Oil
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mmuy, Sep 18, 2022.
  1. Sep 18, 2022 at 9:01 AM
    #41
    mmuy
    mmuy [OP] Well-Known Member
    Tacoma TRD PRO white 2018
    Got it to the middle of the two dots at cold. Thank you for some people who answered my question. And no thanks for the “its friday” people ✌
  2. Sep 18, 2022 at 9:03 AM
    #42
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
  3. Sep 18, 2022 at 9:18 AM
    #43
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    Maybe; today on a different thread regarding cat shields, someone asked if they could still get to the engine oil drain plug with a cat shield in place. I think both questions qualify as "Friday questions".
  4. Sep 18, 2022 at 9:27 AM
    #44
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    New 0W-20 is quite clear, the stick is shiny and can be difficult to read.
    You can gently scuff the normal zone with Scotch Brite or very fine sandpaper - lightly, just enough to give the stick a matte finish.
    OldSaltyDog and AxisCab like this.
  5. Sep 18, 2022 at 10:01 AM
    #45
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Check mine every couple weeks. To make it easier to read scuff up the dip stick between the 2 marks with a file or sand paper in a X pattern. Pull the stick out and wait a couple minutes for the oil you just dragged up the tube to go back down before reinserting to get the reading. Just curious... is engine oil supposed to be red? :eek:
  6. Sep 18, 2022 at 10:16 AM
    #46
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    I check mine ever time I check the airfreshener levels which is every day. Its wise to also check the blinker fluid level on the regular as well. I had a catastrophic blinker failer once, never again :p
    wrightme43 likes this.
  7. Sep 18, 2022 at 10:19 AM
    #47
    Horseshoez
    Dale
    Maryland
    Agreed, running out of blinker fluid is nearly as dangerous and driving while intoxicated.
    Slick Taco[QUOTED] likes this.
  8. Sep 18, 2022 at 1:24 PM
    #48
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    What do have against friday?
  9. Sep 18, 2022 at 1:27 PM
    #49
    zoo truck
    None
    Thats why you need at least 10k to read the dipstick well.
    RIX TUX likes this.
  10. Sep 18, 2022 at 1:33 PM
    #50
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    what other option do you have? drain it and measure? glass oil pan?
    Travlr likes this.
  11. Sep 18, 2022 at 1:48 PM
    #51
    pltommyo
    pltommyo Well-Known Member
    Tom
    2016 Gray Tacoma TRD Offroad
    SSO hybrid bumper, Warn winch, RCI skid trilogy, RRW sliders, everything in the cheap/free mods thread, and of course the frame recall work.
    You telling me that in 70 years you never learned about sarcasm??
  12. Sep 18, 2022 at 1:52 PM
    #52
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    This lazy fucker never checks it!
  13. Sep 18, 2022 at 1:53 PM
    #53
    5465
    5465 Well-Known Member
    South
    2023 TRD Ex Cab
    I have a guy that checks it for me and I suspect the 2nd Gen peeps could be right.
  14. Sep 18, 2022 at 2:02 PM
    #54
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    No, what's that?
    (sarcasm)
    pltommyo[QUOTED] likes this.
  15. Sep 18, 2022 at 2:06 PM
    #55
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Well, can they? :popcorn:
    Horseshoez[QUOTED] likes this.
  16. Sep 18, 2022 at 2:18 PM
    #56
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Only one way to know, obviously you should drain your engine into a measurable container and see for yourself. Sounds like a great way to spend a Sunday, a Friday, or any other day of the week.
  17. Sep 18, 2022 at 2:27 PM
    #57
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
    I check all fluids once a month, just to keep tabs on what's what. But not ATF, not yet.
  18. Sep 18, 2022 at 3:17 PM
    #58
    OldSaltyDog
    OldSaltyDog Well-Known Member
    Hampton Roads VA.
    2022 DCSB Limited Nightshade Edition in Magnetic Grey
    None to speak of, just enjoying it for the moment.
    Probably an obvious question but is your truck resting on level ground?
  19. Sep 18, 2022 at 4:05 PM
    #59
    mmuy
    garage. I think its level as can be. Took out 900cc then its at the center of the two dots
  20. Sep 18, 2022 at 4:29 PM
    #60
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    I bought a Toyota so I didn't have to check my oil.
    OldSaltyDog likes this.
