Oil suggestions after oil treatment?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03TurtleTaco, Oct 18, 2016.
  1. Oct 19, 2016 at 6:39 PM
    Roadeater
    Roadeater Well-Known Member
    Kennesaw, Ga
    2004 Black Tacoma Prerunner TRD V6
    When I changed to Penzzoil synthetic the difference was noticeable. Engine got quieter and better gas mileage too.
  2. Oct 19, 2016 at 6:54 PM
    Xyphon112
    Xyphon112 Well-Known Member
    Where's your sample analysis for proof?
  3. Oct 19, 2016 at 7:32 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Car oil. Whatever is marketed the best is what sells. Doesn't royal purple say it can go a year? Interesting to see what it's viscosity is after a year
  4. Oct 19, 2016 at 8:01 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Whens the last time you did a tear down on a pennzoil run motor? parafin (Aka wax) which is a petroleum product, is in conventional motor oil. When the oil is used the additives are worn out. Once they are worn out it begins to leave a waxy residue behind. Aswell as sludge. In the case of pennzoil and quaker state there oils break down much faster than other brands such as mobil one or valvoline. You dont need a oil analysis to prove it happens and to prove there is still wax in oils. Do some research, might suprise yourself with what you find.
  5. Oct 19, 2016 at 8:13 PM
    ajm
    ajm Well-Known Member
    Anthony
    AZ
    1996 4x4
    Nothing wrong with Quaker state or Pennzoil. Both quality oils.
    I'd say you're good to go with any name brand oil. I use whatever is on sale, my engine hasn't gunked up yet.
  6. Oct 19, 2016 at 9:09 PM
    03TurtleTaco
    03TurtleTaco [OP] Well-Known Member
    Kody
    03 Tacoma off road build on a budget
    3 inch lift (eibach coils with bilstein 5100s in the front and rear with an aal). 17" Toyota trail team wheels (7 spoke) with Nitto Terra Grapples (285/70/17).
    well, thanks for all the info guys lol
    This may be a dumb question but what she the overall recommend viscosity? Would it be bad to use synthetic at 230k miles?
  7. Oct 19, 2016 at 9:47 PM
    757yotas
    Virginia
    2007 TRD Sport
    If you have no oil leaks and not alread burning oil then make the switch! And stay with 5w-30 as its the OEM recommended oil weight. If you burn oil you could try going to a 10w-30 to see if it helps but it may not.
  8. Oct 19, 2016 at 9:48 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    Everyone is probably going to freak out about this but.... I have some people that are swearing by this stuff! One of them is an engine machinist who has been working in a machine shop for 40+ years. He swears his engine is as clean as when it came out of the factory. Another customer of mine who does heavy duty only, farm, tractors, hydraulics, also swears by this. He has it in several of his own cars.
  9. Oct 19, 2016 at 9:54 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SLC
    2000 ext cab, 2.7L, auto, 4x4
    No reason to freak, that's a very high quality engine oil. Excellent additive package and high in zinc, which is likely to be what's keeping the engine so clean.
  10. Oct 19, 2016 at 9:57 PM
    CodeSeven
    Serge.
    Coachella Valley
    Yeah, it has to deal with the high pollutant capabilities of diesel, I can kinda see why it is able to keep gasoline engines clean. Not much compared to diesel.
  11. Oct 19, 2016 at 10:06 PM
    cruiserguy
    Elijah
    SLC
    Exactly.
    To be honest, I'm still really surprised that folks still use conventional oil. I don't care either way, it's just surprising. With the data and testing we've done now and and the lower price point than in the past, quality synthetic oil just performs much better than conventional. Flows quicker on cold start up, protects to a much higher temp, etc. I don't want to start a passing match over it... I'm just surprised, is all.
  12. Oct 19, 2016 at 10:06 PM
    CodeSeven
    Serge.
    Coachella Valley
    I was thinking about switching over for 1 oil change to see what happens. or who knows, maybe I'll make the permanent switch :)
  13. Oct 19, 2016 at 10:07 PM
    cruiserguy
    Elijah
    SLC
    Oh my bad, I didn't know you weren't already using synthetic, lol. Not a dig at anyone, promise.:oops:
  14. Oct 19, 2016 at 10:42 PM
    KrzyKjun512
    KrzyKjun512 Well-Known Member
    Chad
    2000 TRD, Original Rust-Free
    Why do I always read oil threads......I always end up disappointed. Just like when I get together with my Ex. :pccoffee:
    757yotas and ajm like this.
  15. Oct 19, 2016 at 10:53 PM
    #35
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    Seeing the sludge pennzoil left behind is what caused me to switch to AmsOil. All oils are not created equal. This thread https://www.tacomaworld.com/threads/im-concerned-yellow-gunk-under-oil-filler-cap.68453/ with pictures of sludge in oil caps and filler necks also shows all oils are not created equal.
    757yotas[QUOTED] likes this.
  16. Oct 19, 2016 at 10:58 PM
    #36
    cosmicfires
    David
    Everett, WA
    Diesel oil should not be used in gasoline engines. Diesel oil has additives designed for diesel engines not gasoline engines. The chemistry of diesel engines is different from gas engines requiring different additives. It's best to use the oil designed for the engine.
  17. Oct 19, 2016 at 11:18 PM
    #37
    cruiserguy
    Elijah
    SLC
    This just isn't accurate.
    From Amsoil's site:
    Motorists may favor diesel motor oils over theirgasoline counterparts for a few different reasons. It is safe to use a diesel oil in your gasoline engine, provided the diesel oil meets the appropriate specifications and viscosity requirements of your engine.
    (the vast majority of them do, I'd be surprised if you can find one at the parts store that doesn't)
    Get yoself edjumacated:
    Some really good info and reading on this website,
    https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1483035
  18. Oct 20, 2016 at 12:23 AM
    #38
    CodeSeven
    Serge.
    Coachella Valley
    Also, after about 12 years in the wholesale auto parts business, ive learned pretty much that all conventional oil is the same except for what additives they put in it. the additives are there to: 1) change viscosity at different temperatures, 2) introduce dispersants to prevent sludge buildup, and 3) provide antioxidants to prevent rust and metal to metal ware.
    So really, no. Delo won't harm your engine. Especially a slow revving high torque engine like our 3.4s.
    Only thing is i'm a little worried about testing this theory even though I really want to try it out. :annoyed::confused::mad::(:bananadead:
  19. Oct 20, 2016 at 9:02 AM
    #39
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    How is this a Pennzoil problem vs Other non synthetic oils?
    Whats wrong with Waxy slick surfaces in engines? Are you confusing waxy surfaces with deposit build up? How do you evaluate it being "break down much faster" ?
  20. Oct 20, 2016 at 9:05 AM
    #40
    OneWheelPeel
    Phoenix, AZ
    Uh Oh that meens my Motorcycle which I use Rotella in is going to blow up any second!!!!1!! And I'm lucky my 16K RPM limited sport bike which I ran T6 in for 20+ thousand miles didnt blow up two!!!!111!!!!
    What specific kinds of "additives" are you referring to? Have you looked at a Virgin sample of most diesel oils?
