dec 6, 2019 at 8:16 AM
    #36
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Wondering if putting a fumoto oil drain valve would solve all the failed or misaligned washer concerns. One change over and you don't have to worry anymore about leaks. Makes it an easy DYI on the weekend and or when you have your next oil change....Lots of videos on them - check them out.
  17. Dec 6, 2019 at 9:29 AM
    #37
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    Agreed.... I have been doing the same for 55 years with the same result. If it ain't broke, don't fix it. :)
  18. Dec 6, 2019 at 11:38 AM
    #38
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Done this a few times for people
    grab a shop vac, remove oil fill cap and put vac hose on oil filler neck and turn it on vac
    unscrew drain plug and remove washer from plug
    put on new washer and install drain plug
    turn off vac and put oil cap back on
    look, no mess
    Muddinfun likes this.
  19. Dec 6, 2019 at 12:53 PM
    #39
    junkyardyote
    junkyardyote Well-Known Member
    2010 4x4 sr5 4.0 crew cab/ 2023 TRD Offroad DCLB 3.5 auto
    Please not the stupid fumoto thing...F#@#
  20. Dec 6, 2019 at 1:11 PM
    #40
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You guys must also be the same kind of people who run their spark plugs into the 200,000 mile interval before ever even considering touching them as well.
    knottyrope likes this.
