Oil vs. Electricity vs.Gas
Discussion in 'Off-Topic Discussion' started by 85yote09taco, Mar 5, 2012.
  1. Mar 5, 2012 at 12:49 PM
    85yote09taco
    85yote09taco [OP] Well-Known Member
    Eric
    York, PA
    Tacoma TRD OR
    3'' OME lift, TRD CAI, Built Right UCAs, 285 Goodyear DURATRACS, black steelies, Fog light anytime, DTRL, Alternating turn signal, Diff breather relocated, Carrier bearing drop, Weathertechs, Bestop, Extended SS brake lines, CBI Sliders w/kickout, Cab mount chop, Total Chaos LCA skids, All Pro skids, Satoshi(HomerTaco), Bruteforcefab ''HC'' rear bumper, Bruteforce Hybrid front bumper
    Currently I'm looking to buy a home and need some advice from people who don't have a conflict of interest. What I mean by that is there's a conflict between my girlfriend's father and I. Daddy doesn't like the location of the home I've seriously considered buying, it's in the country vs. his development.
    Anyhow, The home has CAC unit that doubles as a heat pump. Now I know that this is an ongoing debate but just need some opinions. The home is an 1100sq.ft. 3br with brand new windows roof etc etc. Totally renovated and updated.
    Now I just got off the phone with the realtor and i requested that he get the last few months heating bills because this will be the first time I would have to live with electric heat/my first home purchase. There is no one living in the home and besides some lights being flicked on for showings and the hot water heater running the bill averages around $170 a month. This is with the home set at 61 degrees.
    Now there is a few things that noticed when viewing the home that I think could make some difference such as the basement door every time I go down there is blown open, easy fix. And other small things. Right now I'm used to living in a big home oil furnace/wood stove. Now the heat is turned down to roughly 50 degrees and I chop a lot of wood needless to say. I guess what I'm getting to is that I will be saving money/my time by moving to this home. Oh yeah, Daddy has been nit picking everything in this home as I value his opinion I know deep down he doesn't want us to get it.
  2. Mar 5, 2012 at 1:07 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Regardless of what you choose, I'd strongly recommend programmable thermostats. They can make a huge difference in your heating costs if you set them up correctly.
    You'll have to look into what's available in your area and what the costs for each type of system are. As far as I'm concerned, it's a tough debate to definitively say one is better than the other because different systems have different pros and cons, efficiency, etc. I have propane for my stove and dryer, oil for the hot water and heat (tankless) and no electric heat. I like the hot water heat, if you can find old cast iron radiators, I still think they're one of the best ways to heat a home. My old townhome had natural gas and I didn't not the forced hot air heat. It was miserably dry and if the system isn't properly balanced, one side of the house ends up freezing cold and the other side is boiling hot.
  3. Mar 5, 2012 at 1:14 PM
    fadippides
    fadippides Well-Known Member
    NEPA
    12 TRD Off Road
    The heat pump will kill you below about 25 or so degrees....I dont think its that frequent in York
    My living more north is:
    NG>Geothermal>Pellet>wood>Heat Pump>Electric>Oil>Propane
    I have geothermal and a pellet stove. Do you plan to try and power the heat pump if the power is out for an extended period?
  4. Mar 5, 2012 at 1:16 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Lol
    Geothermal > Wood > everything else
  5. Mar 5, 2012 at 1:21 PM
    fadippides
    NEPA
    12 TRD Off Road
    I still use my Pellet stove quite a bit...It works out cheaper and isnt much extra work. It depends on your electricity rate. For my setup the geothermal uses a 375ft well so it has to draw that water up, then extract the heat. Its still cheap, maybe even slightly cheaper than NG.
    The problem is, during a power outage I would need a monster generator to handle the surge of the unit and the well so I opted for a pellet stove supplement.
  6. Mar 5, 2012 at 1:33 PM
    OZ-T
    Peter North
    British Columbia
    I get free wood
    Does your pellet stove hopper work with no power ?
  7. Mar 5, 2012 at 1:38 PM
    fadippides
    NEPA
    12 TRD Off Road
    Nothing can compete on cost with free wood and a healthy back ;-)
    The hopper and fan for the stove need power. If the power is cut, some smoke will come though the hopper to the house. I had a generator switch wired this summer and plan on tying an inverter and 12v to the switch box to use the stove when a generator would be off.
    If the OP gets a heat pump, for most cases it will be fine, but can always be supplemented with a pellet / wood stove for the coldest of days.
  8. Mar 5, 2012 at 2:36 PM
    OZ-T
    Peter North
    British Columbia
    :thumbsup:
  9. Mar 5, 2012 at 3:06 PM
    85yote09taco
    Eric
    York, PA
    Tacoma TRD OR
    I appreciate the replies, and yes there is a few months in the year that I can see below 25degrees. I'm still considering a wood stove for the basement as that is where the chimney inlet is located. I have enough money saved that even after the purchase of the home I should be fine to look into a stove come fall. I'm not really that concerned as I've talked to quite a few people on there experiences. I'm really not sure but someone told me that electric heat and a heat pump are not the same thing so....maybe I'm asking all the wrong questions??
  10. Mar 5, 2012 at 3:10 PM
    85yote09taco
    Eric
    York, PA
    Tacoma TRD OR
    Also this winter in PA has been very mild and I was just wondering how much worse can the heating bill reach when/if we get slammed next winter?
  11. Mar 5, 2012 at 4:53 PM
    fadippides
    NEPA
    12 TRD Off Road
    Electric heat typically refers to baseboards. Its 100%efficent but your size house might be $400 /mo. A heat pump should by under $250 a month. If it gets too cold and the heat pump uses emergency heat (basically the electric restistance) you meter will be spinning rapidly. Id have no problems with a heat pump around york as long as I had a backup for when the temp is really low. It also may be hard getting heat out of that basement
  12. Mar 5, 2012 at 5:01 PM
    85yote09taco
    Eric
    York, PA
    Tacoma TRD OR
    Cool that's what I was thinking but thanks for the clarification. thanks for the input!
    +1 Rep
