Oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by accesscab, Dec 31, 2010.
  1. Dec 31, 2010 at 4:48 PM
    accesscab
    accesscab [OP] Well-Known Member
    Scott
    tennessee
    10 prerunner TRD off-road
    Which is best to use, regular 10w-30 or fully synthetic? I used fully synthetic the last time, but because of the price was wondering if regular would work. Or is there any major differences?
  2. Dec 31, 2010 at 4:54 PM
    accesscab
    Scott
    tennessee
    Can regular be put in after synthetic has been in it?
  3. Dec 31, 2010 at 4:58 PM
    accesscab
    Scott
    tennessee
  4. Dec 31, 2010 at 5:08 PM
    accesscab
    Scott
    tennessee
    I said 10w-30, I meant to say 5w-30. lol Just clearing that up.
  5. Dec 31, 2010 at 6:01 PM
    pinktaco808
    pinktaco808 Hot Steppa
    anykine as long as you change every maintenance required for it.
  6. Dec 31, 2010 at 6:04 PM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    5w30 mobile1 at walmart + a toyota oil filter for 6 bucks it can be done for under 30 bucks.
  7. Jan 1, 2011 at 3:01 AM
    Potomac30
    Potomac30 Member
    SC
    2011 PreRunner
    5W30 Mobil Clean 5000 at walmart + a toyota oil filter for 6 bucks it can be done for under 18 bucks.
    If you're changing it every 5K miles, regular oil will be fine.
  8. Jan 1, 2011 at 6:03 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Conventional oils have been very good for a long time but the newer SM and SN grade oils are just so damn good the only advantage synthetic oils offer are long service life.
    So I'd say only use synthetic if you're planning on extended drain intervals (~10,000 miles). If you're draining at the 5,000 mile recommended interval or especially if you just can't shake the myth and still think 3K is good use conventional as synthetic will be a complete waste of money.
