Oil Suggestions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRD Fisher, Aug 18, 2016.
  1. Aug 18, 2016 at 4:41 AM
    TRD Fisher
    TRD Fisher [OP] Well-Known Member
    Abingdon, MD
    2014 TRD Sport
    I know this has probably been addressed, but with searching I have not been able to find it. I have a 2014 v6 with 30k on it. The previous owner has been getting oil changes done at the dealer with conventional oil. I have always run Motul full synthetic through my subaru WRX because it is one of the few oils that would stand up to the high heat of the turbo. With that being said I no longer need to spend that kind of money.
    What oil does everyone suggest? I will be keeping the truck till the floor boards rust out. Should I change to synthetic, semi-synthetic or run conventional? What oil should I use?
    I drive about 700 miles a week and most of it is city driving.
    Any suggestions would be great.
    Also I will be doing the changes every 5k and doing a rotations.
    Do you recommend a round robin change or a x applesauce?
    Thanks again everyone.
    10trdtaco and Rambo MARINE Recon like this.
  2. Aug 18, 2016 at 4:55 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  3. Aug 18, 2016 at 5:10 AM
    Rambo MARINE Recon
    Rambo MARINE Recon Well-Known Member
    Robert Goudin
    2013 Toyota Tacoma PreRunner DCLB V6 Auto. Hvy Duty
    Many, suspension, Hood Scoop,Decals and Pin Stripping, New Tires Michelens LTX MS2
    AMSOIL or MOBIL 1 !!!!
    Norton likes this.
  4. Aug 18, 2016 at 5:32 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Wow, 700 miles a week.... That's about 3k miles a month, so you plan on doing oil changes every other month?... Definately go synthetic. Any synthetic.
  5. Aug 18, 2016 at 5:37 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    It's probably been covered a thousand times.
    FWIW, I run Mobil1 however my $0.02 is that regular changes using a high quality oil is the key more than a particular type.
  6. Aug 18, 2016 at 5:41 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    Sounds like you want something fairly cheap but still good. I run Castrol Edge full synthetic in my first gen. Been running that in it since I rebuilt the engine 4 years ago, and the oil comes out just barely darker than when it went in, and that's changing it every 5k. :thumbsup:
  7. Aug 18, 2016 at 5:48 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    any oil really that is not basic garbage (well known and api spec)
    conventional change at 5,000 w/filter
    synthetic change at 10,000 w/filter
    that's it
  8. Aug 18, 2016 at 7:19 AM
    TRD Fisher
    Abingdon, MD
    2014 TRD Sport
    Thanks everyone
  9. Aug 18, 2016 at 11:45 AM
    Fulton246
    Fulton246 Well-Known Member
    NC
    2019 TRD Sport 4x4 DCLB
    Mobil 1 full synth with OEM filter and crush washer. Buy the oil from Sams (6 qts are usually on sale for around $28-$30) and the filters online.
  10. Aug 18, 2016 at 12:21 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    Great point on Mobil1. I get it at Wal-Mart (no Sam's membership) and you get a 5 quart jug for about $22. If you compare you'll see it's often more expensive for 4.5 quart jug other places.
  11. Aug 18, 2016 at 12:27 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    mobil 1 or gtfo
    127.0.0.1 likes this.
  12. Aug 20, 2016 at 7:40 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    FWIW, I run Amsoil Signature Series oil and Toyota 90915-YZZD3 filters. Replacing the oil plug gasket at each change is definitely a good idea.
  13. Aug 20, 2016 at 10:42 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    If I had the money: Amsoil all the way. Since I don't: Valvoline Full synthetic or Mobil 1 full synthetic
    Rambo MARINE Recon likes this.
  14. Aug 20, 2016 at 10:57 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Don't over think this. Get some off-the-shelf synthetic (M1, Valvoline, Castrol, Pennzoil, whatever floats your boat) and a decent filter. Call it a day and enjoy life.
  15. Aug 20, 2016 at 11:04 AM
    TRD Fisher
    Abingdon, MD
    2014 TRD Sport
