oil weight, 0W-20
Discussion in 'Technical Chat' started by DanGer, Mar 16, 2009.
  1. Mar 16, 2009 at 11:22 AM
    DanGer
    DanGer [OP] Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    My owners manual for my '07 2.7L I4 5 speed recommends either 0W-20 or 5W-20. I have always thought that 0W-20 would be slightly better than running water (exaggeration but you get the point, I hope). So Since getting my truck about 6K miles ago, I changed it with Penzoil Platinum 5W-20. Now I took advantage of the Autozone Mobile 1 5 qt plus filter deal. I was wondering what exactly the pros and cons are of 0W-20 vs 5W-20 are. I know you get better fuel economy with 0W-20 but are you sacrificeing protection with it? How does temperature affect them. In the winter one mechanic told me to run 0W-20 to help with ignition but I have never had any issues
  2. Mar 16, 2009 at 11:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The 0w-20 will flow slightly better in 32* conditions on start up. When up to operating temp, they are both a "20" weight.
  3. Mar 16, 2009 at 11:26 AM
    DanGer
    Ok so would it be bad if I got 5 qts of 0W-20 of mobile1 in stead of 5W-20, especially with summer coming?
  4. Mar 16, 2009 at 11:32 AM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    I've used 0W-40 in my race mower, which I know isn't a truck, but we run the engines 2 times as fast as designed for. It makes a big difference and the engine runs a lot cooler and better. As for my truck, I've always just run 10W-30.
  5. Mar 16, 2009 at 11:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes, you will be fine.
    The old 2.7 is recomended to be run with 10w-30. The new one uses a thinner oil.
  6. Mar 16, 2009 at 11:41 AM
    DanGer
    chris if i didnt think my questions might help someone else out I would just pm you directly haha
  7. Mar 16, 2009 at 11:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats what the board is for. :proposetoast:
  8. Mar 16, 2009 at 1:51 PM
    BUK 0H5
    BUK 0H5 Still For Sale
    Queen Creek, AZ
    Silver 09 2.7L Manual AccessCab SR5 PreRunner
    Removed Mud Flaps, Suspension TSB, 5100's all around, JVC KW-AVX710 Head Unit with Metra surround.
    Well considering that a viscosity of 0 is equal to the viscosity of water you are pretty much spot on there. The difference is that water is corrosive while oil has better lubricating properties. Like Chris said though the only real diff between 0-20 and 5-20 is when the oil is cold. You will get easier flow out of the 0-20 at start up, which may improve your gas mileage and hp a tiny bit by making it easier for your engine to turn your oil pump, but once they reach operating temp they are the same.
  9. Mar 16, 2009 at 2:41 PM
    DanGer
    Thanks for the input! I guess the only question I have left is why would anyone run 5W-20 instead of 0W-20? It seems the me (in my truck where I have the option for either) that there is no benefit to running the 5W. I'm not asking why oil companies make it, I know some vehicles require it, but why would they mention it in my manual? Easier to locate when you need a change?
  10. Mar 16, 2009 at 2:44 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    5w20 is available in 5 qt jugs from walmart and other stores. That saves you a few bucks, plus it is easier to find.
  11. Mar 16, 2009 at 2:50 PM
    DanGer
    Ya I put in the penzoil 5 quart last change, but I picked up five quarts of 0W-20 plus the mobile1 filter from autozone for $30. No huge desire for the filter but hell, its going on my taco
  12. Mar 16, 2009 at 2:57 PM
    OU812
    OU812 ban the term murdered out
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    Nothing yet, brand new!
    Do they not provide a graph in the owner's manual for different climates? That is my understanding when the engineers provide another oil viscosity in the book.
    I run the 5W30 Castrol syntec in my motor all year. But it's the V6.
    On real cold mornings I have not heard any adverse valve noise on initial startup so they know what they are talking about regarding oil weight.
    I have sat in on conference calls with service engineering at work and the Mobil 1 0-40 is reported to reach the valvetrain in less than 2secs at -30F on our motors on initial cold start.
  13. Mar 16, 2009 at 3:01 PM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    Toyota says to use 5w30 for year round protection in the v6. I would continue to use what you're using now. Synthetic does flow much better in extreme cold than the dino oils do. JMO.
  14. May 1, 2009 at 7:35 PM
    Makana
    Makana Well-Known Member
    HAWAII
    07 4X4 SR5 TRD OR
    6" VSC FABTECH, Dirt Logic, Light Racing UCA, Moto Metal 955's, Mickey Thompson Baja MTZ
    X2
  15. May 1, 2009 at 7:41 PM
    JAG
    JAG Well-Known Member
    Ha ha. Thats what I do...just pm. Chris is the go to man for just about any tech question.
    Thanks Chris! :rolleyes:
