My Truck is doomed! Oil test results from 30k oil change. UPDATE: 110K!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Woodrow F Call, Aug 11, 2017.
  1. Aug 11, 2017 at 4:19 PM
    Woodrow F Call
    Woodrow F Call [OP] Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Screenshot_20210727-141328_Adobe Acrobat.jpg Screenshot_20210727-141328_Adobe Acrobat.jpg Screenshot_20170811-181737.jpg Screenshot_20171215-163245.jpg Screenshot_20180705-083004_Adobe Acrobat.jpg 20181130_141247.jpg 20190510_162537.jpg 20191206_172706.jpg Screenshot_20201201-204946_Adobe Acrobat.jpg
    I know there has been quite a bit of discussion about if you should change your oil more frequently than the manufacturer recommendations.
    Since all the data is in this latest pic, I'm cleaning up and deleting the redundant information. As you can see below, the data from the 30K, 40K, and 50K, 60K, 70K, 80K is there.
    I'm using 0W-20.... For my 30k, I used Mobil 1 0W-20 Advanced Fuel Economy.
    For more info on the reports: https://www.bobistheoilguy.com/engine-oil-analysis/
    Please note: I goofed up the 80K sample a little. I forgot to take the sample from the oil pan. I ended up having to take it from the filter housing.... after I drained it with the plastic spout. Basically, I just took the filter out and poured the remains in the sample jar. I kinda figure that might be the worst oil anyways. Just a FYI.
  2. Aug 11, 2017 at 4:21 PM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Thanks for sharing - good to see some hard data on the oil change intervals!
  3. Aug 11, 2017 at 4:27 PM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
  4. Aug 11, 2017 at 4:29 PM
    rnicholls
    rnicholls Well-Known Member
    2016 TRD OR DCLB
    I don't know to interpret this but I definetly appreciate it
    gnarkill2k likes this.
  5. Aug 11, 2017 at 4:32 PM
    harrycary
    harrycary Well-Known Member
    Harry
    2016 Tacoma TRD Off Road
    Thanks for sharing.
  6. Aug 11, 2017 at 4:33 PM
    rjacobs
    rjacobs Well-Known Member
    you cant interpret much until the OP has several OCI's that are all tested. Its good to compare to their universal average for this motor too, but seeing what YOUR engine is doing compared to previous changes is the key. IF something all the sudden spikes to a weird level, you can pin point problems before bad things happen. So copper goes sky high... can point to main/rod bearings. If iron goes up could be valve guides. Etc...
    kgilly, Joe23 and Dogg23 like this.
  7. Aug 11, 2017 at 4:39 PM
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    what engine do you have I4 or V6?
  8. Aug 11, 2017 at 4:39 PM
    Woodrow F Call
    Colorful Colorado
    You can get that the oil is still good after 10,000 miles... That's the main question here.
    As far as the health of my engine, you get a ballpark idea, but as you stated the more data points, the better I'll be able to tell if I have a rebuild coming up.
    I got a few more changes before I run out of warranty. I'll test those too, but I'm not really worried about it as most engines will make 200k with proper maintenance, easy.
    kgilly, Krucen 01, Joe23 and 4 others like this.
  9. Aug 11, 2017 at 4:40 PM
    Woodrow F Call
    Colorful Colorado
    V6
  10. Aug 11, 2017 at 4:40 PM
    TheCookieMonster
    North East
    OEM oil filer?
  11. Aug 11, 2017 at 4:43 PM
    Woodrow F Call
    Colorful Colorado
    Filter? Correct. OEM filter each time.
  12. Aug 11, 2017 at 4:44 PM
    TheCookieMonster
    North East
    thanx for the infos this is really helpful
  13. Aug 11, 2017 at 4:48 PM
    scocar
    scocar hypotenoper
    The viscosity is surprisingly good for that interval.
  14. Aug 11, 2017 at 4:51 PM
    Ed Crankshaft
    Ed Crankshaft Well-Known Member
    2016 Black Tacoma TRD 4X4 DCSB
    Thank you Mr. Call! That is good information.
    Woodrow F Call[OP] likes this.
  15. Aug 11, 2017 at 4:52 PM
    Woodrow F Call
    Colorful Colorado
    Most mfgs really test the snot out of oil and give you a conservative estimate on the frequency the oil should be changed.
    TRDSport10, Paul631, Governor and 3 others like this.
  16. Aug 11, 2017 at 4:54 PM
    th365thli
    th365thli Well-Known Member
    Jerry
    Bay Area
    2019 Ram 1500 Big Horn Quad Cab
    Good shit man, always appreciate your contributions.
    Krucen 01 and Woodrow F Call[OP] like this.
  17. Aug 11, 2017 at 4:55 PM
    scocar
    scocar hypotenoper
    Yeah, I've done Blackstone samples before on my old 5vzfe and was surprised to see how poorly the viscosity was holding up on Mobile 1 full synthetic at only 6k.
  18. Aug 11, 2017 at 4:56 PM
    Woodrow F Call
    Colorful Colorado
    Mostly, it's snarky comments, but every now and then I try to be useful.
  19. Aug 11, 2017 at 5:00 PM
    Woodrow F Call
    Colorful Colorado
    Might have had something else going on killing your oil? Boosted? How was your TAN?
    The hammer likes this.
  20. Aug 11, 2017 at 5:17 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    I'm pretty sure I could put 20k on my truck with the mobil1 0-20W synthetic I use and get a clean bill of health, all is normal engine health check.
    They ran multiple synthetic oil trial tests on state police cruisers many years ago, some went much longer and when they tore them down for inspection, they found amazing good results no appreciable wear after 100-200k, or so they reported.
    But that's never gonna happen in my case as I like changing my oil & filter every 5k, just to be sure and getting under there to check everything and making sure everything is ok under there
    Thanks for sharing the good findings, this is good news on these engines
    Cheers
    DevilTaco4, Krucen 01 and CusterFan like this.
