Oil type in your 1st gen's???
Discussion in '1st Gen. Tacomas (1995-2004)' started by BislandTaco, Jan 24, 2017.
  1. Aug 29, 2018 at 5:20 PM
    #61
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I use Torco SR-1 5w30 and a wix filter in my 2.7L 3rz 2000 tacoma
  2. Aug 29, 2018 at 5:22 PM
    #62
    betterbuckleup
    Ian
    Concord, CA
    Is this a common thing that people do?
    How much does a test usually run?
  3. Aug 29, 2018 at 5:51 PM
    #63
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I don't know many people to do it, but it's a good way to really look at the health of an engine that you cannot otherwise see with physical observation. The test itself is $28, well worth it in my opinion. It can tell you if your piston components are wearing out, or your crankshafts, etc. by observing the amount of a certain metal. Or if coolant is present, usually indicated by high Sodium and Potassium.
    E30325 likes this.
  4. Aug 29, 2018 at 6:12 PM
    #64
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    I get mine tested. Trying to get extended change intervals. They noticed an increase in wear metals after my supercharger install. Too much skinny pedal I guess :burnrubber:
    QMEDJoe and BartMaster1234 like this.
  5. Aug 29, 2018 at 6:55 PM
    #65
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    2003 Std Cab 2.7L 4x4 & 2024 Off Road
    Bilstein 5100s, Deaver Leaf Springs, JBA UCAs on 2003 King 2.5 shocks front and rear on Off Road
    Saw an interesting video recently on youtube. For those in colder climates, its about four popular synthetic oils and their comparative reduction in viscocity at -40F.
    Amsoil, Mobile 1, Royal Purple and Walmart brand.
    https://www.youtube.com/watch?v=uQ_vxdO_9nc
    QMEDJoe and Luv my yota like this.
  6. Aug 29, 2018 at 8:11 PM
    #66
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    I saw that umpteen years ago, surprised it’s still around, Walmart oil did pretty bad. I loved putting Motorex 20w50 racing oil in my truck, but have to wait till warm to drive really but the motor ran sweet. Now it’s Royal or Mobil as I don’t have access to Motorex for cheap. Saved most of it for my bike.
  7. Aug 31, 2018 at 1:50 AM
    #67
    Bahamayellow
    Bahamayellow Well-Known Member
    2002 tacoma sr5
    The shop I use is a Toyota repair only and I have them put Mobil 1 with a Toyota filter. After that I ad a 1/3 to half quart of Lucas oil synthetic stabilizer.
  8. Aug 31, 2018 at 5:52 AM
    #68
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Holy thread from the dead! Anywho, I run Castrol GTX 5w-30 Conventional and either a Toyota YZZD1 filter or a Napa Gold #1348. 5.4 qts just as the book says. No need to run synthetic oil in an old engine is my opinion. You're just pissing away your money.
  9. Aug 31, 2018 at 7:59 AM
    #69
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Any reason in particular you chose to add Lucas oil stabilizer to your oil? What exactly are you trying to stabilize?
  10. Aug 31, 2018 at 6:14 PM
    #70
    smmarine
    Melbourne FL
    Synthetic has benefits for any engine no matter what age it is.
    QMEDJoe likes this.
  11. Aug 31, 2018 at 6:18 PM
    #71
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Where's the proof? My vehicle and my dads vehicles have all ran fine on conventional lubricants for a probable combined 750,000 miles or more in the past 30 years. No issues that were directly attributed from inadequate lubrication ever came up. I dont care about extended change intervals, I like working on my vehicles.
  12. Aug 31, 2018 at 6:24 PM
    #72
    smmarine
    Melbourne FL
    There’s quite a bit of proof out there, but I’m not going to cite a bunch of technical and science stuff. Extended intervals is just one of the many benefits.
  13. Aug 31, 2018 at 6:50 PM
    #73
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    I've had my truck for about 4 years. In my engine I use 5W30. I started using Royal Purple, I then tried Mobil1 due to it being so available. I just recently switched to Amsoil and I definitely noticed a difference. I did have Redline MT90 in my transmission and I really liked that but the Amsoil is a much smoother shift. When I made the switch the engine felt like it was brand new.
  14. Aug 31, 2018 at 6:54 PM
    #74
    perniva1978
    perniva1978 Active Member
    Fort Worth TX
    04 PreRunner V6 Double Cab
    Bridgetone Dueler Alenza
    Original owner here for my 2004 (purchased Dec-2003).
    Miles 0 - 60,000 Conventional 5w30 Pennzoil at dealer in California
    Miles 60,000 - 130,000 Kendall High Mileage Blend 5w30
    Miles 130,000+ Pennzoil High Mileage Blend 5w30
    Has never burned oil. Never had to add oil inbetween oil changes.
    Just need to figure out if I want to replace both valve cover gaskets...both sides have a minor leak on the lower side of each valve cover. $650 at dealer
    QMEDJoe likes this.
  15. Aug 31, 2018 at 6:55 PM
    #75
    QMEDJoe
    Joe
    How many miles were on your engine when you installed the S/C?
    Curious because that's my next mod after springs and lower control arms/ ball joints.
  16. Aug 31, 2018 at 6:57 PM
    #76
    QMEDJoe
    Joe
    Just got mine replaced a few months back due to a cracked valve cover. I paid close to a grand with labor but I needed a drivers side valve cover
  17. Aug 31, 2018 at 7:20 PM
    #77
    smmarine
    Melbourne FL
    Don’t pay a dealer to do that. It’s any easy repair.
  18. Aug 31, 2018 at 7:21 PM
    #78
    smmarine
    Melbourne FL
    70k or so
    QMEDJoe[QUOTED] likes this.
  19. Sep 1, 2018 at 2:04 AM
    #79
    crankpin
    crankpin Well-Known Member
    Crank
    Florida
    2003 PreRunner
    I am sure the 3.4 would run on Crisco or chicken fat. I have had several 1st Gens, oil change on this one, Pennzoil Gold 5W30. Dealer that installed the Michelins, did it, no issues. This is the '04. The oil change sticker, 3K miles change.
    This one had all docs since new, perfect frame, no leaks anywhere. 162344 odo,
    Runs like new.
    Crank
  20. Sep 1, 2018 at 10:19 AM
    #80
    Jay-coma
    Jay-coma Well-Known Member
    British Columbia
    i change my oil every 5000kms with what ever is on sale.I still haven't jumped on the synthetic band wagon.
