Oil viscositys ?
Discussion in 'X-Runners' started by Big O, Mar 26, 2011.
  1. Mar 26, 2011 at 3:03 PM
    Big O
    Big O [OP] Well-Known Member
    Owen
    Dallas , Texas
    ' 06 X Runner ( Red )
    K & N Air Filter , Magnaflow Muffler , Full Synthetic Oil R/P ,block,trans & differencial , New LED taillights, TRD Short Shifter, a Boulekos Sprint Booster !
    Ok guys I know I'm really fixin' to start something here , but ,. here we go ,
    I'm old school in alot of ways , like the fact that I have pretty much used 20/50 weight in everything but my lawn motors.
    But, my owners book on my '06 X is very infatic that we have to only use 5/30 w. And in an emergence if one has to use 10/30 w. CHANGE it back as soon as you can !
    I have compromised from 20/50 to 10/30 w here in Texas and haven't seen any problems .
    What do you think ?
    Big O
  2. Mar 26, 2011 at 3:08 PM
    98tacoma27
    Ben
    Not Beech Creek
    Why would you expect problems using the recommend oil viscosity?
    I'm not sure what you getting at here.
  3. Mar 28, 2011 at 11:51 PM
    dbredleader
    dbredleader Member
    David
    Tennessee
    07 Tacoma stock
    I think I would be running 5/30 (read: am running 5/30) like the Toyota engineers recommend. Unless you want to screw your truck up:confused:
  4. Mar 29, 2011 at 12:55 AM
    Racerboy221
    Racerboy221 Well-Known Member
    Bill
    Litchfield Park, AZ
    Tacoma 2.4, Std cab/bed, 18"wheels,airshocks
    18" Wheels & Tires, Airshocks, CB Radio
    I sell AmsOil and double checked the charts we recommend for your truck and it list both 0W-30 as well as 5W-30 for the two options.
    I understand the old-school line of thinking, I used to follow that train of thought a well but have come to realize that old-school is not always the best.
    The mad scientists at Toyota are paid the big dollars to tell us what to run in the vehicles they designed. If you keep their recommendations and something goes wrong, then take it up with them through the courts.
    Good luck with your choices
  5. Mar 29, 2011 at 1:01 AM
    Schinkey10689
    Schinkey10689 Well-Known Member
    Justin
    Tampa, Florida
    09 PreRunner SR5
    Toyota just recently (I think...) started recommending using 0W-30 in most newer model vehicles due to the "green" revolution. That weight is supposed to give off less emissions.. I'm sticking with 5W-30 though cause thats what's been good to me.
  6. Apr 4, 2011 at 11:15 AM
    06RadiantRed
    06RadiantRed Well-Known Member
    CA-Bay Area
    2006 Tacoma 4x4 TRD Off Road - RadRed!!
    ICON ext. Travel Coilovers, TC UCAs, Fox 2.0 FJ Rear Shox + 2"AAL rear
    I cant give you a link to this information, just what i remember reading. But essentially, part of the reason Toyota recommends the 5-30 is because of how the engine lubrication system was designed. The size of the holes and channels requires a thinner oil to flow properly.
  7. Apr 4, 2011 at 9:08 PM
    CCCSOCOP
    CCCSOCOP Active Member
    RON
    CALIFORNIA
    06 TACOMA X-RUNNER
    XENON HEADLIGHTS, TINTED WINDOWS, BILLIT GRILL, TRAILER HITCH
    Hey Big O,
    I have to admit that I'm old school too. I've been using 20-50 Castrol for over 20 years in my two vehicles. My last one was the 1992 Toyota 4x4 with a 4-banger, never had anyproblems up to 173,000 miles - then had some minor head problems from overheating but not oil related. Did switch to the High Mileage oil after 100,000 or so. Now on my 2006 x-runner I still plan to use the same weights, Seems to work best in my climate area.:rolleyes:
  8. Apr 12, 2011 at 12:40 PM
    Big O
    Owen
    Dallas , Texas
    As we all know the first number is for the start up period the second number for actual running down the road. The chart in my manual shows the temper range for 5w is from below -5 to over 100 degrees . Here in Texas , that means over half of the time my start up temp would not be needed in that range over half the time. A lot of times my out side temp is already off this chart. They are also dropping the start up number for "green reasons". The same reasoning they tell us to NOT let the motor warm up, but pull away immediately . I don't do that ether. I give the motor the time to idle down on it's own.
    Since over half the time my running temp is off their 5/30 w chart , I will be really tempted to kick it on up to 10/40 w for my summers .
    Big O
  9. Apr 12, 2011 at 12:49 PM
    KBToyota
    KBToyota Well-Known Member
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    OME 883, 5100 all around, Wheelers 3 leaf progressive aal
    This is why the new Fords use 0w-20. Th eoil channels are so small that if you used a heavier oil you would actually starve the bearings of oil.
    Use what is recommended, they know what is best they built the damn thing.
