Ok, it's too cold, and getting worse, time to be less lazy.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by captaintofuburger, Dec 28, 2021.
  1. Dec 28, 2021 at 5:38 PM
    captaintofuburger
    captaintofuburger [OP] Well-Known Member
    2011 Base 4wd 4banger
    Backstory, plugged in a 100W power inverter in, all was well, no hot wires. Then my blower motor pooped out. Wasn't the resistors because it didn't work on high. Lazy, I just unrolled the windows and quit using AC. Magically a week later, kicks to life, works for weeks.
    Plug a 150w inverter in to charge my laptop, start the truck. Blower motor dead. This was in June. It's still dead.
    However both times, all cigarette lights work with cell chargers.
    About 2 weeks ago I start my truck. Lowbeams, inop. High works, low won't. Blubs ohm out, fuses good, swapped relays, not seeing anyhinng obvious.
    Something makes me think all 3 must have a common something. Is there a shared ground point somewhere? Can't seem to find much on google. Or somehow I have 3 odd things break.
  2. Dec 28, 2021 at 5:58 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I think your dealing with separate issues, you might want to check the connector at the blower switch for melting or burning.
    Otherwise you need to check powers and grounds at each component and see what's missing.
    RustyGreen and TnShooter like this.
  3. Dec 28, 2021 at 6:00 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    High and Low Beams share the same ground.
    You need to see if you have power to the socket.
    Red/Yellow and Red/Black are wires for the Low.
    I’d start at the Lo Fuses for the head lights. Check them for power.
    Then go from there. If you don’t have power to those fuses, don’t bother checking the socket. They don’t have power either.
  4. Dec 28, 2021 at 6:13 PM
    captaintofuburger
    Came in to posy this and look for my multi-meter, I just remembered that I just started to notice my AC light will flash, regardless if in I have it set either full hot/cold. If that has something to do with it. Just seems like 1 progressive problem getting worse. to me.
  5. Dec 28, 2021 at 6:29 PM
    captaintofuburger
    Have full power on anything I test either fuse or relay, swapped relays around, no change.
  6. Dec 28, 2021 at 6:32 PM
    TnShooter
    Deogee
    STOCK
    If you have power to the Lo Fuses, then the next step is to go to the socket.
  7. Dec 28, 2021 at 6:41 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The A/C light flashes when the A/C Amplifier does not detect the correct speed signal from the Compressor Lock Sensor when it engages the clutch.
    The first step would be to see if the compressor clutch engages momentarily when the button is pressed.
    If it doesn't you need to check for power at the compressor clutch when the button is pressed.
  8. Dec 29, 2021 at 10:10 AM
    captaintofuburger
    It all of a sudden stopped today, when I move the knobs on my HVAC (any of them) I can get a faint whine (even the ones not related to the blower) something goofy is up.
    https://imgur.com/YAX09b7
    At the bottom, anyone know where EA EB would physically be located? Should mention it's a 2011 2TRFE
    Edit: facepalm, location was on the next page.
  9. Dec 29, 2021 at 10:19 AM
    captaintofuburger
    Fuck it. I'm buying a new truck. as much fun as it is to play in -2 degree weather. I quit.
    CurtB likes this.
