Oil Type and Brands?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Amanwithnoplan, Dec 29, 2021.
  1. Dec 29, 2021 at 8:06 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    For 5k OCIs (oil change intervals), I actually wish I could just use conventional 5w30 since it's cheaper and there's tons of evidence to show that dino oil can take a 5k interval with no major hit in performance. But conventional oils tend to cause unsightly varnish in upper engine components so I avoid it for that reason.
    Lucky for us, synthetics have gotten very cheap over the years and if you get a 5qt jug with a rebate, it costs the same (or even less!) than dino oil.
  2. Dec 29, 2021 at 8:25 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    This,
    & Castrol syn,& Napa Gold.:eek:
  3. Dec 29, 2021 at 8:29 AM
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    i am also on the Supertech Full synthetic 5w30 and Toyota filter bandwagon. $30 oil change.
    CS_AR, ARCHIVE and 2015WhiteOR like this.
  4. Dec 29, 2021 at 8:46 AM
    vettaco
    vettaco Well-Known Member
    Vince
    09 AC PreRunner
    ^ Applause (clap clap) and with synthetic oil from the 21st century you can typically go much more than 5k per OCI. (Don't take my word for it, do some reading on bobistheoilguy.com)
  5. Dec 29, 2021 at 9:23 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    NAPA synthetic is Valvoline Advanced Synthetic rebranded. Excellent choice.
  6. Dec 29, 2021 at 9:27 AM
    Plain Jane Taco
    USA
    All the Warren oil clones are excellent....SuperTech, Kirkland/Costco, Amazon Basics, Harvest King, Meijer and others.
    If filters are your thing, M1 A series, Fram Ultra/XG, Wix, Purolator Boss are all highly rated filters
    CS_AR and EdgemanVA like this.
  7. Dec 29, 2021 at 9:28 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    I've switched to Costco synthetic. 10 quarts for $25, so $12.50 for 5 quarts of full synthetic 5W30.
    hfjeff, CS_AR, tacotoe and 3 others like this.
  8. Dec 29, 2021 at 10:13 AM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    I use synthetic oil and an OEM filter every 5k miles. I've used Mobil 1, Castrol and Valvoline. I never noticed a difference between the oil and I doubt my truck can either
  9. Dec 29, 2021 at 10:26 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    OP.....you can cut thru the BS by opening your Owner's Manual. It will state the viscosity and the API grade for your truck. Any brand oil in dinosaur or synthetic that meets the viscosity and API grade will be acceptable. Get a good oil filter. IMHO, the best filters are Toyota, WIX, NAPA Gold, Bosch and ACDelco. Then just follow the change interval. Its not as complex as the Internet leads to believe.
    Example: My '06 with 115,xxx mile the V-6 (4.0L, 1GR-FE) has 5w30 synthetic with a NAPA Gold filter.......Sorry, I don't recall the brand of oil.
    BTW, be wary of the "knowledge" at the auto stores. They insisted my truck needed iridium plugs.....I didn't believe. Went to Toyota, bought the correct plugs, they turned out to be just basic copper based plugs. Ended up saving $$
    tacotoe and wi_taco like this.
  10. Dec 29, 2021 at 4:23 PM
    Amanwithnoplan
    Amanwithnoplan [OP] Member
    Sievrrhyn
    2015 Black Tacoma TRD Pro
    Right before the chip shortage hit hard, paid 33k (after tax, registration, etc.)with it having like 54,000 miles.
    tacotoe, fresyota and Dm93 like this.
  11. Dec 29, 2021 at 4:36 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I buy Costco full synthetic, roughly $25 for two 5 quart jugs. Buy Fram filters from Walmart. I've been changing the oil every 10,000 miles since new. 15 years and 220,000 miles ago. It still doesn't use any oil in the 10,000 miles. Been doing the same on every vehicle I own for years. I used to do 5000-mile oil changes but figured I was wasting my time and money.
    I've driven several million miles in the last 49 years. Never felt the need to pre-fill an oil filter. Never had an engine failure.
    CS_AR, ARCHIVE and NAAC3TACO like this.
  12. Dec 29, 2021 at 4:41 PM
    Steve-O
    Steve-O Well-Known Member
    SW Ohio
    2007 Tacoma 4x4, TRD Off-Road
    I've been running Walmart SuperTech 5w30 full synthetic and a Motorcraft FL400S filter :eek: for a long time. The thing has never used oil.
