oil weight debate
Discussion in '4 Cylinder' started by PeterNM, Feb 9, 2009.
  1. Feb 9, 2009 at 10:08 AM
    PeterNM
    PeterNM [OP] Active Member
    New Mexico
    97 Tacoma LX, 4X4, 248,000m
    AFE Drop-in
    my 97 has 170K on it. the engine is emaculate....the person i bought from was a toyota guy(fj's)...but the oil he used: rotella 5w-40. any thoughts...the pros, the cons.....so far i've one bud who said it's great because that oil has more detergent in it and will keep the engine clean....
  2. Feb 9, 2009 at 12:09 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    Rotella is generally a diesel engine oil. I used it in my race bike for 2 years (constantly seeing 13k rpm) and the engine internals looked great after the first season! I havent used it in my Tacoma yet, Im going with 5W30 Mobil One now.
  3. Feb 9, 2009 at 1:27 PM
    dually
    dually Low and slow
    +1. Why change what works?
  4. Feb 9, 2009 at 4:41 PM
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    02 4runner 04 solara
    4runner-32x11.5x15 falken rocky mt, tundra king 2.5 coilovers with taco perch, TC UCA, OME rear springs and procomp es9000's, thule roof rack.
    i just started using the high mileage 10w-30 valvoline for the taco. it sounds great and doesnt have as much of the noises on start up. if anything, up the thickness of the oil, but stick with the manufacturer
  5. Feb 10, 2009 at 9:53 AM
    PeterNM
    New Mexico
    AFE Drop-in
    thanks for the feed back....i'll keep using rotella.....any theories on using oil that's not the recommended.
  6. Feb 10, 2009 at 10:12 AM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    Frequency of oil changing has more to do with keeping the engine clean than anything. If you change it every 3k, then there's less chance that acids and sludge will build up in the oil. I've used straight 10w-30 the entire 217,000 miles I've owned mine, but recently went to 10w-40 since the engine seems to run a bit smoother on a heavier oil. Probably because of wear.
  7. Feb 13, 2009 at 6:51 AM
    wawireguy
    wawireguy Well-Known Member
    Use what the manufacturer specs.. These small 4cyl are being made to use the lighter 5w20, 0w20 oils.
