OK,lets start over
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HondaGM, Oct 31, 2009.
  1. Oct 31, 2009 at 10:03 AM
    HondaGM
    HondaGM [OP] Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    whats your opinion on trans fluid service intervals,not what toyota says,i want to know how you maintain your truck and why.:D
  2. Oct 31, 2009 at 10:13 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    I maintain mine to the spec toyota says. Checked at the dealer after 100K miles. If I keep towing heavy it may be sooner. You have to understand the the engineers came up with the number for a reason, they didn't just arbitrarily pull it out of their asses.
  3. Oct 31, 2009 at 10:18 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    Are you sure jk :D
  4. Oct 31, 2009 at 10:20 AM
    TacoNut
    Adam
    Denver, Co
    Hmmm, the Japanese are flexible. :p
  5. Oct 31, 2009 at 10:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    And how do you know this???? :eek:
  6. Oct 31, 2009 at 10:34 AM
    gcwaterski
    gcwaterski Well-Known Member
    x2, I have dated 2 myself :p
  7. Oct 31, 2009 at 10:39 AM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
  8. Oct 31, 2009 at 10:54 AM
    TacoNut
    Adam
    Denver, Co
  9. Oct 31, 2009 at 5:14 PM
    def4pos8
    def4pos8 Well-Known Member
    Ohio
    White Tacoma AC 2.7L/5spd SR5
    undercoat, running boards
    I drain/refill my manual transmission's gear lube at 24-month intervals. I'm an Old Guy so that's only about 20,000 miles. Moisture contamination isn't a big deal with the tranny but it is with the differential, which is why I'm under the truck playing with 75W-90. I do 'em together. Now and then the amount of grunge on the magnet is surprising.
  10. Oct 31, 2009 at 6:35 PM
    Peru
    Peru Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    had a GMC -- interval on tranny was 60K I had it flushed at 27K. The oil looked like used motor oil. I think they want their trucks to look like they have low owner cost (low maintance). I had mine flushed by the dealer. Bought my Tacoma used so I wanted to make sure I cover myself if past owner towed enough to make a diff. Aside from GMC I've seen other manufacturers claim numbers that IMO are not kosher.
  11. Oct 31, 2009 at 7:21 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    like i already told you...100k complete flush cause toyota says so! opinion is that if that is what they recommend, then its good!
  12. Nov 1, 2009 at 7:15 AM
    M2M
    M2M Well-Known Member
    bilstiens, sport 08 w/o scoop, debadged
    my mechanic recommended I flush and change at 50 K because of all the miles I put on it -
    51k in less than two years
    I did a complete change - tranny.transfer case and differential
    also did cooling system because I live in so cal and drive to the mountains
    overkill, don't know but i have always got great life out of my trucks - 150k - 220k - w/o major problems - and we're talking dodge and ford in the past
  13. Nov 1, 2009 at 10:15 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    How much grunge do you get in just 1 yr 20,000 miles on a brand new truck? :confused: I have the same truck in red. Thanks Curious George
