Ok.... All I want is remote start & keyless entry
Discussion in '2nd Gen. Tacomas (2005-2015)' started by soilsample, Dec 30, 2009.
  1. Dec 30, 2009 at 8:43 AM
    soilsample
    soilsample [OP] Well-Known Member
    Donald
    Southwest Louisiana
    '09 4x4 Double Cab
    I don't need the alarm features. Don't want to spend a ton of $$$ on alarm that I don't need.....
    I do want 2 way system.
    I've installed dozens of audio systems and I'm comfortable removing interior parts from my truck.
    What system should I buy, and can I expect to install it myself without ruining my truck????
    I've searched and read dozens of posts, but would still appreciate input on specific models and prices.
    Thanks
    Donald
  2. Dec 30, 2009 at 8:54 AM
    JTech
    JTech Well-Known Member
    Phoenix, Arizona
    Silver 09 Double Cab 4x4 Sr5 Off-Road
    Locking Bed Boxes, built in air compressor, Husky Liners(not really a mod but I love them)
    I installed one myself on my old truck(1st gen) it wasn't that hard if youvfollow the instructions.I would say no harder than putting in a new stereo. As to which one to get I don't know I don't keep up with them anymore
  3. Dec 30, 2009 at 9:00 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2009 DC V6 TRDsport
    5100's all around - fronts at 1.75", 265/70/17 Bridgestone Revo 2, HID headlights and fog lights, factory skid plate, ss exhaust tip, tube steps, Access roll-up tonneau cover, Redline hood struts, 6 D-rings, seat MagLite, LED dome, fumoto oil drain, DTRL, fog light anytime, Kenwood/Clarion speakers, Pop-N-Lock 5300, LED bed lights and a few other things...
    Subscribed as I'm interested as well.
    I have heard it gets tricky with chipped keys and you have to install a system that overrides it. The other solution (and one that I would probably go with) is to secure the gray valet key somewhere near the column so the ignition is always activated.
    With this setup, you can start the car remotely because the column picks up the signal from the valet key. Have heard this is cheaper and easier to install.
  4. Dec 30, 2009 at 10:00 AM
    soilsample
    Donald
    Southwest Louisiana
    '09 4x4 Double Cab
    I'm considering buying a Viper 5901 system or a Python 991 and only using the features that I need.
    I see these systems on some online stores for around $250.
    Is this price "too good to be true"?
    I suspect that I'd have to add the cost of the key bypass module or just use my vallet key.
  5. Dec 30, 2009 at 10:03 AM
    CAMZTRD
    CAMZTRD Well-Known Member
    steve
    hampton, va
    2006 DC TRD Off-Road 4x4
    billy 5100's @ 2.5 w/ 1/4 spacers, toytec aal, LR UCA's, revotec headlights,revotec taillights, lamin-x fogs, color matched grille and rear bumper, undercover, bed-extender, black nerf bars, scan gaugeII , afe drop in, 50 series flowmaster, 6000k bi-xenon hids, more to come.......
  6. Dec 30, 2009 at 10:25 AM
    stang88
    stang88 Well-Known Member
    I do remote start installs for a living.... get either a viper or python system... they do cost a little more but the quality is top notch.... are you planning on doing the install urself?.. if so.... pm me ur yr make and model a nd ur email addy and ill send ya wiring info.... if you are having a shop do it make sure they solder the wires.. that insures no problems down the road.
    also make sure they are using a directed bypass module "pkall". so far thats the best bypass i have come across.
    you should be able to get a remote start and keyless installed for under $300.
  7. Dec 30, 2009 at 1:40 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    I have a question for you. What is the maximum distance a chipped key can be away from the ignition and still allow a non chipped key to start the truck?
    The reason I ask is my valet key was placed somewhere under the dash when my remote start was installed. I assumed that this meant the immobilizer was disabled and therefore I had a normal non chipped key cut as a spare. The non chipped key would not start the truck even though my valet key was underneath the dash and allowed my remote start to operate.
    Next I took one of my chipped keys and held it next the the ignition as I again tried to start with a non chipped key - no go. Engine would turn but not fire.
    I never could get the non chipped key to start the truck, even with the valet key underneath the dash and another chipped key held next to the ignition.
