Oil seepage on head...ok or change gasket?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by becauseracebike, May 23, 2017.
  1. May 23, 2017 at 6:30 PM
    becauseracebike
    becauseracebike [OP] Member
    2008 Blue Ribbon Tacoma TRD SR5 4x4 V6
    2.5" lift, Duratrac's, Viper Alarm, Panorama S dash cam, 12V constant power mod, tonneau cover
    [​IMG] Hi guys, I noticed some seepage recently. New head gasket right?
  2. May 23, 2017 at 6:32 PM
    OKTACO
    OKTACO Well-Known Member
    Ty
    2005 SR5 Taco
    Valve cover gasket.
    outlawtacoma likes this.
  3. May 23, 2017 at 6:41 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    valve cover gasket. Not a big deal unless it starts to leak bad (yours is very very minimal). I forget what the torque spec for those small bolts n nuts that hold the cover on but you might consider going through and just snugging each one up.
    Jimmyh likes this.
  4. May 24, 2017 at 12:54 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    What he said ^^^
  5. May 26, 2017 at 12:25 AM
    becauseracebike
    Awesome thanks for the info guys!
  6. May 26, 2017 at 12:35 AM
    1999RegCab
    1999RegCab Well-Known Member
    Cacti Land, AZ
    1999 Reg Cab, 2.7, 5 speed
    3-link SAS
    If you had a blown head gasket you would have other issues :D Retorque everything as somebody suggested, but if you have to replace it the actual gasket, it is an easy job but it can be time consuming depending on how comfortable you are doing it yourself.
  7. May 26, 2017 at 5:19 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    80 in-lbs on the 10mm bolts.
