Oil Sludge in 4 and 6 engines
Discussion in '4 Cylinder' started by buckstaco, Nov 14, 2009.
  1. Nov 14, 2009 at 7:53 AM
    buckstaco
    buckstaco [OP] Member
    independence,ky
    06 tacoma
    none
    I just learned from my amsoil dealer that amsoil is not making oil filter for certain toyota engines as they will not warrant extended drains on them. I was told that these engine produce water in the oil and that produces the gunk that stops up the filter. I ask my dealer and my answers were less than I wanted. They are saying the problem was people were not changing their oil enough.. I found on the net that toyota at first wound not warrant the engine failures but now are doing so. any information appreciated as I have two 2006 4 cyl engines. one in a corrola and one in a taco.
  2. Nov 14, 2009 at 7:56 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    As long as you change your oil on a regular basis you will be fine.
    I have a 99 Camry and it's fine - oil changed every 2500 - 3000 miles - no problems.... one of the people I worked with had one as well and did not change the oil regularly... their engine died due to sludge and needed to be replaced.
  3. Nov 14, 2009 at 8:00 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    Oil Changed every 5k with Mobil 1 Synthetic.
  4. Nov 14, 2009 at 8:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2
    Sludge builds up from moisture accumulation in the crank case. Mostly, this is caused from multiple short trips, when the engine is not run for a long time at operating temp.
  5. Nov 14, 2009 at 5:09 PM
    def4pos8
    def4pos8 Well-Known Member
    Ohio
    White Tacoma AC 2.7L/5spd SR5
    undercoat, running boards
    Your AMSOIL dealer might want to be a bit more proactive. I've been an AMSOIL user/dealer since 1978.
    The kids and I operate four Tacomas, '08 through '10, all with the 2.7L/5spd driveline.
    A conversation with AMSOIL tech support people would reveal that the EaO-57 is not listed for extended drain intervals due to insufficient media volume. The EaO-57 will work normally. You simply need to replace the FILTER at manufacturer's interval -- 5,000 miles IIRC.
    That's what we are doing now: one year on the crankcase drain; 5,000 miles on each EaO-57.
    I'm exploring possible installation of the BPK-23, dual remote, bypass filter kit. I used one on a 4cyl/5spd 4Runner and it worked wonderfully. I've downloaded the BPK-23 install sheets. It looks to be reasonably straight forward. The toughest part will be figuring out precisely where to hang it. With that kit, owners can hang truly LARGE filters, including a bypass filter, and return to one-year filter changes.
    The engine doesn't NEED a bypass filter. I'm just an Old Guy with certain fetishes regarding clean oil in sufficient volume.
  6. Nov 15, 2009 at 9:23 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Word. In my 06 Taco 2.7, I usually drive at least 15 miles on each trip with regular 40+ mile trips so I know everything's up to temp for sufficient periods. I know several people who change their oil every 3k but only replace the filter every other oil change -- they use quality filters that hold lots of particulates and have not had any problems at all. My Dad recently bought a 2006 Toyota Highlander with the same 2.7L 4-banger and 90% of his trips are between 2-5 miles. (Once or twice per month he will drive 30 miles in a trip but that's the longest he will go in his normal routine.) Anyway I told him these constant short trips might be considered 'severe servce' so he really should consider changing the oil every 3k instead of following the recommended 5k interval. Oil is cheap -- engines are not.
  7. Nov 15, 2009 at 9:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Bingo.
  8. Nov 15, 2009 at 12:30 PM
    The Shape
    The Shape Well-Known Member
    Forrest City, AR
    '09 Access Cab A/T 4banger
    Yeah I am thinking of going to a shorter OCI becasue I tend to a lot of stop and go driving and short trips. I know any enging can get sludged up by not changing the oil, but these aren't the engines that Toyota had all of the problems out of were they?
  9. Nov 15, 2009 at 6:39 PM
    Terrier
    Terrier Well-Known Member
    Idaho
    2008 SR5 Access Cab 4x4 2.7
    This thread brings up an interesting issue; however, I do not want to hijack it so I will post a new thread. The issue is What is Normal Operating Temperature?
  10. Dec 31, 2009 at 7:49 AM
    TroutBum
    TroutBum Well-Known Member
    Michigan
    06 SR5 AC 4x4 Sold, 17 Sport 6MT DCSB, 2020 OR DCSB
    Leer 100R
    I just did an oil change on my 2.7 this morning and noticed some sludge in the oil cap. I've been changing every 5000 miles per the manual, and switched to Mobil 1 at my last oil change. But, since August I've been driving to a job site three to four times a week that's only 3 miles from my office. Might start on a 3000 mile interval for now at least until this project is over...
  11. Dec 31, 2009 at 7:56 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    OP stated in title 4 and 6 engines. I have the V6 in my 09. Changed to Amsoil at the 5000 mile mark. My plan was to change the filter every 5000, and the oil every year or 10,000 miles. I more than likely wont put over 10,000 miles on it in a year as I have a 5 mile trip to work. Does this throw a wrench in my plan?
  12. Dec 31, 2009 at 7:58 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I would say so. If condensation builds in teh crank case, it doesnt matter what kind of oil you have.
  13. Dec 31, 2009 at 8:02 AM
    hendooman
    Jeff
    KC
    ^^^Chris would you suggest full changes at 5000 mile intervals then? F-me...that is an expensive oil change then twice a year.
  14. Dec 31, 2009 at 8:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You should do an oil sample at 5k miles to determine your oil change intervals.
  15. Dec 31, 2009 at 8:34 AM
    hendooman
    Jeff
    KC
    sounds like a plan. I could do that right now, as I am about to turn 10,000 miles...thanks for the advice. I will share results with you and maybe you can help me decipher them. Thanks.
  16. Dec 31, 2009 at 8:35 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    According to the AMSoil Product Recommendation and Drain Interval Chart, our trucks/engines aren't listed as vehicles that are prone to sludge. I've emailed their tech support to see what they have to say. I follow the severe use drain interval with an EaO-57 filter (oil and filter once a year). I did find that they don't offer that filter any more, but I had a spare so I put that on last time.
    Interesting that they don't spec the filter for the 2TR-FE anymore, but the engine isn't listed as sludge prone.
  17. Dec 31, 2009 at 8:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Cool :)
  18. Dec 31, 2009 at 8:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not many are listed. It all depends on your driving style. Short trips will build condensation in the oil. Regardless if the engine is not "Sludge prone".
  19. Dec 31, 2009 at 8:40 AM
    hendooman
    Jeff
    KC
    just ordered the blackstone lab test kit :woot: I am on my way.
  20. Dec 31, 2009 at 8:42 AM
    afd23a
    The Dynamo of Dixie
    Good point. Sludge can happen on any engine that way. I'm still curious if using extended drain intervals on our engines voids the warranty.
