Ok I've been told by dealer it cant be done
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DoggMan1163, Mar 24, 2019.
  1. Mar 24, 2019 at 11:42 AM
    DoggMan1163
    DoggMan1163 [OP] DoggMan1163
    Robert
    2020 Taco TRD off road
    I would like to add rear lockers to my taco I have a 2018 TRD Sport and was wondering if I can put lockers on the back I know the off road TRD has it but dealer told me it won't work on the sport I'm a ferm believer that where there is a will there's a way
    mcharfauros and tcjacado like this.
  2. Mar 24, 2019 at 11:43 AM
    Lunabird
    Lunabird Well-Known Member
    Arb air lockers
  3. Mar 24, 2019 at 11:43 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    Where there's a thick wallet there's a way. I'd just trade it in on an OR
    mcharfauros, JNG, JKU3000 and 3 others like this.
  4. Mar 24, 2019 at 11:44 AM
    DoggMan1163
    Robert
    Would I have to replace the rear end to use them or will thay work with oem
  5. Mar 24, 2019 at 11:45 AM
    WanderingTaco
    WanderingTaco TTC #136
    Erik
    Conroe, TX
    2011 Prerunner
    Harrop
  6. Mar 24, 2019 at 11:45 AM
    tcjacado
    tcjacado Well-Known Member
    Harrop I believe is the name.
  7. Mar 24, 2019 at 11:46 AM
    DoggMan1163
    Robert
    To much aftermarket stuff on taco to trade it
  8. Mar 24, 2019 at 11:49 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You can either buy an aftermarket locker and have it installed, or swap in an entire axle assembly out of a TRD OR and then figure out the wiring.
    Easiest is just get an ARB air locker installed.
    mcharfauros, whatstcp and tcjacado like this.
  9. Mar 24, 2019 at 11:50 AM
    DoggMan1163
    Robert
    Well if Toyota holds with most builders it should have most of the wiring and CPU already there I was thinking of buying a off road that's been totalled and just swapping it out any thoughts
  10. Mar 24, 2019 at 11:51 AM
    DoggMan1163
    Robert
    Thanks for the advice and inputs
  11. Mar 24, 2019 at 11:51 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It’s more effort than it’s worth IMO.
    tcjacado and GF8er like this.
  12. Mar 24, 2019 at 11:53 AM
    tcjacado
    The wiring is the hardest part of it. A few have done this on their 2nd gens and a few have done 4wd conversions on their 1st gens.
    Nunya Bizness likes this.
  13. Mar 24, 2019 at 11:53 AM
    DoggMan1163
    Robert
    I just didn't know if a arb would work with the stock taco rear or would there be a lot of mods to do
    tcjacado likes this.
  14. Mar 24, 2019 at 11:54 AM
    DoggMan1163
    Robert
    I'm not to knowing about lockers
  15. Mar 24, 2019 at 11:54 AM
    WanderingTaco
    Erik
    Conroe, TX
    2011 Prerunner
    It works you just need to run air lines and get a compressor
  16. Mar 24, 2019 at 11:54 AM
    tcjacado
    Arb is the easiest route I believe. Or get a trutac Detroit locker
  17. Mar 24, 2019 at 11:54 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Incorrect. The housing is different, not to mention two completely different gear assemblies. The rear end in his sport is a 8.4” ring gear (assuming he’s an automatic) and the Offroad is an 8.8” or something like that.
    Tocamo, DoggMan1163[OP] and tcjacado like this.
  18. Mar 24, 2019 at 11:55 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It bolts right in. A professional can install it in a day and you’ll be out the door for maybe ~$1,800 by the time you pay for a locker, an air compressor to engage it, and labor.
  19. Mar 24, 2019 at 11:56 AM
    DoggMan1163
    Robert
  20. Mar 24, 2019 at 11:56 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    I would look for a respected off road shop or axle/gear shop local and see what they offer. You could also do some shopping online at places like www.randysworldwide.com/toyota-drivetrain-differential/ I should add there are more than one type of locker diff's. An air or electronic locking diff might not be your best option, take time to determine what you are trying to accomplish and how you plan on using your truck.
