Oil spraying everywhere
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HillBillyRedNeck, May 5, 2019.
  1. May 6, 2019 at 7:30 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  2. May 6, 2019 at 7:36 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Look for the highest place that the oil is puddling. Take more pictures for these anxious viewers.
    Biscuits and Running Board Man like this.
  3. May 6, 2019 at 8:01 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    That does not look good. Curious to see what the cause is. Good luck OP!
  4. May 6, 2019 at 8:07 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Oil filter is on the right side of the engine... dip stick is on the left though..... did you check that it's in and seated all the way? Not trying to insult your intelligence OP, just a thought...
  5. May 6, 2019 at 8:07 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Pattern looks like it could be the PS pump but the color says motor oil
    :notsure:
    Running Board Man likes this.
  6. May 6, 2019 at 8:11 AM
    TireFire
    Olympic Peninsula
    More like braking is for losers fluid
  7. May 6, 2019 at 8:19 AM
    TireFire
    Olympic Peninsula
    Amazing. Dot 3?
    Maybe rubber brake hoses are disintegrating
  8. May 6, 2019 at 8:47 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Learn something new every day. :thumbsup:
    Biscuits likes this.
  9. May 6, 2019 at 8:51 AM
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    Not sure why there is hate on pressure washing. Just don't point the nozzle to close to electrical components and you will be fine. I take off the plastic engine cover and spray away.
    I have used this method in my 4.0 V6 4runner for 6 years without issues. I will do the same method to my Tacoma as well.
    Keep the engine valley dry? Come on, the engine gets so hot and any excess water will steam off anyway. Again I never had any 'valley' issues with my 4runner.
    landphil and wheeliest like this.
  10. May 6, 2019 at 8:54 AM
    TireFire
    Olympic Peninsula
    Why would you though? IMHO the maybe low risk outweighs the minimal reward
    This!
  11. May 6, 2019 at 8:57 AM
    4wdExplorer
    Orange County, CA
    To keep the engine bay clean. When you off road engine gets dirty and if you do not clean the excess mud or dirt you can run hotter than normal. I just like a clean engine bay because I work on my own cars and I don't like flaking dirt falling on top my driveway and garage floor.
  12. May 6, 2019 at 9:03 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Has the source of this leak been located?
    With all the comments about washing the engine, I lost track.
    Any chance v this could be transmission fluid?
  13. May 6, 2019 at 9:10 AM
    4wdExplorer
    Orange County, CA
    I would not blame that on engine washing. You can rust from many ways, being in a environment with lots of corrosion can cause this. Where it snows, close to the beach, etc.
    My friend lived in IL and I popped his hood in his 5 year old Tacoma and some of his OEM intake clamps had rust on them. I would not blame that due to engine bay washing..
  14. May 6, 2019 at 9:18 AM
    TireFire
    Olympic Peninsula
    I use simple green and garden hose for that. But I don’t go mudding
  15. May 6, 2019 at 9:28 AM
    #35
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    You are watching, what's the update?
    Torspd and 9TRDTCO like this.
  16. May 6, 2019 at 9:28 AM
    #36
    HillBillyRedNeck
    HillBillyRedNeck [OP] Well-Known Member
    JOSH
    Arlington, Wa
    2010 Tacoma SR5
    cheap spacer lift for now
    Here is a video, its coming from behind the crank pulley.
    b_r_o likes this.
  17. May 6, 2019 at 9:28 AM
    #37
    TacomaSport86
    No video
    9TRDTCO likes this.
  18. May 6, 2019 at 9:43 AM
    #38
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Front main seal. Did a belt shred, or some form of string or debris get stuck between the crank pulley and seal?
    Biscuits and b_r_o like this.
  19. May 6, 2019 at 9:43 AM
    #39
    HillBillyRedNeck
    JOSH
    Arlington, Wa
    2010 Tacoma SR5
    Well the video won't load
    b_r_o likes this.
  20. May 6, 2019 at 9:44 AM
    #40
    HillBillyRedNeck
    JOSH
    Arlington, Wa
    2010 Tacoma SR5
    No belts shredded, I'm going to tear it apart and see what i find
    Torspd likes this.
