Oil pressure light issues
Discussion in '4 Cylinder' started by Archaic2021, Dec 28, 2021.
  1. Dec 28, 2021 at 8:00 AM
    Archaic2021
    Archaic2021 [OP] Well-Known Member
    99 Tacoma 2.7L 329k miles...unknow motor history before 300k miles.
    So very randomely the oil pressure light will flicker, Not even fully illuminating just flicker
    It's very spuratic and it only seems to happens under these condtions.
    Running highway speeds for 20 mins or so...coming to a stop and taking off quickly say 50% throttle and only through first and second gear it may flicker very dimly.
    Never at cruising speeds...very weird.
  2. Dec 28, 2021 at 8:03 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Have you checked the oil level???
    LoveableWerewolf likes this.
  3. Dec 28, 2021 at 8:04 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Suggest take/get a real oil pressure reading. Possibly the oil pressure is borderline (low).
  4. Dec 28, 2021 at 8:06 AM
    Knute
    True. At that mileage the oil pump could have enough wear to cause low oil pressure at the lower engine speeds.
  5. Dec 28, 2021 at 8:21 AM
    Archaic2021
    Oil level is good.
    At idle oil pressure is sitting at 25lbs by the gauge I have.
  6. Dec 28, 2021 at 8:31 AM
    Knute
    Check the oil pressure sensor. Loose wire??
  7. Dec 28, 2021 at 8:45 AM
    Archaic2021
    I didn't feel any loose wires or anything...didn't pull too hard.
    Sensor is what 16 bucks...may try that.
  8. Dec 28, 2021 at 5:03 PM
    Archaic2021
    So it did it a little more on the way home.
    It only occurs while the engine is underload like taking off. Idling you can Rev it all day and nothing happens.
    Also as soon as you back out of the throttle it stops...which is weird
  9. Dec 29, 2021 at 4:41 PM
    Archaic2021
    So now when idling and Rev to 2k rpms and let off the throttle the ligh barely dims.
    Could it be cluster related because the temp gauge doesn't work either.
  10. Jan 1, 2022 at 7:12 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    well worn engine on its last legs showing intermittent L O W oil Pressure
    not Unusual
  11. Jan 2, 2022 at 7:12 AM
    Knute
    In truth....if the easy things have been verified as correct......then that leaves the oil pump itself.
    The behavior you describe is typical of a worn pump. In a nutshell, the oil will slip past the end gaps of the pump. I believe the oil pumps in these truck are the gearotor type. Normally, the oil is between the teeth of the pump. But when the pump becomes worn and the end gap becomes large, the oil will slip out from between the teeth. The issue is less pronounced at higher pump speed, ie engine speeds.
    Check both pressure and flow at idle. Pressure alone is not enough.
  12. Jan 2, 2022 at 8:40 AM
    Archaic2021
    Well after checking with a manual algae agin is still showing good oil pressure.
    After removing the air I take I found the wiring harness that the temp gauge and oil pressure wires run through in rough shape..
    After putting the sensor back in and re rapping the wire I drive thr truck on a 30 MI ite trip...not once did the light come on...and before this the day before is was coming on almost consistent to the point t engine should have had damage
    Again checking the oil pressure with a gauge it's showing 30+ lbs.
    If a oil pump was worn would it not continue ually get worse and not just get better fir a few days
  13. Jan 2, 2022 at 8:50 AM
    Knute
    If you go back to post #11... "...if the easy things have been verified as correct.."
    Apparently, you had a wiring issue causing the intermittent warning light.
    Yes, the oil pump is mechanical. Yes, it will wear and continually get worse. But the oil pump is one of the most robust parts on an engine. Your symptoms manifested when the engine went from high rpm to idle or stopping. Pump degradation is typically very slow.
    There is a lesson here. Always check and verify the simple things first. Wires, filters, sensors, pressure, pump.......
    Glad you found the problem and the fix was easy and simple.
  14. Feb 2, 2022 at 7:40 PM
    Cwoods99508
    Cwoods99508 Active Member
    98' Tacoma 4x4 2.7 litre
    Just to post my experience with the same symptoms.
    Last winter (1 yr ago) I had the same happening with correct level of oil. I read a couple places on the net where others had oil pressure light illuminating at times and how this would happen with some brands of oil filters.
    I had a cheap STP filter in at the time....changed oil and got oem filters from the dealership and never had it duplicate again. 98' Tacoma 2.7 with 284,000 miles on the odometer.
