Oil Pressure Gauge on a 1st Gen?
Discussion in '1st Gen. Tacomas (1995-2004)' started by steve o 77, Jan 15, 2010.
  1. Jan 15, 2010 at 11:04 AM
    steve o 77
    steve o 77 [OP] braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Well I searched and found nothing on this. I was wondering if anyone on here has installed an oil pressure gauge on their first gen 3.4L. If you have could you explain how you hooked it up and where you mounted the gauge?
    Thanks
  2. Jan 15, 2010 at 11:28 AM
    Taco Joe
    Taco Joe Active Member
    Rancho Cucamonga
    01 PreRunner SR5 TRD Debadged
    Black wheels, exhaust, and BFG's
    Don't know how to install them, but here is a site that makes them. They mount in the pillar... http://www.gaugepods.com/tacoma2002.jpg
  3. Jan 15, 2010 at 11:47 AM
    steve o 77
    Steven
    In a corn field, OH
    Yeah, I saw those, they look nice. I just don't know how to hook it up on the engine side.
  4. Nov 30, 2010 at 9:40 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Bump! Im buying one and would like to know this as well.
  5. Nov 30, 2010 at 9:47 PM
    steve o 77
    Steven
    In a corn field, OH
  6. Nov 30, 2010 at 9:57 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    But thats more a mechanical oil pressure gauge right? Im getting a electrical gauge though haha. Thanks though. :)
  7. Nov 30, 2010 at 10:20 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    Really? Well I have no idea how to even hook it up yet lol. Have any links that show how to on our trucks?
  8. Dec 8, 2010 at 6:01 PM
    TacoBlitz
    TacoBlitz Well-Known Member
    Jake
    Omaha, Nebraska
    01 DoubleCab SR5 TRD, white
    Topper, Yakima Racks, Yakima Loadwarrior roof basket (lights all around) 20% window tint (all 4 doors), Spectre ProFab Air Intake System, Black grille, Rino Lined rocker panels, rear bumper and flares Suspension: New OME 881 coils and OME 5 leaf rear springs, Blilstein shocks and struts, Daystar Greasable lift shackels Extended rear brake line
    what is better, mechanical or electrical?
  9. Dec 8, 2010 at 8:33 PM
    TacoBlitz
    Jake
    Omaha, Nebraska
    ok thanks, so is the electrical one easier to install i assume?
  10. Dec 8, 2010 at 8:45 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    Electrical. No high pressure lines going into cab. :thumbsup:
  11. Dec 8, 2010 at 9:15 PM
    TacoBlitz
    Jake
    Omaha, Nebraska
    geez sounds kinda complicated. although I havent done to much research yet so I don't know much about it.
  12. Dec 8, 2010 at 10:15 PM
    zero4
    zero4 Metal Cutter
    Will
    Northridge, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Not sure about these days but the Autometer senders I've installed are pretty big (about 10 yrs ago). I would think technology advancements would have led to smaller senders these days.
    Electrical is the "safest" but I still always prefered mechanical. The measurment range was much greater than electrical & mechanical is more accurate. Again, maybe these days they have improved.
    If you do run mechanical, don't use the cheap nylon tubing that comes with the kit, especially if you ever plan on disconnecting it for serving or anything. Spend the $60 for a steel braded line. Trust me, I learned the hard way, had a driver's side floor mat covered in a pool of oil before. That was not fun yet I still would not swap over to an electrical guage.
    I never installed one on a Tacoma but I've almost always installed them in the factory location for the sender for the oil pressure warning light (aka idiot light) with a T fitting. Usually on the block.
