Oil Seep
Discussion in '1st Gen. Tacomas (1995-2004)' started by bubbas, Mar 5, 2025.
  1. Mar 5, 2025 at 9:11 AM
    bubbas
    bubbas [OP] Well-Known Member
    98 Tacoma 4x4 V6 3.4L
    Have had people (tht work on the truck) say engine has slight oil weep/seep. At what point do you act on this? The guy that replaced my timing belt said there was no oil there and that he was not really worried. He is a good mechanic. He said engine would have to be shampoo'd and dye put in to find leaks as it is kind of all over but he said not enough to cause any issues. No oil shows on ground or pavement when I park ever. What would you guys do? thx
  2. Mar 5, 2025 at 9:33 AM
    Speedbeagle
    Speedbeagle Well-Known Member
    I think if you're not having to add oil in between oil changes you probably don't have a problem. And while it's kinda annoying when getting under the truck to do anything, all that oil flying around under there is keeping things from rusting. However, oil on rubber boots and bushings can degrade them prematurely. If it's keeping enough oil in it to stay in the range between oil changes don't worry about it.
  3. Mar 5, 2025 at 9:34 AM
    Speedbeagle
    When I stripped my truck down to the frame, the only pristine part of the frame was directly under the engine.
  4. Mar 5, 2025 at 3:29 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    im not a fan of that oil dye
    i used once.....took freakin 3 oil changes to get that crap out of engine
    makes you oil look rust color....couldnt stand it
    nothing you cant see/locate with cans of brake cleaner and monitoring seepage area
    tech tip: always start LOW in nasty caked area.....then work your way UP to find fresh seepage once cleaned
  5. Mar 5, 2025 at 3:50 PM
    Williston
    Williston Unknown Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a couple of non-OEM nods.M mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    I would address it when any drips reach/make it to the ground, driveway, or the garage floor after sitting overnight.
