Ok... Here is what I want to do. Will it work?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mar322, Jan 30, 2013.
  1. Jan 30, 2013 at 8:35 PM
    Mar322
    Mar322 [OP] Well-Known Member
    Cincinnati
    2013 4x4 Mag Grey DC SB
    Stock for now
    I have been looking on various websites along with help hereand have come up with the following.
    Billstein 5100's
    2"AAL
    17" ATX Artillery Teflon -12 offset 4.52 BS
    If I was willing to go with a quality spacer of an inch or so could I run say a 285 70 17? If a little bit of plastic needs to be trimmed so be it... I don't want to start cutting or flattening metal tho.
    Thanks for any advise
  2. Jan 30, 2013 at 8:42 PM
    seric007
    seric007 Well-Known Member
    depends on what you set the 5100's. 4.5 backspacing is where you want to be. rubbing with 285's is far more dependent on your caster alignment. (more caster = wheel forward more. if you have to trim, its far easier)
  3. Jan 30, 2013 at 8:52 PM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    Hey Mike, I think you may have to chop the cab mount with 285's. It could rub at full lock.
