Oil seep
Discussion in '1st Gen. Tacomas (1995-2004)' started by zach141b, Apr 8, 2018.
  1. May 15, 2018 at 5:25 PM
    zach141b
    zach141b [OP] Well-Known Member
    Zach
    Louisiana
    2001, double cab, 4WD, 3.4L Tacoma
    I was definitely considering going that route.
    I'll post a pic of the situation with that broken piece removed--I totally think a repair is safe for my case, as the piece that actually "caps" the camshaft is intact.
  2. May 15, 2018 at 5:38 PM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    Belzona is what they use in the refineries and chemical plants down here in Houston in the machine shop,,, good stuff. Hope what ever, it works for you.
    cruxofthebisquit likes this.
  3. May 15, 2018 at 6:02 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Like most things you want a deal on.......EBAY.
    Edit: it would prob be stronger than the surrounding metal.
  4. May 29, 2018 at 2:08 PM
    zach141b
    Zach
    Louisiana
    Well, bad news. After replacing the camshaft seals and the front crank seal, I now have an oil LEAK (possibly two!), versus the original (and comparatively minor) oil "seep."
    I haven't torn back into it yet, but I'd appreciate anyone's further thoughts.
  5. May 29, 2018 at 2:11 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    that crack looks scary, might want to take to a mechanic you trust.
  6. May 29, 2018 at 2:12 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    How was it repaired?
  7. May 29, 2018 at 2:50 PM
    zach141b
    Zach
    Louisiana
    JB Weld on the crack on the cam bearing cap. I meant to photograph the repair before reinstalling the valve cover, but I forgot.
    Of possible additional note, RTV was not applied to the OD of the seals--just grease.
  8. May 29, 2018 at 2:53 PM
    zach141b
    Zach
    Louisiana
    The crack looked scary to me at first. But when I realized the broken piece could not possibly get inside with the camshaft, I decided to attempt repair.
    I'm gonna remove the #2 timing belt cover and check soon, but I'm pretty certain my attempt failed.
  9. May 29, 2018 at 4:45 PM
    zach141b
    Zach
    Louisiana
    Hey, Sperrunner. Would you happen to have a vendor for a rebuilt head? I may well be needing one. (Passenger side.)
    Thanks.
  10. May 29, 2018 at 6:03 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Idk any veders but im sure if you google it there is a few.
  11. May 29, 2018 at 6:48 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Did the JBWeld penetrate (ooze) out both sides of the crack then require filing or grinding in and out?
  12. May 29, 2018 at 7:43 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
  13. May 30, 2018 at 3:47 AM
    zach141b
    Zach
    Louisiana
    No. I attempted to use as little as possible. My best guess right now, without yet having it apart, is that I didn't clean the area well enough (of oil.)
  14. May 30, 2018 at 3:48 AM
    zach141b
    Zach
    Louisiana
  15. May 30, 2018 at 5:29 AM
    #35
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Any little channel of a crack remaining won't cut it, has to be all the way across and as you said, able to stick to the surface well.
    A dremel would be a good choice for refinishing the bore surface and a triangular file for the arch corner.
    edit: Hate to say it (because I've been guilty of using a screwdriver to pop out a seal myself) but this is why a seal puller works best.
  16. May 30, 2018 at 6:26 AM
    #36
    zach141b
    Zach
    Louisiana
    I was using a seal puller, but not the kind I wanted. I had pretty much this exact one-- http://www.sears.com/craftsman-seal-puller/p-00947645000P . Here's the one I wanted, but it was Sunday and I couldn't find it in my little town--https://www.amazon.com/Lisle-58430-Shaft-Type-Puller/dp/B000FPYW4K .
    Actually, both Haynes and factory manuals said to cut the seal, then get it out with a screwdriver. Like it was not a big deal at all. We just couldn't get the screwdriver method to work. So then, we got the seal puller. It got the crank seal out no problem. The tool struggled with the driver's side cam, but got that one out also. Somehow, on the passenger side cam, we just couldn't get the angle just so, or we applied what leverage we had in the wrong direction. Then the piece broke off the bearing cap.
  17. May 30, 2018 at 2:02 PM
    #37
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Oh, well,dam. I was assuming and really need to stop.
    JMO but I would try a repair on the arch again before changing out a head over it. Maybe get lucky that it's an O.D. leak and not channeling out.
    RTV would remedy that. That plastic coating they use on the seal steel ring has been pretty forgiving in my experience but sometimes you just get star crossed.
    If you have an I.D. leak with a new seal and there's no score mark on the rotating object....I got nothing except just try again with a different seal.
  18. May 30, 2018 at 2:05 PM
    #38
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Any chance the JBWeld just didn't cure?
  19. May 30, 2018 at 2:28 PM
    #39
    zach141b
    Zach
    Louisiana
    That's my current guess--it didn't cure due to contamination of the epoxy with motor oil within the head. Or that I just didn't use enough of it.
  20. May 30, 2018 at 2:32 PM
    #40
    zach141b
    Zach
    Louisiana
    We're gonna try a few things before I go buying a re-manned head. The price of that one Sperrunner above linked too is $680.
