Oil plug stripped
Discussion in '1st Gen. Tacomas (1995-2004)' started by Archaic2021, Dec 17, 2021.
  1. Dec 17, 2021 at 8:28 AM
    Archaic2021
    Archaic2021 [OP] Well-Known Member
    So I usually am a DIY guy.
    I've done the last 3 oil changes on my truck, took it too our quick lane and now the plug is just spinning and wont' come out.
    tried to put a screwdiver behind it to put a very small amount of tension on it but it did not catch. Didn't wanna do to much since I would be stick 40 miles from home.
    Should I go ahead and plan to put a pan on...being a 99 4wd how hard is it...will I need to drop the front diff?
  2. Dec 17, 2021 at 8:37 AM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    I wouldn’t put a new pan on it. I’d do a thread repair on the existing pan
    JudoJohn likes this.
  3. Dec 17, 2021 at 8:40 AM
    Archaic2021
    can you do that on these pans? It's seaping pretty good anyways but it seems like a not so easy job
  4. Dec 17, 2021 at 9:08 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Hopefully you can get some vice grips on there and give it some tension as you're twisting it.
    Then maybe drill and tap to a larger size.
    And never go to one of those oil monkey shops again.
  5. Dec 17, 2021 at 9:17 AM
    OpeCity
    Long Beach, CA
    I don’t see why you cant. It’s a pan like any other
  6. Dec 17, 2021 at 9:30 AM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    iffy lube strikes again
    Gl op
    Bivouac likes this.
  7. Dec 17, 2021 at 10:13 AM
    Archaic2021
    Well the bad thing THIS IS OUR QUICK LANE AT THE FORD STORE I WORK AT.
    It looks like the washer is just crushed...i'm wondering if I can get it home and slowly easy it out...although I'm not counting on.
    Already have a pan, gasket on order and will be here in the morning just in case.
    I'm wondering does the front diff have to come all the way out or can it just be dropped a little.
  8. Dec 17, 2021 at 11:00 AM
    Archaic2021
  9. Dec 17, 2021 at 11:26 AM
    jbrandt
    Justin
    *probably* but at that point you may as well just drop it entirely and give yourself more room to work. Plus, with the diff still in the way I think you would have a hard time reaching in to clean the gasket surface.
    Last time I did my timing belt I spent like 2+ hours fiddling around trying NOT to take the radiator out. Removing the radiator is a 10 minute job...
    NSDON and Bivouac like this.
  10. Dec 17, 2021 at 1:21 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    My question is why isn't the 'quick lane' place fixing this instead of you?
    Superdave1.0, Murd3rd, Travlr and 2 others like this.
  11. Dec 17, 2021 at 1:45 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    This is a very good question?
    At least cover the parts I would think.
    I know myself the pan needs to come off there is no way I would attempt any repair on the truck.
    It depends just how far the pan needs dropped to clear the oil pick up tube it is possible to drop the pan enough to remove the pick up tube but it is a royal pain getting it back on with my big hands.
  12. Dec 17, 2021 at 1:52 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Yah. I’m sure their quality on fixing their fuck ups are at least as good as the fuck up itself. Better settle for a “premium air filter” freebie.
    Jase likes this.
  13. Dec 17, 2021 at 2:03 PM
    Archaic2021
    This is what the Service Manager and I are arguing about now. This is the first time they have done a oil change...I have done all the rest. There saying I overtightend and stripped it.
    Ive been working on vehicles since I could walk.
    I'm almost saying the when right instead of left the way the washer and the little seal looks crushed. I'm going tonight and HOPEFULLY I can ease it back out with some pressure but I'm not counting on it.
  14. Dec 17, 2021 at 2:26 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    1995 2.7 4x4 - I was doing oil change at the same Toyota dealer for more than 10 years and they finally stripped the plug. They asked me for 900 dollars to replace the pan (which was about 140 dollars) so close to 750 dollars in labor. Based on what I see and info in FSM it is not a quick job, and the front diff must be dropped. I did not give them any money, and told them - you broke it you fix it (they had all oil change records). They did thread insert fix (not helicoil, just some threaded insert), and they told me it's good as new. I told them, that's good because I will be still coming to them for the oil change so we will see how long it will last. It did not last long - on the forth oil change they pulled the insert out and now the pan was FUBAR. They took the truck for oil pan replace and eat the cost including rental.
    When I got the new oil pan, I never left my truck for the oil change to anyone since then. I saw, it is a common practice to use impact wrench to take out the plug and quite often to put it back in. In my opinion impact wrenches will damage thread if the plug is stuck for example. Impact wrench will apply tremendous torque and it will take the whole thread out no questions asked. I'd rather use a long bar for the wrench and feel what's going on instead blindly hammering the plug till something gives.
    ULURU, treyus30, Squirt and 1 other person like this.
  15. Dec 17, 2021 at 2:32 PM
    Archaic2021
  16. Dec 17, 2021 at 2:45 PM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    Sounds like it’s time to rage quit that place. Haha
  17. Dec 17, 2021 at 2:58 PM
    tonykarter
    tonykarter Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
    The guy working in the pit at these places isn't there because he's their smartest employee.
  18. Dec 17, 2021 at 3:10 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    If that's their smartest guy, the rest of his crew must be waddling around with their knuckles dragging on the floor.
    MalinoisDad likes this.
  19. Dec 17, 2021 at 3:25 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Idiots. Don’t forget it’s nicely lubed too….
    I’ve changed my own oil for decades. With the Tacoma, I splurge on a new crush washer every time and use a stubby wrench. I stop torquing when the washer crushes- never had an issue.
    NSDON likes this.
  20. Dec 17, 2021 at 4:12 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Never understood risking over-torquing an oil pan bolt. Worst case of undertightening, it falls out and you loose all oil but you'd notice and just put new oil in. Worst case is this - $750 repair on broken oil pan. All to save 5 seconds.
    NSDON likes this.
