Oil Pressure at Extreme Angles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by A7XTaco, Apr 7, 2011.
  1. Apr 7, 2011 at 9:53 PM
    A7XTaco
    A7XTaco [OP] Member
    Bryan
    Austin, TX
    You don't want to know...
    So, does anyone know at what angles the v6 can safely run at before the engines starts being starved of oil?
  2. Apr 8, 2011 at 3:38 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I'm going to take a leap here and make the assumption that it should be fine at any angle that your truck won't roll on.
  3. Apr 8, 2011 at 3:49 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Agreed, since the oil system is pressurized and not dependent on gravity, you would be fine at any angle, even upside down... not that that is safe, lol.
  4. Apr 8, 2011 at 3:57 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Hmmm, dunno bout all this. Isn't there still a pickup in the pan like most others? I'd be wary of any prolonged crazy angles front to back that might starve it but that much of an angle from side to side would have the truck flopped on it's side before the starvation occurs. That being said, haven't seen any postings about anything bad happening like that.
  5. Apr 8, 2011 at 4:02 AM
    StandingCow
    NJ
    I think the fuel would cut off from not having fuel to the fuel pump before the oil would run out of the system... you still have everything in the oil filter and all.
  6. Apr 8, 2011 at 4:04 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Agreed, depending on how much was in the tank..........
  7. Apr 8, 2011 at 4:38 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I went down and up Hell's Gate in Moab without an oil pressure light coming on. I'd expect that's about as steep and long as one would go. I had to ride the clutch in 4low to keep from killing it.
    I can't imagine getting much steeper than that for any extended period of time.
    I do wonder however about the auto trannys...
  8. Apr 8, 2011 at 4:44 AM
    Manwithoutaplan
    ID
    Interesting topic wouldnt think about the oil level when wheeling... good to know though.
  9. Apr 8, 2011 at 6:53 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    Slightly off topic, but X-runners have been known to spin a bearing, when doing a little drifting.
    I have made this deep sump baffled oil pan. I have been running it about two weeks.
    I also repositioned the drain plug. The stock oil drain, is not in the low spot in the pan.
    This adds about 1.25 quarts to the capacity.
    oilpan016_76a93e6f7ce0540cbc5ba56aa7b5183d010b40e5.jpgoilpan006-1_b86a4831cd0b1aa16920aded102508fc302d7708.jpgoilpan007-1_9523ad9bece13c15bfed9cb72681c1fabef9bdac.jpg
    oilpan005-1_fef5a5ae902f49b08a3e2efbaae1685c35576055.jpgoilpan004-1_1eccf50c93d1b873feb2d3c92a00af96f9826fa8.jpg
  10. Apr 8, 2011 at 6:57 PM
    A7XTaco
    A7XTaco [OP] Member
    Bryan
    Austin, TX
    That's a good idea^^^
    It also kinda scares me. Is the oil pan the same on between the x-runner and Off-Road?
    I would think you would be able to simulate the same thing at sharp angles as drifting.
  11. Apr 8, 2011 at 6:59 PM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    The oil pan on the 4 x 4 is a deeper than an X-Runner.
  12. Apr 9, 2011 at 6:51 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Nice fab work there neighbor.......Same stuff is known problem for my Mazda P5, it corners so good it starves itself into same problem...that and the oem fill only = 3.7 qts including the filter. I don't autox and it's fr wheel drive so no drifting either. I use a v6 626 filter that gives it little over 4 qt capacity even tho I'm not doing the fun stuff in it.
    Could Xrunners use a 4x4 pan & pickup to avoid this or is there fit issues?
  13. Apr 9, 2011 at 10:20 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Nooo...not upside down. :D You'll get oil in the cylinders and that'll be just as bad as water in the cylinders (hydrolock).
    Had to mention that.....:p
  14. Apr 9, 2011 at 11:55 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    Run amsoil zero thirty and forget the rest
  15. Apr 9, 2011 at 1:45 PM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    That I do not know. I know the lower pan will not bolt on. If you replaced both pieces (uppper & lower pan) with the pick up tube, maybe.
