OK kinda confused on something
Discussion in 'Suspension' started by ross123, Aug 1, 2010.
  1. Aug 1, 2010 at 3:39 PM
    ross123
    ross123 [OP] Well-Known Member
    fort bragg
    so im thinking on doing 5100's all around. and getting ome 885's for the front of my truck. if i do this what would i need to set the 5100's at in order to get a full 3 inch lift up front? and would i need any spacers? ok now onto the rear. would the toytec AAL add enough lift to make the rear even with the front? thanks guys
  2. Aug 1, 2010 at 3:41 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    The max I'd set the 5100's to would be .85". That combined with the 885's would give you approx. 3" of lift IIRC. For the rear a Toytec 1.5" or 2" AAL would be good for the back.
  3. Aug 1, 2010 at 3:42 PM
    JAG
    JAG Well-Known Member
    I wonder if it would be more worth your while to get the ome front shocks too.... the ome coils actually give you the lift. So the 5100's might be futile.
  4. Aug 1, 2010 at 4:37 PM
    ross123
    fort bragg
    yeah right now im in between the OME lift kit or getting 5100's all around i just dont know ive read these boards alot and i still cant make up my mind
  5. Aug 1, 2010 at 5:17 PM
    JAG
    I have the billies and wish I would have got the ome lift. It would have give me a real 3 inch lift.
    If i had a redo I would have done this....
    ome coils
    ome shocks/struts
    light racing uca's
    1/4 spacer for driver side taco lean
    tsb 1.5 inch aal
    but thats just me
  6. Aug 1, 2010 at 5:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    That would give over 3" lift....More like 3.75" lift. Only recomended IF you are running aftermarket UCA's. ;)
  7. Aug 1, 2010 at 6:41 PM
    ross123
    fort bragg
    whats this taco lean? im guessing one side sags alittle more then the other?
  8. Aug 1, 2010 at 7:11 PM
    JAG
    driver+full gas tank+battery=heavy left side
    I don't think the ome coils are side specific... chris 4x4 will know if you need to get the spacer or not...
  9. Aug 1, 2010 at 7:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Nope. They are not side specific. OME sells a Trim Packer, for use with their shocks. For the 5100's, a 1/4" spacer can be used.
  10. Aug 1, 2010 at 7:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  11. Aug 1, 2010 at 7:57 PM
    AKTacoma
    AKTacoma Dedicated Crew Chief
    Houma, Louisiana
    08 Tacoma DCLB
  12. Aug 1, 2010 at 8:03 PM
    Incognito
    VA
    Gotcha, thanks for the clarification Chris. :eek:
    On Wheelers, it says the 885's give 1.75" of lift... I assumed that with the coils would be close to 3". :eek:
  13. Aug 1, 2010 at 8:06 PM
    JAG
  14. Aug 1, 2010 at 8:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah....Not entirely sure why they list that. The 885 give almost 3" lift alone.
  15. Aug 1, 2010 at 8:08 PM
    Incognito
    VA
    Got it, thanks again for clearing that up!
  16. Aug 1, 2010 at 8:08 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
  17. Aug 2, 2010 at 8:20 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    When I was looking at the OME springs from Wheelers they said that those numbers for the 884, 885 and 886 were not correct and just haven't updated them.
  18. Aug 2, 2010 at 8:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats what I was told as well.
  19. Aug 2, 2010 at 9:03 AM
    Masada
    Taylor
    Laveen, AZ
    Lol how hard would it be to update their information???
  20. Aug 2, 2010 at 9:24 AM
    newbtacoma
    newbtacoma Well-Known Member
    Houston, TX
    2010 Super White Sport
    What do you have now? Why would you have gotten the OME kit instead? I am also looking at lifting my truck and I think I want the toytec ultimate kit.
