Oil / tranny fluid cooler with factory towing package
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hardtaco, Jan 20, 2011.
  1. Jan 20, 2011 at 1:18 PM
    hardtaco
    hardtaco [OP] Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    What exactly does this added oil cooler look like that comes with the factory tow package on my 08? I want to see if I have this or not.
  2. Jan 20, 2011 at 1:26 PM
    06aztaco
    06aztaco Screw you guys, I'm going home.
    Cole
    Phx AZ
    06 Prerunner 2.7
    a small radiator in front of your normal radiator
  3. Jan 20, 2011 at 1:33 PM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    I see that one but I believe its the condenser coil for AC.
  4. Jan 20, 2011 at 3:01 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    Under that big red oil filter is the oem engine oil cooler.
  5. Jan 20, 2011 at 3:47 PM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    Hmmmm.......I need to see if I have that or not.
  6. Oct 25, 2011 at 9:17 AM
    Blackhawk131
    Blackhawk131 Well-Known Member
    Then where is the trans cooler located?
  7. Oct 25, 2011 at 11:36 AM
    Paczowski123
    Paczowski123 Well-Known Member
    David
    Kennesaw
    05 prerunner trd off road
    OME 3" Lift, Kennesaw Mountain Off Road Wincher Front Bumper w/ 5" Integrated off road lights, Kennesaw Mountain Off Road Multi Carrier Rear Bumper w/ swingout tire carrier, Jerry can, and hi-lift mount, Sof-topper rear cargo cover. Galaxy DX44V CB Radio W/ 4' FireStikII, Rock Sliders
    there^^
    it is the mini radiator located here^ about the size of an open wallet w/ two rubber/metal lines that go into it
  8. Oct 25, 2011 at 11:41 AM
    Blackhawk131
    That makes sense because that is where most after market systems go. But now why is the oil cooler under the filter and how good is that cooler? Seems like it wouldn't work as well.
  9. Oct 25, 2011 at 11:45 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If it's an automatic you'll have two one for the engine oil (under the red filter) and one for the trans (in front of the A/C condenser).
  10. Oct 25, 2011 at 2:41 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Givim a damn picture
    Driver's side, in front of the A/C Condenser, half hidden by the Bumper, with a hose entering the top
    CC
    Island Cruiser and BassAckwards like this.
  11. Oct 25, 2011 at 5:45 PM
    Toyo_Jet
    Toyo_Jet Well-Known Member
    Shane
    Flatlands of Indiana
    10 4X4 V6 SR5 access Cab
    The engine oil cooler is a water to oil cooler not a traditional air to oil cooler. I have two Yamaha bikes with this system, works fine.
  12. Oct 25, 2011 at 6:36 PM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    Anybody have a picture of the oil cooler off the truck, or just with their oil filter off?
    These things are $500+ and toyotapartssales.com. I am wondering if my machinist in-laws can make me a heat exchanger (the t-stat housing is under $100).
  13. Oct 25, 2011 at 8:03 PM
    iroc409
    Washington
    A red one
    Engine oil. I assume it's kind of just a water jacket that oil flows through, but I've never seen one without a filter or off the vehicle.
  14. Oct 25, 2011 at 8:12 PM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    Engine oil runs about 210 ~215 degrees F.
    Radiator coolant runs about 184 degrees F.
    Factory oil cooler circulates coolant through the heat exchanger that sets under the oil filter. The cooler water lowers the higher oil temp.
    Look on ebay. They pop up for sale from time to time.
  15. May 17, 2015 at 5:16 PM
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    '10 Tundra TRD RockWarrior
    Yes.
    Beyond the additional oil capacity gained, do you think the 4.0L would benefit from an additional, more traditional, Oil to Air cooler in line? Adding oil is usually beneficial in most systems, and the additional cooler would likely add almost a quart between lines and the cooler itself.
  16. May 17, 2015 at 5:56 PM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    I know of some guys that have gone this way. I would say the important item would be to get a model that has a thermostat. This way it won't circulate until the oil warms up.
