Oil pressure light flickering
Discussion in '1st Gen. Tacomas (1995-2004)' started by Toyota4x4#3, Jan 26, 2017.
  1. Jan 30, 2017 at 12:41 PM
    Toyota4x4#3
    Toyota4x4#3 [OP] Member
    Michael
    01 Tacoma
    Tree fell on, but still going
    After 3 days I finally got a hold of a mechanic friend. He's got a gauge, so within the next few days, as soon as I can get him to say when,I'll put a gauge on and see what pressure I have at different rpms. He also suggested that I start using 20w50 oil because I have 258,000 miles on my truck. Does this sound like a good idea??
  2. Jan 30, 2017 at 12:46 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Check the grounds on the intake plenum...
    Toyota4x4#3[OP] likes this.
  3. Jan 30, 2017 at 12:52 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Not necessarily. Where region are you located in?
  4. Jan 30, 2017 at 12:57 PM
    cruiserguy
    Elijah
    SEKS
    If you are gunked up, or even if not, might not be a bad idea to run an oil cycle with Rotella T6 5w-40. It's marketed towards diesel engines but perfectly safe to use in gas engines. It has additional amounts of detergents, ex. high in Zinc, etc. Possibly could help with breaking up gunk, if that is what's messing with your oil pressure.
  5. Jan 30, 2017 at 12:58 PM
    Toyota4x4#3
    Michael
    01 Tacoma
    I am located in the Mid-Atlantic region
    I live in southern Maryland.
  6. Jan 30, 2017 at 12:59 PM
    cruiserguy
    Elijah
    SEKS
    Yeah gets cold there. I wouldn't run a 20w-XX.
  7. Jan 30, 2017 at 1:05 PM
    Toyota4x4#3
    Michael
    01 Tacoma
    I have never used any engine cleaner type products the entire time I've owned the truck. I have used gas treatment several times, where you pour in the container and fill up with gas. Might have been only a couple times with that. You think I should wait til I'm due for my next oil change before I use any engine cleaner??
  8. Jan 30, 2017 at 1:24 PM
    cruiserguy
    Elijah
    SEKS
    Or like mentioned above by someone, maybe try a cleaner that he mentioned and then run that oil. But really should verify with a manual oil pressure gauge what's going on. That step shouldn't be skipped.
  9. Jan 30, 2017 at 3:16 PM
    Toyota4x4#3
    Michael
    01 Tacoma
    A mechanic friend told me he had a gauge so as soon as I can get him to do it, probably next few days. As stated before, I sat in driveway for over an hour with no flicker. It seemed to me like it won't flicker sitting still even if I hold the gas at different rpms. So sitting in his driveway it might not flicker either. It should increase in pressure when I raise the rpms though, right??
  10. Jan 30, 2017 at 5:48 PM
    cruiserguy
    Elijah
    SEKS
    Yeah the gauge should show the increase in pressure as the engine accelerates. 100% positive the oil level is full, right? Not trying to be a putz, just asking.
  11. Feb 22, 2017 at 9:45 PM
    Toyota4x4#3
    Michael
    01 Tacoma
    Been awhile, but had knee surgery and not much driving. Yes, the oil level was full. I've driven it several times and it's seems like as soon as it warms up and drive a few miles I get the flickering. Then I'll make a stop for coffee or get some gas and back on the road and it won't flicker. I need to check it with gauge and a friend told me he'd loan me his. Test drive from his house and see if gauge shows pressure drop when it flickers. Thank you goes out to everyone that gave me some advice!!
    mechanicjon likes this.
  12. Feb 23, 2017 at 7:53 PM
    Glamisman
    Glamisman Well-Known Member
    10 psi per 1000 rpm is a good start. If possible the next time it flickers pull over and pull the dip stick really fast. I am thinking cavitation, look for bubbles on the stick. Take the oil fill cap off and see if oil is pooling in the cover and finally try a Toyota oil filter, while similar, they are not the same.
  13. Feb 26, 2017 at 10:52 AM
    Toyota4x4#3
    Michael
    01 Tacoma
    That's all I use is genuine Toyota oil filters and Pennzoil. The last couple times I've been out for a drive of more than 25 miles, it hasn't flickered at all. Hoping whatever caused it , cleared up on its own. I'm gonna get a new sending unit. They had several listed at Rockauto. They ranged in price from $4.90- $17.99. They all looked the same. If I can replace it for $5 + shipping why not? Its supposed to get warm again this coming week , so I should be able to at minimum check my pressure with a gauge.
  14. Feb 28, 2017 at 9:51 AM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
