Oil pump chatter
Discussion in '1st Gen. Tacomas (1995-2004)' started by Allex95, Dec 14, 2021.
  1. Dec 14, 2021 at 6:19 PM
    Allex95
    Allex95 [OP] Well-Known Member
    allex
    96 Tacoma 4x4 2.7l 4 cylinder
    So I’ve recently had a noise coming from my front cover it’s sounds like it’s coming from the oil pump cover itself. Sounds as if the pump is rattling inside the cover like the cover is Worn out for the pump to spin. there seems to be wear marks on the cover on the lower part of the pump.
    https://youtube.com/shorts/6xtWyJTdRME?feature=share
  2. Dec 15, 2021 at 4:00 PM
    Murd3rd
    Murd3rd I believe I Toyota harder than most
    Your Mom's House, USA
    00.5 Reg Cab Slammed, Turbo'd/19 TRD OR 6MT S/C
    1st gen - it's got a built engine, a turbo, and waaaaaaay too much to list. 3rd gen - basic-bitch lift, S/C, Pro Wheels
    How many miles on it? Could be timing chain, they sound like that when the guides wear out or the tensioner isn't doin it's job any more.
    Also could be something as simple as a pulley. You can use a piece of vacuum line like a stethoscope to try and pinpoint where the sound is coming from.
  3. Dec 15, 2021 at 4:03 PM
    Allex95
    allex
    Short story I put the harmonic balancer on wrong it damaged the small sprocket behind the cover I replaced it and now my oil pump sounds to be making noise. I’m thinking the timing cover is worn
  4. Dec 15, 2021 at 4:05 PM
    Murd3rd
    Ah, so there was more to the story. Gotcha. How's your oil pressure? It might suck but you may have to tear it back down...
    wilcam47 likes this.
  5. Dec 15, 2021 at 4:06 PM
    Allex95
    allex
    It’s fine as far as I know oil light never on. I’ve taken off the pump cover and looked at the gears there is wear on the timing cover where the pump sits and I think it’s worn to the point the pump possibly may have play
  6. Dec 15, 2021 at 4:09 PM
    Murd3rd
    Just be cautious with oil pressure. The light comes on at 4psi. That's extremely low. So it could be at 5psi and the light will stay off, which sucks, but that isn't near enough pressure to last. With play in the pump it may not be able to keep the proper pressure. I'm not saying that this will def happen, or is happening, but something to be weary about.
  7. Dec 15, 2021 at 4:12 PM
    Allex95
    allex
    Well how can I see a get a number on the pressure. I’m not sure how it wouldn’t make pressure I’ve spun it inside and it works fine. It just seems to be making noise which it could be rubbing the cover. Not sure honestly
  8. Dec 15, 2021 at 4:16 PM
    Murd3rd
    You can remove the oil pressure sensor and connect an actual gauge. You can even install a T fitting between the pressure sensor and block and then install a gauge. Not so sure of any other way. The oil pressure sensor is just below the exhaust manifold on the passenger side. BPT (British pipe thread) tapered fitting. I don't remember the size, just know it's not a straight tapped fitting
    At this point though it might be worth it to just get a new oil pump gear and a new pump cover(or timing cover, which ever is showing signs of wear)
  9. Dec 15, 2021 at 4:20 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The pump doesn't really have any room to wiggle around in there when everything is installed
    But the chain does.. I'd pull the valve cover and look down at the guides and chain components
  10. Dec 15, 2021 at 4:35 PM
    Allex95
    allex
    Ive pulled off the cover and the chain was tight I had replaced the small crank timing sprocket behind the cover because when I put the balancer on wrong it cracked it. I reset the chain and it was tight so.
  11. Dec 15, 2021 at 5:40 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I think your oil pump is cursed !!
    this has been going on pretty long now has it not?
  12. Dec 15, 2021 at 6:02 PM
    Allex95
    allex
    Yes I’m waiting for time to tell me
  13. Dec 15, 2021 at 6:56 PM
    Allex95
    allex
    My biggest fear is loosing oil pressure out of no where
  14. Dec 15, 2021 at 9:45 PM
    Murd3rd
    Been there bud, then I dropped almost 5k buying forged parts and fully built mine. Lol. Now running 20+lbs of boost and having a helluva time!
  15. Dec 15, 2021 at 10:28 PM
    Allex95
    allex
    This is a jdm tho runs fine just has this noise that appeared after I fucked up puttingthe balancer on wrong
  16. Dec 16, 2021 at 1:49 AM
    Murd3rd
    I was more or less lite heartedly joking. But if your oil pressure drops too much then you can have what happened to me...bearings got ate up from no oil pressure so it needed a rebuild anyway, I just wanted to build it to handle more boost, so I did.
  17. Dec 16, 2021 at 2:17 AM
    Allex95
    allex
    I would love to do that but after I get a better daily then my 15mpg Tacoma :rofl:
    Murd3rd[QUOTED] likes this.
  18. Dec 16, 2021 at 8:45 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  19. Dec 18, 2021 at 7:47 PM
    Allex95
    allex
    Quick question.. is it possible for when the crank pully went on wrong the crank isn’t spinning correctly in the front now so that’s why the pump gears hit the timing cover?
  20. Dec 18, 2021 at 9:15 PM
    O'Silver_Taco
    MD
    I would be more worried about damage to the crank key, key seat, on the HB and the shaft....
    If that seat is not true, you may get a slight wobble......and the HB internal rubber bushing may be flexing.....
