Ok it’s the weekend and time to lift my Gen2
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ritter, May 1, 2021.
  1. May 1, 2021 at 5:49 PM
    Ritter
    Ritter [OP] Well-Known Member
    David
    Atlanta/ Nassau
    08 Taco Crew TRD and 03 Xtra 4x4
    Extreme newb though I own a Gen 1 and 2 for over 10 years.
    Looking at 2” lift for my Gen2 . The only off-roading I do is occasionally the infield at Road Atlanta and if I miss my driveway and end up on the grass next to it.
    I only know what I’ve skimmed here (200 pages into the silver Tacoma thread). Bilstein 5100’s? What else do I need?
    Which shop in Atlanta area can perform this feat for me?
    Thanks in advance.
  2. May 2, 2021 at 3:26 AM
    TacoTuesday1
    SD CA
    2" is probably either spacers
    or $90 AAL in back (+ hardware kit), Bilstein 5100 shocks set to 0 (~$300, supposedly can be ordered generic or vehicle model-specific) to handle that lift height
    and taller front spring such as OME 883x or whatever else is out there, to lift the front 2"
    all varies in price
    easier to install with access to spring compressor
    maybe refreshing some suspension parts while you're in there like strut top mounts (~$25-30/per side)
  3. May 2, 2021 at 9:04 AM
    Ritter
    David
    Atlanta/ Nassau
    Hey thanks. Good suggestion on the mounts “while we’re in there”. Anything else you can think of?
    I’ll probably just go with spacers right now and see how the ride is. Any recommendations?
    Can any mechanic with a lift do this or do I need an experienced shop?
  4. May 2, 2021 at 9:14 AM
    Bishop84
    Bishop84 Well-Known Member
    Mounts aren't really wearable items, the new shocks come with new bushings and washers, so they can be left.
    Spacers are fine for a quick lift. ReadyLift is pretty cheap and reputable. Usually with spacers its 2 1/4 front and 1" rear.
  5. May 2, 2021 at 9:24 AM
    Ritter
    David
    Atlanta/ Nassau
    Thanks. Just ordered Bils all around + Old Man Coils for the front.
    My bed is usually lightly loaded so 1” blocks sounds like the way to go.
    Just to be clear the front shocks are variable and so the rear 1” blocks can provide an overall approx 2”inch lift?
    Bishop84 likes this.
