Oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Justiced2245, Jul 7, 2020.
  1. Jul 7, 2020 at 6:48 AM
    Justiced2245
    Justiced2245 [OP] Member
    Justice
    2008 tacoma dc TRD
    Leveling kit
    My 2008 v6 4.0l has 102,900 miles on it and I was thinking of going to 10w 30 instead of 5 w 30. What do you guys think?
  2. Jul 7, 2020 at 6:50 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Why?
    Unless you have a specific reason to change you won't be seeing any marked benefit to that change... Short or long term.
    Skydvrr, ToyoTaco25 and suaveflooder like this.
  3. Jul 7, 2020 at 6:54 AM
    Clearwater Bill
    Billy
    Largo Florida
    Does your owners manual say bump up the oil viscosity every 100k or so?
    Time saving tip; no, it doesn't.
    Blockhead, Sig45, 4x4spiegel and 4 others like this.
  4. Jul 7, 2020 at 7:49 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Wouldn't do it.....might cause oil leaks. Just make sure you change the oil regularly!
    Justiced2245[OP] likes this.
  5. Jul 7, 2020 at 8:05 AM
    cwadej
    cwadej Ballerina Award winner
    Right Here
    2011 Access Cab 4x4
    I'l assume you are either an lubrication engineer and have had the engine torn apart and all dimensions mic'ed,
    OR
    You torn the engine apart and mic'd all parts and know the new clearances, and a lubrication engineer recommended changing to heavier oil.
    So, since you obviously have solid engineering advice for the change, go for it.
  6. Jul 7, 2020 at 8:06 AM
    Justiced2245
    Justice
    2008 tacoma dc TRD
    Leveling kit
    I just know a couple of people that do it with theirs. They said it causes less wear and lubes everything better. Don’t know if that’s true or not.
  7. Jul 7, 2020 at 8:10 AM
    cwadej
    Right Here
    2011 Access Cab 4x4
    On what do you base their expertise? Their training and experience engineering and rebuilding engines, or their training and experience as lube engineers?
    How do they know it causes less wear and lubes better? They must have torn down the engine and measured all moving surfaces before and after changing oil, right?
    whatstcp likes this.
  8. Jul 7, 2020 at 8:11 AM
    WSW3
    WSW3 @willwitecki
    Will
    Connecticut
    '08 Tacoma DCSB TRD Sport
    Scratches, dents, and a lot of miles
    Don't re-invent the wheel here. Many Toyota engines go for a lot of miles going according to the manual - there's probably a reason for it.
    I'm at 230k with changes every 5k. I think the engine is just about broken in now.
  9. Jul 7, 2020 at 8:12 AM
    memario1214
    Colton
    Missoula, MT
    MAYBE broken in. Maybe :thumbsup:
  10. Jul 7, 2020 at 8:13 AM
    Justiced2245
    Justice
    2008 tacoma dc TRD
    Leveling kit
    I didn’t get on the form to be questioned. I came and asked a question to just get opinions on something I wanted to know. Prick.
    Jimmyh likes this.
  11. Jul 7, 2020 at 8:19 AM
    cwadej
    Right Here
    2011 Access Cab 4x4
    I'm not questioning you, I'm trying to get you to think.
    Seems I hit a nerve, which shows me you realize your buddies have the same qualifications to determine engine oil specs for your engine as you do to perform the math required to get two satellites in the same orbit at different speeds but never meet.
    Skydvrr and 0xDEADBEEF like this.
  12. Jul 7, 2020 at 8:20 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Stick with REGULAR 5w-30 or 0w-30 synthetic or dino oil... when i say regular for the love of god, no "high mileage" oil please.
  13. Jul 7, 2020 at 8:21 AM
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Don’t do it. Stay 5W30
  14. Jul 7, 2020 at 8:23 AM
    memario1214
    Colton
    Missoula, MT
    Just some advice from someone who has been around here for a minute or two. Try not to let an individual comment strike you too hard. It's not a shot from him towards you directly, I almost promise that. We just see and hear a lot of "stuff" here, and everyone has their triggers. Just try and post up how big of tires you can fit without lifting your truck next, and watch the dumpster fire ensue. It's all good man :thumbsup:
    Jimmyh, Skydvrr, ToyoTaco25 and 3 others like this.
  15. Jul 7, 2020 at 8:24 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    The 'increasing viscosity' hack is something that dates back to 70s and earlier engines when a slight increase in viscosity would help take up some of the wear between various surfaces. With the the improvements in production, better metallurgy, and reduced tolerances in modern engines, this is no longer necessary or desirable.
    winkel, henryp and Crow Horse like this.
  16. Jul 7, 2020 at 8:24 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Nevermind that they're asking questions that they think will help you. Sheesh.
    Pinay likes this.
  17. Jul 7, 2020 at 8:35 AM
    ardrummer292
    ardrummer292 500k or bust
    Austin
    ESVA
    2015 DCLB V6 A/T 4x4, 2011 Camry LE
    Overbuilt daily driver
    I put some of the Mobil 1 "extended performance" 5W-30 in mine last oil change. Is that the type of oil you're talking about? I haven't heard of any issues with high mileage oil, which is why I ask.
  18. Jul 7, 2020 at 8:38 AM
    memario1214
    Colton
    Missoula, MT
    I'm no oil expert, but I truly have never heard of "high mileage" or extended life variants of oil creating any sort of issues. I figured that they were pretty much all the same, and it was just marketing magic :notsure:
    Skydvrr and ardrummer292[QUOTED] like this.
  19. Jul 7, 2020 at 8:41 AM
    ardrummer292
    Austin
    ESVA
    I went with Mobil 1 synthetic because I heard it's one of the best options out there to protect the engine. I'm happy to be educated/proven wrong. Egos heal, trucks don't.
    henryp likes this.
  20. Jul 7, 2020 at 8:43 AM
    memario1214
    Colton
    Missoula, MT
    You'll be perfectly fine with what you put in. Don't sweat it :thumbsup:
    ardrummer292[QUOTED] likes this.