    I'm just curious how the system works.:eek: :D
  8. Dec 31, 2009 at 5:37 AM
    Veccster
    Veccster bass turds
    Eric
    2009 DC V6 TRDsport
    Wow...thank you for sharing your experience. I am listening anxiously as I have heard that holding the key next to the ignition will work.
    Did you try holding your other keys to that area? Maybe your valet key is bad.
  9. Dec 31, 2009 at 5:49 AM
    TACOFEAVER
    TACOFEAVER Well-Known Member
    Newfoundland, Canada
    09 SR5
    3" lift, and 265 75 R16 Trxus M/T's enroute. (to be installed in about 2 weeks)
    The valet key in the dash is the process our dealer uses. There is a wire run from the key (hidden somewhere in the lower dash) up and around the ignition tumbler. Autostart is the brand autostart.ca we use and find it great. Having it installed is likely a good idea if you're still under warranty, however it does take a tech. about 3 hours to install. we use the 1-way
    Good luck with it!
  10. Dec 31, 2009 at 6:11 AM
    Fortech
    CANADA
    Yup an the Autostart brand is what is installed on mine as well. We also had one installed on our 2004 Accord, and most recently our 2009 CRV.
    This is the first vehicle I had the pleasure of having a remote start, but hopefully not the last!
  11. Dec 31, 2009 at 6:12 AM
    Fortech
    CANADA
    My Valet key is in the dash in the bypass module. I tried both master (black) keys without success.
  12. Dec 31, 2009 at 6:30 AM
    Octane151
    Octane151 Well-Known Member
    Virginia Beach
    2009 4WD DC LB Silver
    Bilstein 5100 3" lift, Viper SmartStart, Pioneer AVIC-Z140, XM, Licence plate cam, PAC steering wheel control, ID XS65's, ID CTX65's, IDQ10 D4v3, Alpine PDX-4.100, Alpine PDX-1.600, Custom amp board and sub box, 3M Tint, step bars, BHLM Projector coversion w/ 5Ks, Redline hood struts, Weathertech Digital floor mats, hardshell bed cover
    I'm not sure if anyone is interested in this as it's a bit pricey ($500) and requires an annual service... but a cool option for iPhone users. Plus, it utilizes Viper systems.
    http://www.viper.com/smartstart/
  13. Dec 31, 2009 at 6:43 AM
    stang88
    back in "the day" thats how remote starts were done.. a chipped key is placed in a box under the dash.. there is a antenna ring around ur ignition cylinder that when you remote start it.. the code from the key inside the box is sent to that ring and the computer picks it up.... i would recommend taking it to a shop and have them put in a "data" b ypass module... they are very reliable and you will get ur key back... the non chipped key will not start the vehicle.
  14. Dec 31, 2009 at 6:46 AM
    stang88
    they should never use the valet key under the dash nowadays.... the only reason they do is cuz its a much cheaper option for them.... 3hours to install?... jesus.. i can do 4 tacoma's in 3 hours.
  15. Dec 31, 2009 at 7:29 AM
    soilsample
    Donald
    Southwest Louisiana
    '09 4x4 Double Cab
    Thanks for all the replies!!!!
    Is there a good 2 way system for remote start & keyless entry?????
  16. Dec 31, 2009 at 8:22 AM
    stang88
  17. Jan 10, 2010 at 5:45 AM
    drameden
    drameden New Member
    Stang88. I see you are in KC area. Looking to have a Viper 5501 or 5901 installed in a Honda CRV. Please PM me drameden@kc.rr.com if you are able to do this and discuss price/options. Thanks.
  18. Aug 24, 2010 at 12:55 AM
    duckdoctor
    duckdoctor Active Member
    Arkansas
    08 Tacoma 4X4 Off Road Package
    Smittybuilt bull bar, KC lights, window tint, aux reverse lights, camper top, Husky Liner floor mats, Sony Explode cd player, debadged
  19. Aug 24, 2010 at 7:51 AM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    already sold my Viper 5900 2way remote start/security alarm...upgrading and about to install Viper Smart Start for Android OS SP...:D
  20. Aug 24, 2010 at 7:56 AM
    pinktacos
    pinktacos Active Member
    so-cal
    07 cheap taco
    about 800 ft. if you do the c3-rs730lcd it can go about 1200ft, the c3-rs915lcd is close to a mile range
