ok here we go... don't flame the new guy please. Axle Wrap or Transmission Issue?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gatordog, Apr 29, 2015.
  1. Apr 29, 2015 at 12:49 PM
    Gatordog
    Gatordog [OP] Well-Known Member
    Florida
    18 TRD SPORT DCLB4x4
    I searched first! :) and it was overwhelming frankly
    At a lot of stop lights half the time my brand new 15DCSB Trd Sport lurches forward like its going to hit the person in front of me or I got tapped in the back like a oops moment from the vehicle in the back. C'mon this is a brand new 30k+ truck... really. Already in the first week I owned it the tailgate handle snapped off for no reason other than asking it to open.... Rant over
    So is this a "go the stealership" (again in two months) or a " Guy welcome to the Taco with Ax wrap" if that is what it is.... OR?
    Thanks in advance.:bowdown: Not everyone who roams here is a truck expert so I truly appreciate the advice and occasionally the witty banter associated with the forum.
  2. Apr 29, 2015 at 12:57 PM
    andyzx6r
    andyzx6r Well-Known Member
    Atlanta
    Super White TRD Sport
    A/C on?
  3. Apr 29, 2015 at 1:01 PM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
    Definitely not an axle wrap issue if you are just sitting still. Probably when your AC compressor kicks on.
  4. Apr 29, 2015 at 1:24 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    AC compressor for sure. You'll get used to it.
    Tailgate handle snapped off, that sucks!
  5. Apr 29, 2015 at 2:10 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    OP, you may answer that the A/C is off, but if you selected defrost on the HVAC panel, the A/C compressor will operate periodically.... this is normal and designed into it.
    ... In other words, you don't have an axle wrap or tranny problem.
  6. Apr 29, 2015 at 3:18 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Do you have an Automatic??
    Search "Automatic Lurch"
    https://www.tacomaworld.com/search/17392/?q=Automatic+lurch&t=post&o=relevance
    It's normal. In fact.....it has nothing to do with A/C - although, probably feels worse with it on. From what I've experienced and/or learned - if you make quick stops, the transmission is downshifting AFTER you come to a stop. That's what the lurch is. The transmission downshifting.
    If you slow down first and come to a stop on a more relaxed slow pace, you won't get that lurch.
    After a while, you won't even notice it. I've had my truck for 8+ years now, and I don't even notice it anymore.
    Since you're still under warranty, I would atleast have your dealer check to make sure there's enough fluid in the transmission.
    Gatordog[OP] likes this.
  7. Apr 29, 2015 at 3:30 PM
    Brjw
    Brjw Well-Known Member
    Brian
    Forest Grove, Oregon
    My 2015 does this. Will catch you off guard if you aren't hard on the brakes when sitting still. I attributed mine partially to the supercharger but it sounds common.
    It does feel like the ac kicks on and causes an idle up sometimes too.
  8. Apr 30, 2015 at 12:56 PM
    Gatordog
    Florida
    Thanks all!!! Yep.... we got a weird to us spoiled Floridians a late "cold" front and it was only 65 out this morning and sure enough after reading your posts about the a/c... it's def that lurch with the compressor on and nothing else! Best forum I have used for great information... thanks again
    and it's due for the first OC @ 5k soon so I'll have them check the tranny fluid level just cause and hopefully their body shop can adjust the replacement tailgate handle cause I still have to push the gate in while pulling to get it to open... RRRR
  9. Apr 30, 2015 at 1:00 PM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    just to make sure, if you have a torque wrench handy, re-torque the rear U-bolts to around ~80ft lbf
