Oil Viscosity and Burning
Discussion in '2nd Gen. Tacomas (2005-2015)' started by papabear050, Mar 28, 2011.
  1. Mar 28, 2011 at 2:29 PM
    papabear050
    papabear050 [OP] Well-Known Member
    11 dc 4x4 TRD OR Auto
    So I changed the oil in an engine that takes 5W-20 that calls for 5.5 qts. But only 2 Qts come out... no leaks.
    What is the thickest engine oil you would recommend to me that won't reduce fuel efficiency that will help with the oil consumption.
    5W-30
    10W-30
    10W-40
    Maybe use the high mileage type oil.
    Any oil treatment additives anyone has had any luck with. Truck has 125K miles on it
  2. Mar 28, 2011 at 2:32 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Was it red ? You may have drained transmission fluid (common occurance among 2gen owners)
    2 qt sounds like tranny fluid, if you had 2qt in engine I am pretty sure you would have low oil pressure light on constantly. 2qt is not enough to lubricate engine
  3. Mar 28, 2011 at 2:37 PM
    papabear050
    Nope, wasn't in a tacoma. This is a general question about oil consumption. I may have posted in the wrong section however... apologies.
  4. Mar 28, 2011 at 2:40 PM
    BlueT
    NorthEast
    Oh OK post in the right forum next :p
    Also oil you seek is 5W-40 ;)
    10W-30 would be your other bet but only if car can take it.
  5. Mar 29, 2011 at 8:55 AM
    papabear050
    Thanks guys.. yeah I'm in socal so doesn't drop below 20 degrees unless up in Big Bear or Mammoth in the winter, but then I'll have my truck up there.
    I'll probably go 10w-30 high mileage next oil change, until then I'll just keep my eye on it... (Wifes Car)...
    Thanks all!
