OK Off Road Owners
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoSport, Jan 31, 2011.
Have you needed to use A-TRAC in the last 3 mos on your OR?
Poll closed Mar 2, 2011.
  1. Yes
    50.0%
  2. No
    50.0%
  1. Jan 31, 2011 at 9:00 AM
    TacoSport
    TacoSport [OP] opinions are like assholes; everyones got one.
    NE
    2011 TRD SSM Sport DCSB w/Tow
    There's a lot of threads here about the value of A-TRAC by OR owners and I would like to know if you have used it in the last 3 months because you really needed it?
  2. Jan 31, 2011 at 9:01 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    18 wrx limited 6MT
    Just used mine saturday on a trail run. Felt it kick in quite a bit while ascending snowy inclines.
  3. Jan 31, 2011 at 9:28 AM
    fishshooter
    fishshooter Well-Known Member
    Northwest Florida
    09 Super White TRD Off Road 4X4
    Stock
    Used it a few weeks ago launching a boat from a back-yard ramp. The water was low, and I dropped the ass end off the back of the concrete ramp. Even where my front tires were was covered in silt. The back tires were useless, I was able to pull the trailer back out with just the two front tires grabbing. There is no way I would have gotten out of it without ATRAC or a front locker, just not enough traction for one tire to pull the truck and trailer. The guy with me was super impressed.
  4. Jan 31, 2011 at 10:12 AM
    RogueLeader
    RogueLeader Well-Known Member
    Rod
    Las Vegas, NV
    2011 Tacoma Double Cab SR5 TRD
    Used it to help finish a climb up a rutted hill. Works like it's supposed to.
  5. Jan 31, 2011 at 10:15 AM
    jonny
    jonny Betty White Edition Heep ZJ
    had to use ATRAC a few weeks ago at cleghorn. for some reason 4lo and the rear locker didnt cut it on one of the bypasses. hit the atrac button and up we went. little jerky this time...but made it :p
  6. Jan 31, 2011 at 11:29 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Great replies... although it may have been over 3 months since I have been off roading much, A-TRAC is active when ever I go into L4... as spinning tires is just silly and damaging to the roads and tires.
    While we can get almost anywhere we want without A-TRAC, there is peace-of-mind knowing it is there and does what is claimed!
    The first time I really needed it was when my Tacoma was a couple months old and we went out to the Drug Airport/ Welk Run near San Marcos/ Escondido... I backed down a deeply rutted climb and high centered the back end with the tires over the ruts and truck resting on the diff. and spare.
    The rear locker was useless since neither back tire was on the ground, and in 4WD the front might have had one good tire on the grond firmly. So the other tire would have spinned away. The A-TRAC was on, and I gave it the gas... and my truck pulled itself out of the ruts...
    Since then I have taken my truck to the limits many times in Baja and in the desert near here... it is amazing technology that turns our truck into a tractor!
  7. Jan 31, 2011 at 11:54 AM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    Nope I have never used. And for a good reason: I don't have it.:D
  8. Jan 31, 2011 at 12:05 PM
    David K
    The way the poll is worded may put off a few A-TRAC owners... We may not always 'need' to use it... but it is a more enjoyable experience to crawl up or through with it turned on.
    In loose rocks or similar, regular 4WD will have one rear and one front spinning and kicking out rocks... beats just one rear tire spinning (2WD) or usually beats two rear only tires spinning (locker or LSD).
    Off Road TRDs before 2009 had regular 4WD plus a rear locker... two rear tires locked plus one in front spinning... Prety much took us everywhere... but what if any of the tires didn't need to spin and kick out rocks and dig ruts?
    Traction Control in Low Range: A-TRAC... All four tires with rotation matched across an axle, so spinning free and kicking up rocks and making ruts is reduced or eliminated so energy (torque) moves your truck forward!
  9. Jan 31, 2011 at 12:28 PM
    jonny
  10. Jan 31, 2011 at 1:20 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    There will be usage for sure 20 inches of snow coming with ice ... :D Its supposed to be biblical. I wonder if NorthEast gonna get slammed like in 90's and they going have to call National Guard to help.
    Its goign to be fun passing by or pulling those Humvee s out of ditches :headbang:
    I may actually have to turn one or both lockers :D
  11. Jan 31, 2011 at 1:29 PM
    DCW
    DCW Well-Known Member
    David
    Reno, Nevada
    2011 TRD DC Off Road
    TRD exhaust, front skidplate,5100s@1.75
    Last weekend near a place called snake lake. I was going through a river bed (dry) that had been washed out next to a stream and was teetering. Passenger tire on solid and driver rear on solid ground and air under the other two tires. put the A-Trac on and it hooked right up and had lunch next to the stream it worked perfectly.
  12. Jan 31, 2011 at 1:31 PM
    TacoSport
    NE
    Not the intent of the poll
  13. Jan 31, 2011 at 1:36 PM
    TacoSport
    NE
    Blizzard of '78 was one to remember too. I got home in a '70 Barracude convertible and it was buried so deep in snow the next day I could not find it. The town I lived in had a State of Emergency for 2 weeks.
  14. Jan 31, 2011 at 1:47 PM
    fishshooter
    Northwest Florida
    Stock
    As does cgs2k2 and TacomaRoamer. S.B. has an 08. :confused: Was it an option in those years?
  15. Jan 31, 2011 at 2:25 PM
    jonny
    no
    they are just being jerks :gossip:
    :laughing:
  16. Jan 31, 2011 at 2:27 PM
    fishshooter
    Northwest Florida
    Stock
    I know. :) Poll is already a fail.
  17. Jan 31, 2011 at 2:38 PM
    musty40
    musty40 Well-Known Member
    Alan
    Duluth, MN
    2010 DC SB TRD OR
    Haven't used it yet.
    Maybe on the next trip to Canyonlands.
  18. Jan 31, 2011 at 2:43 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    It is nice? Yeah. Is it needed? Nah. I ran an 86 4Runner with open diffs for years.
  19. Jan 31, 2011 at 7:55 PM
    WickedTaco
    WickedTaco Well-Known Member
    Aaron
    Treasure Coast, FL
    '11 Silver DC TRD OR 4x4
    iPod Interface, Bully Tailgate Lock, ScanGaugeII
    Used it a few times and it's worth every penny. The feature alone makes me appreciate my OR model even more.
  20. Jan 31, 2011 at 8:15 PM
    ruslanus
    ruslanus Well-Known Member
    Rus
    Wasilla, AK
    Never used it, but it's because I haven't gone anywhere that would require even a 4L. I think I used my 4H once or twice, when I went snowboarding and when I was at Pismo Beach. But it's nice to know I have it just in case. I'm one of those, "better to have it and not need it..." type of guys :)
