Oil..
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Clayton909, Aug 15, 2016.
  1. Aug 15, 2016 at 3:18 PM
    Bagow
    Bagow Well-Known Member
    Arizona
    2016 DCSB OR 4x4
    You've just proven my point. Oil should be chosen based on environmental conditions. Not what Toyota says.
  2. Aug 15, 2016 at 3:22 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
  3. Aug 15, 2016 at 3:25 PM
    Clearwater Bill
    Billy
    Largo Florida
    Again, not sure if you are talking to me, but I'll assume yes, and that you have issue mastering the quote feature.
    I don't have a '16. I use what my vehicles calls for, except for choosing synthetic over dino, to extend OCIs safely.
    You might enjoy some reading over at bobistheoilguy.com. But probably not.
    Has anyone at your work ever commented about your 'but we've always done it this way' frame of mind? :p
  4. Aug 15, 2016 at 3:31 PM
    Bagow
    Arizona
    2016 DCSB OR 4x4
    There, I quoted you. Are you happy now. If there was a lower viscosity oil readily available Toyota would have gone with that to get their numbers up. This is not rocket science. I've done my oil research and bob is not the only oil guy. Common sense is not very common now days.
  5. Aug 15, 2016 at 3:35 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    My truck currently has 5w20 Kendall synthetic in it. Made NO difference in fuel economy. Made NO difference in the way it performs.
  6. Aug 15, 2016 at 4:09 PM
    taco_mac
    taco_mac Well-Known Member
    Nomadic
    2017 TRD Pro MT
    Did you uncover something interesting?
    Motorshooter likes this.
  7. Aug 15, 2016 at 4:13 PM
    Element
    Element Well-Known Member
    Mass
    2016 Limted Trade for 2017 F 150 Lariat 3.5 Twin Tubro
    You should go to (bobistheoilguy web site). Everybody has a theory what to use and not use. That being said it is a cool web site.
    FritoBandito likes this.
  8. Aug 15, 2016 at 4:21 PM
    Qwntm
    Qwntm Well-Known Member
    Edward
    Boise, ID
    2016 Inferno TRD Off Road DCSB
    None...yet!
    I was suspicious of the 0w20 stuff too... Coming from 1960's straight 6's that ran 500,000+ miles with 10w40 it seemed to me that thicker was always better. (And in the 1960's it probably was!) But after reading this:
    http://bobistheoilguy.com/motor-oil-101/
    I will run the 0w20 Mobile 1 and not worry about it. I am even going to extend the oil and filter changes to 5,000 mile intervals.
    But the choice is yours.
    FritoBandito and tomwil like this.
  9. Aug 15, 2016 at 4:23 PM
    Aussiek2000
    2016 Offroad AC
    There isn't anything from the 60's that went 500k.
    Kilokato likes this.
  10. Aug 15, 2016 at 4:29 PM
    Aussiek2000
    2016 Offroad AC
    The part people forget is that engines use oil. Some use more than others. Think it's VW, that's acceptable to burn a quart per 1000 miles. So on that 10k mile oil changes, it would be acceptable to basically change it twice by adding 10qts of oil as it burns it
  11. Aug 15, 2016 at 4:47 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Good thing I do not own a friggin' VW...!!!! :eek:
  12. Aug 15, 2016 at 4:48 PM
    Aussiek2000
    2016 Offroad AC
    That was just an example. Most manufacturers spec a quart per 1000-2500 miles. Although 99% of them never use that much.
  13. Aug 15, 2016 at 4:48 PM
    Rambeaux
    Rambeaux Diäb soulé
    Jerkwater, USA
    2016 Blk TRD Sport 4X4 DCSB
    Cracked W/S
    Dafuq?o_O
    You just wanted to use that gif, didn't you?
    Qwntm likes this.
  14. Aug 15, 2016 at 4:57 PM
    over60
    Muskoka, Ontario
    Damn...Is that a hand or a foot up her "cooch"..?? Don't look too cumfy to me..!
  15. Aug 15, 2016 at 5:02 PM
    #35
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    Another oil thread. So the 3rd Gen engine has higher build tolerances than the 2nd Gen engine? Your telling me they changed the engine that much in this thread and in other threads you are telling me they are still using the 2nd gen leafs.
    It's not my rig so put whatever you want in it, if you don't want to listen to what the manual states. Take some of the oil you have in it now and send it off to the lab. Then with the 5w-20, at that oil change interval send it into the lab.
    ____
    I am not a 3rd gen but I run 5w-20 fine.
  16. Aug 15, 2016 at 5:33 PM
    #36
    taco_mac
    Nomadic
    2017 TRD Pro MT
    Thx for sharing the link, some good reading there! I enjoyed being schooled a bit on what I thought I knew about oil.
  17. Aug 15, 2016 at 6:10 PM
    #37
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    I would be happier using 5W20 regular or semi-synthetic oil than full synthetic 0W20 as is cheaper and I prefer to change my oil at 5mo/5k intervals, because of condensation and sludge build up.
    But Toyota is not giving much leeway or guidance for some reason, so I’ll do mine every 6mo/7-8k as per manual pg 571.
    And the only real reason I see in difference over the previous 4.0L is the following “The Variable Valve Timing-intelligent Wide (VVT-iW) system is used. This system is operated by the
    engine oil.”
    Hope that helps
    Cheers!
  18. Aug 15, 2016 at 6:12 PM
    #38
    Aussiek2000
    2016 Offroad AC
    They are only so stringent because they have CAFE standards to meet.
    The hammer likes this.
  19. Aug 15, 2016 at 6:18 PM
    #39
    dmharvey79
    dmharvey79 Well-Known Member
    Dennis
    Northern Virginia
    Don't over-think it, we're not driving vehicles with high performance engines...hence the lead-way mentioned above.
  20. Aug 15, 2016 at 6:26 PM
    #40
    The hammer
    Yeah, but you don’t get that much better mileage with 0W20 vs 5W20 that I can measure, but I guess a 10th must be a big deal, or so I’ve heard.
    But I also think they all seem to be competing for that cost of ownership maintenance expense and they’ve done away with lot of other things like pcv valve changes, longer filter life and such. That seems to be a big deal also and maybe oil is a victim of that too?
    IDK I wish I knew more though so I could decide without worries…
    http://www.consumerreports.org/cro/2012/12/what-that-car-really-costs-to-own/index.htm