    Why? Because I can source them locally the day I need them. The oil is dirt cheap for a full synthetic, as is the filter. No coupons or mail-in rebates required. I've changed the oil & filter every 5,000 miles since I bought the truck back in 2007. North of 160k miles on it to date with no engine issues to speak of. Can't say the same for the frame, but Toyota took care of that one on their dime.
    The only other regular engine maintenance I do is change the spark plugs every 30k miles. Someone earlier in this thread mentioned cleaning the MAF sensor every oil change, but I've never touched mine. I've also never run an oiled air filter, so maybe that's why it hasn't seemed to matter. Maybe I'll give it a look the next time I'm so inclined.
    I wasted years searching for the holy grail of oil + filter, but in the end, it doesn't really seem to matter. At least not on this truck. As long as it has the API certification, I just roll with it.
  13. Dec 29, 2021 at 4:50 PM
    Taco 422
    Taco 422 Well-Known Member
    USA
    Gen 2 AC v6 TRD SR5 Prerunner
    1 2/3 oil changes… it’s your funeral bud.
    Second thought: 5000 interval works with synthetic oils. Supposedly.
  14. Dec 30, 2021 at 4:51 AM
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    I have run full synthetic to 7,500 on my Tacoma 4.0, and 10,000 on my Tundra 4.7 v8, Sequoia v8, and 9,000 on my RX330 v6. They all have oil that is far from black at those miles. People who do oil analysis on their used oil know that dumping synthetic at anything less than 5,000 is wasting money and resources.
    There are other car makers I might not do that with, but Toyota engines don't beat up the oil.
    Also, if you use your vehicle in severe duty situations like racing, dust, extreme ambient temps, then not extending interval is smart.
    wi_taco and Taco 422[QUOTED] like this.
  15. Dec 30, 2021 at 4:55 AM
    #35
    mac84
    mac84 Well-Known Member
    Alabama
    2015 Tacoma TRD Sport 4WD MGM
    I've been known to over maintain on some equipment but a 3K oil change......that'll hit you in the wallet if done over time.
    Taco 422[QUOTED] likes this.
  16. Dec 30, 2021 at 11:45 AM
    #36
    MadRussian
    MadRussian Well-Known Member
    Metrowest MA
    2010 TRD OR AC
    M1 5w30 synthetic, Toyota filter, 10k oci, 180k on truck, great recent Blackstone analysis.
  17. Dec 30, 2021 at 7:09 PM
    #37
    jstanley
    jstanley Well-Known Member
    Central TX
    2013 TRD Sport 4x4 Pyrite Mica.
    OTT, OME, Dakar, Eaton rear locker, camper shell, Konig Six Shooters and 33" Wildpeak tires, Pelfreybilt front bumper and skids
    After pulling valve covers and oil pans on a 3 different engines that had run Mobil 1 exclusively and seeing the sludge build up, I switched to Castrol blend. Also went to 10W-40 to quite the noisy lifters (no more tap tap tap). Not sure Castrol is the best choice but is readily available.
    Can't stand how dirty oil is at 5K, so changing at 3K.
    Toyota oil filters on Amazon, buy a whole case for what two filters cost at O'Rielly's
    My dad retired as a Mechanic from the
    state, and agreed with my observations and the changes I made, based on his experiences.
    Fumoto oil drain valve makes oil changes a no mess exercise.
  18. Dec 30, 2021 at 7:29 PM
    #38
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    I fill it about 2/3 full then it dissappear inside there, I screw it on w/out losing any. But then just fire it up afterwards.
    Castrol Synthetic 5W-30 in wife's 2nd gen and M1 0W-20 in mine. Run Toyota filters in both.
    Not sure when the factory went to Synthetic but know my wife's 2013 used conventional from the start. I switched to Synthetic in hers because of the better cold weather flow properties, she has a tendency to light it off and pedal to the metal even in sub zero temperature.
  19. Jan 1, 2022 at 1:29 PM
    #39
    Reggie4x4
    Reggie4x4 Well-Known Member
    Cole
    07 Red TRD OR V6 M/T 4x4
    Mostly stock
    I use Pennzoil FS High Milage 5w30. OEM filters by the 10-pack. Truck is quiet, a few gear heads and mechanics have commented on it - tick aside.
    Since changing the PCV, I'd had no issues with oil loss. 5k interval unless I'm working the olde gurl hard, then ~3k.
    Figuring to buy a Fumoto valve in the future.
    Were I a richer man, I would put Amsoil in.
  20. Jan 1, 2022 at 1:40 PM
    #40
    Clearwater Bill
    Billy
    Largo Florida
    Very analytical.
    You do a taste and sniff test too, correct?
    burrito782, Sig45 and Bushed like this.
